Help with Fanuc O-MD control
within a thou
I have a VMC with a Fanuc O-MD controller. When running a program the tool length offset (H value) is added to my actual Z position (for example if I am programmed at G90 Z-1. and my H value for the tool is -1.5 on the actual position page it shows a z value of Z-2.5) and I know it is a parameter setting to turn this off. I am just not sure which bit I need to change. Any and all help is greatly appreciated.
Yes I am in Absolute this parameter is bit 5 of parameter 018 on other fanuc series controllers I just don;t have the proper parameter book.
No I am not using a tool setter I have a reference tool with a H value of 0.0 I touch that off where I want it then in my G54 offset page I type the actual machine position in reference to home. then when I set a tool after that it is the difference of the length of my cutting tool to my standard and that difference in length becomes my H value
Fanuc Series 0-MD here...
I never bother using a reference tool myself. I just touch off bits to be used using a 123 block and add or subtract the difference from the stock thickness and input it in the corresponding tool offset number. If a stock mikes out to 2.525", I touched the tip of the bits off to the 2" side of 123 block and subtract .525" then input this value. Its super fast touching off bits this way for me so I've always stuck to this way.
As for using a reference tool...
1. Touch off ref tool to your stock.
2. Press function key (POS) until the current position display screen with relative coordinates is displayed.
3. Reset the relative coordinate for the Z-axis to 0 (press CAN key)
4. Press function key (MENU OFFSET) until the tool compensation key is displayed.
5. Use manual operation to move the tool to be measured until it touches the same specified position. The difference between the length of the ref tool and the tool to be measured is displayed in the relative coordinates on the screen.
6. Move the cursor to the compensation number for the target tool (the cursor can be moved in the same way as for setting tool comp values).
7. While holding down the (EOB) key, key in address Z. If either X or Y key is depressed instead of Z key, the X or Y axis coordinate value is input as a tool length comp value.
8. Press the (INPUT) key. The Z axis relative coordinate is input and displayed as a tool length offset value.
^ Thats from the FANUC Series 0 Operator's Manual...
yes ROY I am doing that now but my actual machine parameter data bit is set wrong depending on how it is set the tool length offset is aded in my absolute position Z display or you can set it so it doesn;t add it to my actual G90 position. I just don;t know which data bit I need to change to make the display to not include my compensation value
Oh, OK.
:Gilda Radner voice: "Nevermind."
Remember to turn power off before a changed parameter can take effect...
I found this...
Selection of tool length offset
Select tool length offset A, B, or C by setting bit 6 of parameter 003 and bit 3 of parameter No. 119.
- Not sure if that helps, but I tried. Hope you get it working the way you want.
even after repowering it is still the same. ROY ya that doesn;t apply to this but that is the answer o my next problem lol I am just tryin to prioritise this mess. I just started with this company they were running this machine so back arsewards I am trying to get us up to speed. Not only do I not get to see where my actual Z is at If I marry My H and D values (G43 H1 and G41 D1) it adds both offsets and applys the sum of both of them to both my length and diameter offset. Also when I run off DNC my control is completely blank luckily I am the programmer and not the guy in front of it
I found this...
Right now my machine is set up it If my offset page is set up as follows
H1 -1. D1-1.5
When I program
G43 H1
it adds them together and gives me a H value of the sum of both (in this case Z-2.5)
This is also true when I use G41 it shifts my diameter by 2.5 and not the 1.5 I want it to.
Now what I want to o is set the machine up so I can use the same H# and D# and have it so they don;t compound.
Right now I currently have to use 2 seperate numbers the control doesn;t recognise the difference between my Length offset page and my wear offset page and reads them both as one number
Does the book have the combination of Bit 6 parameter 003 and bit 3 parameter 019 to allow me to do this?
Right now the machine is set for Tool Offset "A" (1 Column)H one number D another number not used as H anywhere.
Tool Offset "B" is H&D same number with no wear (2 columns).
Tool Offset "C" is H&D same number in addtion to wear values for H&D (4 Columns).
That is an option (read you're going to have to pony up some $$$ to Fanuc) to have the same H&D. NO gettin' around that.
Thanks again I have a 24 carriage ATC guess I will just create a standard of adding 30 to my D value so there is no interference and my operators know whats going on.
My other 2 problems are when I run off DNC the program does not display on the controller is this a add on or is there a way to get this program on my screen? Makes it hard when all you can see is distance to go and current codes being executed.
The last problem is when I use G83 my tool starts feeding from .100 above the previous peck depth which is way to far away. I would like to change it to .04
There is a parameter for that look the book for the canned cycles and read carefully and it will tell you what one to adjust.
No book here when working from home so can not be of much help.
