not fully retracting
Bob W.
It appears that my mill is not fully retracting during drilling cycles before heading to the next hole location. It looks like it nicks the side of the hole just slightly as it retracts out. Is there a setting to specify a full retract before rapid in X or Y?
Bob
Make sure in your tool path dialog, that on the drill page that "use clearance only at the start and end of operation" is unchecked.
If it is ,
what values are you using in your drill cycle?
Here is the code in question.
( .375 90 DEG. CSINK TOOL - 12 DIA. OFF. - 12 LEN. - 12 DIA. - .375 )
N900 T12 M6
N910 G0 G90 G54 X.215 Y-.245 S3000 M3
N920 G43 H12 Z.03 T5
N930 M8
N940 G99 G81 Z-.062 R.03 F15.
N950 X1.465 Y-.645
N960 G80
N970 X2.145 Y-.245
N980 G99 G81 Z-.062 R.03 F15.
N990 X3.395 Y-.645
N1000 G80
N1010 X4.075 Y-.245
N1020 G99 G81 Z-.062 R.03 F15.
N1030 X5.325 Y-.645
N1040 G80
N1050 X6.005 Y-.245
N1060 G99 G81 Z-.062 R.03 F15.
N1070 X7.255 Y-.645
N1080 G80
N1090 X7.935 Y-.245
N1100 G99 G81 Z-.062 R.03 F15.
N1110 X9.185 Y-.645
N1120 G80
N1130 X9.865 Y-.245
N1140 G99 G81 Z-.062 R.03 F15.
N1150 X11.115 Y-.645
N1160 G80
N1170 X.215 Y-1.915
N1180 G99 G81 Z-.062 R.03 F15.
N1190 X1.465 Y-2.315
N1200 G80
Bob
A G98 will tell the machine to retract to the 'initial height' which in this case is Z.03 as set in the G43 line:
A G99 will tell the machine to retract to the 'R-Plane" as set in the canned cycle definition line:
Notice that the height is the same for the initial height and the retract height. To fix this, simply check the box nect to 'Clearance' in the operation parameters for that operation and set a reasonable height that you wish to retract to in between the holes. This will result in G98 output automagically.
