HELP !!! 5AX HASS POST
DLIND
We have a Haas VF-2 with a TR-160 5ax Trunion
Using MC9.1 MR0105 (MPGEN 5AX POST)
Need some help on getting our post to allow 'A' axis to go from a (+)to(-) on rotation.
The issue is when cut starts 'A' axis is tilted in the positive direction. as it approaches 'A0' the 'B' axis is rotated 180 deg. to allow 'A' to remain cutting in a positive direction.
2nd issue, We are using 90% of machines' envelope, with 'B' axis rotating 180 tool retract position cannot be consistent.
When cut is made on left side of web, retract
is 5.25" to clear material for re positioning on next pass
When cut is made on right side of web, retract
is 7.5" to clear material for re positioning on next pass.
problem is that we are operating within about a 1.5" envelope for our 'Z' retract.
Below is an example of post generated tool path
I've separated the area in question.
Thank you, Daniel
:0001 ( PROGRAM - 07 )
( DATE - 14-11-07 TIME - 09:37 )
G20
G0 G17 G40 G80 G90 G94 G98
G0 G28 G91 Z0.
( 3/8 BULL ENDMILL 0.1250 RAD 1.8 R TOOL - 1 DIA. OFF. - 1 LEN. - 1 DIA. - .375 )
( TOP )
T1 M6
G0 G54 G90 X.6815 Y-6.583 B163.463 A49.088 S10000 M3
G43 H1 Z2.9454 M8
B163.521 A49.08
X.6787 Y-6.5833
Z-.1606
G1 G93 X.6785 Y-6.583 Z-.8081 A49.114 F46.62
X.6616 Y-6.5785 Z-.7969 B163.796 A48.939 F1999.99
X.6432 Y-6.5734 Z-.7931 B164.088 A48.829 F1999.99
X.636 Y-6.5675 Z-.7869 B164.247 A48.706 F1999.99
X.6124 Y-6.5628 Z-.7828 B164.6 A48.588 F1999.99
X.5967 Y-6.5582 Z-.7684 B164.863 A48.387 F1999.99
X.5772 Y-6.5539 Z-.7644 B165.16 A48.279 F1999.99
X.5801 Y-6.5473 Z-.7766 B165.175 A48.343 F1999.99
X.575 Y-6.541 Z-.7814 B165.294 A48.327 F1999.99
X.5655 Y-6.5351 Z-.7788 B165.472 A48.236 F1999.99
X.5523 Y-6.5293 Z-.776 B165.695 A48.141 F1999.99
X.5525 Y-6.5223 Z-.7777 B165.755 A48.1 F1999.99
X.5435 Y-6.5168 Z-.775 B165.919 A48.013 F1999.99
X.525 Y-6.5118 Z-.7641 B166.204 A47.845 F1999.99
X.5126 Y-6.5075 Z-.7461 B166.415 A47.62 F1999.99
X.5119 Y-6.5006 Z-.7549 B166.475 A47.647 F1999.99
X.5032 Y-6.4941 Z-.749 B166.642 A47.527 F1999.99
X.4861 Y-6.4885 Z-.7317 B166.917 A47.296 F1999.99
X.4908 Y-6.481 Z-.7374 F1999.99
X.4824 Y-6.4754 Z-.7308 B167.071 A47.181 F1999.99
X.4697 Y-6.4701 Z-.7095 B167.287 A46.925 F1999.99
X.4616 Y-6.4642 Z-.6959 B167.444 A46.743 F1999.99
X.4573 Y-6.4574 Z-.6935 B167.553 A46.665 F1999.99
X.4477 Y-6.4511 Z-.6871 B167.724 A46.547 F1999.99
X.4408 Y-6.4448 Z-.6703 B167.87 A46.335 F1999.99
X.4317 Y-6.4376 Z-.6609 B168.043 A46.185 F1999.99
X.4279 Y-6.4315 Z-.6545 B168.141 A46.077 F1999.99
X.4241 Y-6.4255 Z-.6409 B168.24 A45.902 F1999.99
X.4065 Y-6.419 Z-.6202 B168.514 A45.645 F1999.99
X.4031 Y-6.4118 Z-.6109 B168.614 A45.504 F1999.99
X.4085 Y-6.4046 Z-.6089 B168.602 A45.44 F1999.99
X.3998 Y-6.3974 Z-.5958 B168.766 A45.26 F1999.99
X.3921 Y-6.3902 Z-.5792 B168.919 A45.048 F1999.99
X.3838 Y-6.3843 Z-.5584 B169.073 A44.805 F1999.99
X.3797 Y-6.3776 Z-.5452 B169.176 A44.632 F1999.99
X.3757 Y-6.3697 Z-.5395 B169.28 A44.523 F1999.99
X.3689 Y-6.362 Z-.516 B169.425 A44.248 F1999.99
X.3703 Y-6.3543 Z-.5035 B169.465 A44.081 F1999.99
X.3699 Y-6.3473 Z-.501 B169.518 A44.011 F1999.99
X.368 Y-6.3395 Z-.4777 B169.6 A43.742 F1999.99
X.3598 Y-6.3315 Z-.4579 B169.761 A43.5 F1999.99
X.3607 Y-6.3238 Z-.4487 B169.803 A43.365 F1999.99
X.357 Y-6.3163 Z-.4354 B169.899 A43.192 F1999.99
X.349 Y-6.3091 Z-.4082 B170.051 A42.886 F1999.99
X.3466 Y-6.3009 Z-.3849 B170.137 A42.618 F1999.99
X.3486 Y-6.2927 Z-.3689 B170.169 A42.419 F1999.99
X.349 Y-6.2848 Z-.3629 B170.213 A42.316 F1999.99
X.3521 Y-6.2758 Z-.3401 B170.234 A42.053 F1999.99
X.343 Y-6.267 Z-.3207 B170.402 A41.812 F1999.99
X.3442 Y-6.2594 Z-.3075 B170.436 A41.645 F1999.99
X.3457 Y-6.2509 Z-.2912 B170.469 A41.446 F1999.99
X.3429 Y-6.2416 Z-.2682 B170.561 A41.178 F1999.99
X.3456 Y-6.2326 Z-.2452 B170.584 A40.916 F1999.99
X.3479 Y-6.2238 Z-.2284 B170.607 A40.713 F1999.99
X.3551 Y-6.2148 Z-.2126 B170.572 A40.521 F1999.99
X.3459 Y-6.2057 Z-.1891 B170.736 A40.247 F1999.99
X.3496 Y-6.1956 Z-.1627 B170.749 A39.95 F1999.99
X.3554 Y-6.1871 Z-.1534 B170.726 A39.822 F1999.99
X.3553 Y-6.1783 Z-.1441 B170.774 A39.688 F1999.99
X.3599 Y-6.1674 Z-.1141 B170.775 A39.356 F1999.99
X.3584 Y-6.1568 Z-.0807 B170.849 A38.989 F1999.99
X.3657 Y-6.1464 Z-.0621 B170.814 A38.769 F1999.99
X.3724 Y-6.1376 Z-.049 B170.779 A38.605 F1999.99
X.3743 Y-6.1277 Z-.0293 B170.805 A38.372 F1999.99
X.3787 Y-6.1158 Z.0036 B170.807 A38.012 F1999.99
X.3877 Y-6.1053 Z.0269 B170.747 A37.749 F1999.99
X.3884 Y-6.0957 Z.043 B170.785 A37.551 F1999.99
X.3924 Y-6.0843 Z.0731 B170.787 A37.218 F1999.99
X.4008 Y-6.0725 Z.092 B170.738 A36.991 F1999.99
X.4102 Y-6.0606 Z.1178 B170.676 A36.7 F1999.99
X.4234 Y-6.0494 Z.1329 B170.563 A36.515 F1999.99
X.4264 Y-6.0379 Z.1562 B170.576 A36.245 F1999.99
X.4306 Y-6.025 Z.186 A35.912 F1999.99
X.4473 Y-6.0126 Z.2157 B170.421 A35.591 F1999.99
X.4541 Y-6.002 Z.2284 B170.382 A35.427 F1999.99
X.4647 Y-5.9884 Z.2607 B170.302 A35.073 F1999.99
X.4753 Y-5.9747 Z.2928 B170.22 A34.72 F1999.99
X.4792 Y-5.9625 Z.3203 B170.218 A34.412 F1999.99
X.4827 Y-5.9503 Z.3533 B170.215 A34.053 F1999.99
X.4863 Y-5.9376 Z.3833 B170.212 A33.719 F1999.99
X.4984 Y-5.9223 Z.4163 B170.113 A33.355 F1999.99
X.5022 Y-5.909 Z.4461 B170.109 A33.021 F1999.99
X.4997 Y-5.8965 Z.4833 B170.174 A32.618 F1999.99
X.5171 Y-5.8818 Z.5125 B170.002 A32.298 F1999.99
X.5218 Y-5.8678 Z.5463 B169.982 A31.926 F1999.99
X.5133 Y-5.8544 Z.5876 B170.119 A31.478 F1999.99
X.5123 Y-5.8386 Z.6276 B170.172 A31.037 F1999.99
X.516 Y-5.8235 Z.6567 B170.169 A30.703 F1999.99
X.5137 Y-5.8106 Z.6956 B170.224 A30.286 F1999.99
X.5043 Y-5.7961 Z.7363 B170.371 A29.838 F1999.99
X.5165 Y-5.7781 Z.7707 B170.262 A29.449 F1999.99
X.5147 Y-5.7623 Z.8059 B170.32 A29.053 F1999.99
X.52 Y-5.7459 Z.8455 B170.286 A28.619 F1999.99
X.5073 Y-5.7324 Z.8752 B170.474 A28.273 F1999.99
X.514 Y-5.714 Z.9161 B170.425 A27.821 F1999.99
X.5117 Y-5.696 Z.9548 B170.489 A27.381 F1999.99
X.5074 Y-5.6812 Z.986 B170.571 A27.023 F1999.99
X.5043 Y-5.6644 Z1.0231 B170.639 A26.604 F1999.99
X.5096 Y-5.645 Z1.061 B170.606 A26.171 F1999.99
X.5135 Y-5.6272 Z1.0909 B170.59 A25.82 F1999.99
X.5116 Y-5.6078 Z1.1332 B170.643 A25.34 F1999.99
X.5137 Y-5.5921 Z1.1595 B170.645 A25.029 F1999.99
X.5101 Y-5.5737 Z1.1935 B170.719 A24.63 F1999.99
X.5155 Y-5.5529 Z1.2284 B170.685 A24.218 F1999.99
X.5204 Y-5.5335 Z1.264 B170.65 A23.806 F1999.99
X.5148 Y-5.5165 Z1.2941 B170.746 A23.447 F1999.99
X.5184 Y-5.4975 Z1.3231 B170.73 A23.095 F1999.99
X.5235 Y-5.4766 Z1.3559 B170.694 A22.702 F1999.99
X.5207 Y-5.4551 Z1.395 B170.757 A22.242 F1999.99
X.5224 Y-5.4384 Z1.4185 B170.76 A21.949 F1999.99
X.5257 Y-5.4194 Z1.4475 B170.742 A21.597 F1999.99
X.5239 Y-5.3952 Z1.4915 B170.789 A21.078 F1999.99
X.5205 Y-5.3732 Z1.5282 B170.858 A20.635 F1999.99
X.5322 Y-5.3535 Z1.5521 B170.733 A20.333 F1999.99
X.5323 Y-5.3367 Z1.5691 B170.757 A20.098 F1999.99
X.5462 Y-5.3146 Z1.5946 B170.605 A19.769 F1999.99
X.5605 Y-5.2917 Z1.6203 B170.447 A19.44 F1999.99
X.5494 Y-5.2683 Z1.6671 B170.608 A18.888 F1999.99
X.5449 Y-5.2465 Z1.7052 B170.681 A18.43 F1999.99
X.5466 Y-5.2259 Z1.7266 B170.683 A18.136 F1999.99
X.5597 Y-5.2035 Z1.7472 B170.538 A17.85 F1999.99
X.5731 Y-5.1819 Z1.7684 B170.388 A17.564 F1999.99
X.5685 Y-5.1598 Z1.8047 B170.461 A17.12 F1999.99
X.5658 Y-5.135 Z1.8442 B170.511 A16.633 F1999.99
X.5695 Y-5.1117 Z1.8689 B170.484 A16.297 F1999.99
X.594 Y-5.0892 Z1.8851 B170.184 A16.062 F1999.99
X.5958 Y-5.0691 Z1.9051 B170.178 A15.781 F1999.99
X.5932 Y-5.0439 Z1.9443 B170.223 A15.294 F1999.99
X.5906 Y-5.0171 Z1.9814 B170.272 A14.819 F1999.99
X.6059 Y-4.9928 Z2.0013 B170.087 A14.534 F1999.99
X.6191 Y-4.9723 Z2.018 B169.928 A14.292 F1999.99
X.6349 Y-4.951 Z2.037 B169.729 A14.03 F1999.99
X.6236 Y-4.9203 Z2.0832 B169.889 A13.437 F1999.99
X.6283 Y-4.8958 Z2.1069 B169.84 A13.1 F1999.99
X.6551 Y-4.874 Z2.1175 B169.494 A12.922 F1999.99
X.6534 Y-4.8468 Z2.154 B169.524 A12.446 F1999.99
X.6586 Y-4.8228 Z2.1781 B169.461 A12.111 F1999.99
X.6807 Y-4.7948 Z2.1998 B169.174 A11.793 F1999.99
X.6869 Y-4.7708 Z2.2226 B169.097 A11.467 F1999.99
X.6932 Y-4.7469 Z2.2462 B169.016 A11.131 F1999.99
X.6999 Y-4.7212 Z2.2685 B168.93 A10.805 F1999.99
X.7324 Y-4.688 Z2.298 B168.491 A10.399 F1999.99
X.7405 Y-4.6628 Z2.3204 B168.381 A10.072 F1999.99
X.7453 Y-4.6393 Z2.3391 B168.32 A9.782 F1999.99
X.7542 Y-4.6131 Z2.3607 B168.198 A9.455 F1999.99
X.7811 Y-4.5756 Z2.3981 B167.823 A8.944 F1999.99
X.7921 Y-4.549 Z2.42 B167.67 A8.618 F1999.99
X.8111 Y-4.5269 Z2.4302 B167.403 A8.434 F1999.99
X.8358 Y-4.5004 Z2.443 B167.053 A8.213 F1999.99
X.8782 Y-4.4641 Z2.4671 B166.452 A7.853 F1999.99
X.9003 Y-4.4322 Z2.4919 B166.135 A7.483 F1999.99
X.9244 Y-4.3999 Z2.5174 B165.784 A7.107 F1999.99
X.9704 Y-4.3646 Z2.5379 B165.118 A6.799 F1999.99
X.9783 Y-4.3393 Z2.5506 B164.991 A6.562 F1999.99
X1.0385 Y-4.2963 Z2.574 B164.113 A6.206 F1999.99
X1.0878 Y-4.261 Z2.5908 B163.386 A5.943 F1999.99
X1.0985 Y-4.2294 Z2.6149 B163.21 A5.563 F1999.99
X1.1768 Y-4.1785 Z2.6381 B162.044 A5.21 F1999.99
X1.2187 Y-4.1445 Z2.6468 B161.4 A5.033 F1999.99
X1.2653 Y-4.1035 Z2.6665 B160.684 A4.716 F1999.99
X1.3701 Y-4.0412 Z2.69 B159.092 A4.369 F1999.99
X1.4187 Y-3.9977 Z2.7053 B158.318 A4.097 F1999.99
X1.5331 Y-3.9258 Z2.724 B156.529 A3.801 F1999.99
X1.6242 Y-3.8651 Z2.7363 B155.072 A3.593 F1999.99
X1.7702 Y-3.7715 Z2.7555 B152.723 A3.302 F1999.99
X1.9194 Y-3.6649 Z2.7776 B150.255 A2.958 F1999.99
X2.0876 Y-3.5411 Z2.7918 B147.381 A2.721 F1999.99
X2.2315 Y-3.4226 Z2.8072 B144.834 A2.468 F1999.99
X2.4938 Y-3.2044 Z2.8266 B140.042 A2.213 F1999.99
X2.7482 Y-2.9538 Z2.841 B135. A2.01 F1999.99
X2.9863 Y-2.6733 Z2.8553 B129.806 A1.791 F1999.99
X3.44 Y-1.9948 Z2.8799 B118.072 A1.559 F1999.99
X3.6614 Y-1.4921 Z2.8912 B110.136 A1.464 F1999.99
X3.7883 Y-1.0555 Z2.8993 B103.57 A1.368 F1999.99
X3.9018 Y-.002 Z2.92 B88.025 A1.331 F1999.99
X3.7242 Y1.0569 Z2.9407 B72.181 A1.349 F1999.99
X3.5467 Y1.5004 Z2.9485 B65.095 A1.415 F1999.99
X3.2891 Y1.9573 Z2.9593 B57.265 A1.527 F1999.99
X2.8696 Y2.4851 Z2.9793 B47.121 A1.752 F1999.99
X2.536 Y2.7863 Z2.9963 B40.314 A1.985 F1999.99
X2.2869 Y2.9616 Z3.01 B35.676 A2.2 F1999.99
X2.0524 Y3.1006 Z3.0208 B31.535 A2.367 F1999.99
X1.7858 Y3.2279 Z3.0371 B27.013 A2.624 F1999.99
X1.6322 Y3.2783 Z3.0502 B24.52 A2.872 F1999.99
X1.5209 Y3.3056 Z3.061 B22.751 A3.084 F1999.99
X1.4051 Y3.328 Z3.0744 B20.925 A3.339 F1999.99
X1.2898 Y3.3429 Z3.0903 B19.12 A3.639 F1999.99
X1.1911 Y3.3477 Z3.1061 B17.592 A3.946 F1999.99
X1.0795 Y3.357 Z3.1191 B15.859 A4.199 F1999.99
X1.0257 Y3.3495 Z3.1293 B15.046 A4.42 F1999.99
X.9253 Y3.3477 Z3.1449 B13.496 A4.718 F1999.99
X.8688 Y3.3314 Z3.1603 B12.642 A5.034 F1999.99
X.8319 Y3.3163 Z3.1702 B12.095 A5.257 F1999.99
X.798 Y3.2998 Z3.1796 B11.592 A5.48 F1999.99
X.7612 Y3.2801 Z3.1917 B11.041 A5.753 F1999.99
X.7226 Y3.2575 Z3.2069 B10.46 A6.071 F1999.99
X.6624 Y3.2392 Z3.2216 B9.53 A6.377 F1999.99
X.6644 Y3.2131 Z3.231 B9.593 A6.614 F1999.99
X.6192 Y3.1973 Z3.2402 B8.893 A6.831 F1999.99
X.5735 Y3.178 Z3.2522 B8.183 A7.1 F1999.99
X.5531 Y3.1524 Z3.2638 B7.878 A7.376 F1999.99
X.5342 Y3.127 Z3.2756 B7.595 A7.652 F1999.99
X.5195 Y3.1046 Z3.2852 B7.374 A7.883 F1999.99
X.5081 Y3.0835 Z3.2911 B7.206 A8.063 F1999.99
X.4732 Y3.0595 Z3.3023 B6.654 A8.335 F1999.99
X.4571 Y3.0308 Z3.3159 B6.407 A8.657 F1999.99
X.4642 Y3.0043 Z3.325 B6.537 A8.894 F1999.99
X.4379 Y2.9855 Z3.3312 B6.116 A9.069 F1999.99
X.411 Y2.9619 Z3.3402 B5.682 A9.304 F1999.99
X.4005 Y2.9343 Z3.3505 B5.519 A9.574 F1999.99
X.41 Y2.9105 Z3.3567 B5.684 A9.766 F1999.99
X.4017 Y2.8856 Z3.3651 B5.553 A9.998 F1999.99
X.3939 Y2.8597 Z3.3736 B5.428 A10.231 F1999.99
X.3864 Y2.8343 Z3.3814 B5.309 A10.455 F1999.99
X.3807 Y2.811 Z3.3878 B5.217 A10.652 F1999.99
X.3753 Y2.7891 Z3.3934 B5.128 A10.831 F1999.99
X.37 Y2.7657 Z3.3991 B5.042 A11.019 F1999.99
X.3763 Y2.7349 Z3.4093 B5.152 A11.3 F1999.99
X.3702 Y2.7093 Z3.4175 B5.049 A11.533 F1999.99
X.3655 Y2.6861 Z3.4234 B4.97 A11.721 F1999.99
X.3739 Y2.6608 Z3.4289 B5.114 A11.913 F1999.99
X.3672 Y2.6318 Z3.4386 B4.998 A12.191 F1999.99
X.3618 Y2.6051 Z3.4464 B4.905 A12.424 F1999.99
X.3676 Y2.5743 Z3.4562 B5.006 A12.705 F1999.99
X.3625 Y2.5476 Z3.4639 B4.917 A12.938 F1999.99
X.368 Y2.516 Z3.4737 B5.013 A13.229 F1999.99
X.3632 Y2.4884 Z3.4816 B4.927 A13.472 F1999.99
X.3693 Y2.46 Z3.4887 B5.037 A13.709 F1999.99
X.3753 Y2.4316 Z3.4955 B5.143 A13.946 F1999.99
X.3697 Y2.4012 Z3.5052 B5.042 A14.234 F1999.99
X.3651 Y2.3748 Z3.5121 B4.962 A14.455 F1999.99
X.36 Y2.3443 Z3.5216 B4.868 A14.743 F1999.99
X.3656 Y2.3151 Z3.5291 B4.97 A14.991 F1999.99
X.371 Y2.2872 Z3.5352 B5.068 A15.215 F1999.99
X.366 Y2.2566 Z3.5441 B4.977 A15.504 F1999.99
X.372 Y2.2299 Z3.5493 B5.087 A15.708 F1999.99
X.3671 Y2.1999 Z3.5578 B4.999 A15.984 F1999.99
X.3633 Y2.1717 Z3.5653 B4.927 A16.229 F1999.99
X.3675 Y2.1395 Z3.574 B5.005 A16.522 F1999.99
X.373 Y2.1135 Z3.5787 B5.108 A16.714 F1999.99
X.3686 Y2.0833 Z3.5866 B5.024 A16.989 F1999.99
X.3649 Y2.055 Z3.5933 B4.956 A17.234 F1999.99
X.3688 Y2.0227 Z3.6012 B5.029 A17.527 F1999.99
X.3653 Y1.9941 Z3.6081 B4.963 A17.772 F1999.99
X.3691 Y1.9617 Z3.6164 B5.034 A18.065 F1999.99
X.3657 Y1.9341 Z3.6225 B4.97 A18.296 F1999.99
X.3699 Y1.9043 Z3.6288 B5.051 A18.546 F1999.99
X.374 Y1.8745 Z3.635 B5.13 A18.795 F1999.99
X.3629 Y1.8451 Z3.6421 B4.915 A19.065 F1999.99
X.3669 Y1.8152 Z3.6479 B4.994 A19.315 F1999.99
X.3639 Y1.7865 Z3.6544 B4.934 A19.56 F1999.99
X.3672 Y1.7538 Z3.6619 B4.999 A19.853 F1999.99
X.371 Y1.7239 Z3.6677 B5.074 A20.103 F1999.99
X.3674 Y1.6923 Z3.6749 B5.004 A20.391 F1999.99
X.3711 Y1.6623 Z3.6804 B5.077 A20.641 F1999.99
X.3682 Y1.6333 Z3.6859 B5.02 A20.887 F1999.99
X.3718 Y1.6032 Z3.6915 B5.091 A21.137 F1999.99
X.369 Y1.5742 Z3.6973 B5.035 A21.383 F1999.99
X.3657 Y1.5413 Z3.7046 B4.97 A21.688 F1999.99
X.3692 Y1.5112 Z3.7099 B5.039 A21.938 F1999.99
X.3665 Y1.482 Z3.7152 B4.986 A22.184 F1999.99
X.3635 Y1.4501 Z3.7214 B4.923 A22.472 F1999.99
X.3668 Y1.4199 Z3.726 B4.99 A22.722 F1999.99
X.3699 Y1.3896 Z3.7312 B5.056 A22.972 F1999.99
X.367 Y1.3564 Z3.7379 B4.995 A23.278 F1999.99
X.3646 Y1.3272 Z3.7429 B4.945 A23.524 F1999.99
X.3618 Y1.2951 Z3.7486 B4.886 A23.811 F1999.99
X.3702 Y1.2639 Z3.7528 B5.062 A24.064 F1999.99
X.3679 Y1.2333 Z3.7577 B5.013 A24.329 F1999.99
X.3707 Y1.2017 Z3.7626 B5.075 A24.597 F1999.99
X.3685 Y1.1723 Z3.7673 B5.026 A24.843 F1999.99
X.3708 Y1.1392 Z3.7724 B5.077 A25.134 F1999.99
X.3687 Y1.1084 Z3.7771 B5.03 A25.399 F1999.99
X.3713 Y1.0767 Z3.7815 B5.089 A25.668 F1999.99
X.3688 Y1.0445 Z3.7861 B5.033 A25.955 F1999.99
X.3667 Y1.0149 Z3.7903 B4.988 A26.2 F1999.99
X.3647 Y.984 Z3.7948 B4.943 A26.466 F1999.99
X.3673 Y.9535 Z3.7985 B5.001 A26.714 F1999.99
X.3698 Y.9216 Z3.8025 B5.057 A26.984 F1999.99
X.3674 Y.8893 Z3.8075 B5.004 A27.269 F1999.99
X.3703 Y.86 Z3.8111 B5.069 A27.498 F1999.99
X.3684 Y.8289 Z3.8156 B5.025 A27.764 F1999.99
X.3664 Y.7977 Z3.8198 B4.982 A28.03 F1999.99
X.3693 Y.7699 Z3.823 B5.045 A28.238 F1999.99
X.367 Y.7359 Z3.828 B4.995 A28.544 F1999.99
X.3656 Y.7089 Z3.8313 B4.961 A28.749 F1999.99
X.3679 Y.6768 Z3.8351 B5.015 A29.018 F1999.99
X.3661 Y.6471 Z3.8386 B4.974 A29.262 F1999.99
X.3688 Y.6176 Z3.8415 B5.034 A29.493 F1999.99
X.3669 Y.5879 Z3.8452 B4.994 A29.736 F1999.99
X.3653 Y.5565 Z3.849 B4.954 A30.003 F1999.99
X.3678 Y.527 Z3.852 B5.013 A30.233 F1999.99
X.3661 Y.4956 Z3.8554 B4.974 A30.499 F1999.99
X.3686 Y.466 Z3.858 B5.032 A30.73 F1999.99
X.367 Y.4362 Z3.8609 B4.993 A30.973 F1999.99
X.3693 Y.4082 Z3.8631 B5.05 A31.18 F1999.99
X.3678 Y.3752 Z3.8657 B5.012 A31.471 F1999.99
X.37 Y.3456 Z3.8673 B5.068 A31.702 F1999.99
X.3688 Y.3183 Z3.8692 B5.037 A31.905 F1999.99
X.3672 Y.2868 Z3.8713 B5. A32.172 F1999.99
X.366 Y.2595 Z3.8724 B4.97 A32.375 F1999.99
X.3683 Y.2299 Z3.8731 B5.025 A32.606 F1999.99
X.3671 Y.201 Z3.8741 B4.995 A32.834 F1999.99
X.369 Y.1705 Z3.8747 B5.042 A33.079 F1999.99
X.3678 Y.1415 Z3.8754 B5.013 A33.307 F1999.99
X.3699 Y.1119 Z3.8757 B5.067 A33.539 F1999.99
X.3687 Y.0828 Z3.876 B5.038 A33.767 F1999.99
X.3676 Y.0538 Z3.8763 B5.009 A33.995 F1999.99
X.3697 Y.0242 Z3.8762 B5.062 A34.227 F1999.99
X.3686 Y-.003 Z3.8761 B5.033 A34.43 F1999.99
X.3675 Y-.0303 Z3.8759 B5.005 A34.632 F1999.99
X.3692 Y-.0643 Z3.8749 B5.049 A34.927 F1999.99
X.3683 Y-.0908 Z3.874 B5.028 A35.118 F1999.99
X.3673 Y-.1181 Z3.8727 B5.001 A35.321 F1999.99
X.3662 Y-.1471 Z3.8711 B4.973 A35.549 F1999.99
X.3682 Y-.1768 Z3.8691 B5.024 A35.781 F1999.99
X.3671 Y-.2058 Z3.8665 B4.997 A36.01 F1999.99
X.3661 Y-.233 Z3.8639 B4.97 A36.211 F1999.99
X.3682 Y-.2601 Z3.8608 B5.027 A36.406 F1999.99
X.3673 Y-.2892 Z3.8573 B5. A36.635 F1999.99
X.369 Y-.3188 Z3.8531 B5.049 A36.867 F1999.99
X.3681 Y-.3459 Z3.8491 B5.022 A37.068 F1999.99
X.3671 Y-.3768 Z3.8442 B4.996 A37.324 F1999.99
X.3664 Y-.4016 Z3.8394 B4.976 A37.488 F1999.99
X.3655 Y-.4306 Z3.8341 B4.95 A37.717 F1999.99
X.3674 Y-.4578 Z3.8279 B5.005 A37.913 F1999.99
X.3675 Y-.4576 Z5.0781 F399.95
G0 Z7.5776
X.3672 Y-.4621
B4.999 A37.949
M9
M5
G0 G28 G91 Z0.
M30
Question 1, I'm not to sure about because we have 360 in our B (in my case C)axis.
As for the second question though, I've found adding a force tool change on the paths that your having difficulty with retracts on. What this should do in bring the machine to its highest point in the Z and unwind itself then repostion over the next path. This seems to work for us quite well but I can't be sure if this will help you.
_________________
Derek
6 Seats
MC X2 MR2 Lv3 Lv5
Robotmaster
Solids
Solidworks 07
DLIND,
Welcome to the forum! cheers.gif You're in the right place for the help you need.
Look for these parameters in your post:
 #Primary axis angle description (in machine base terms)
#With nutating (mtype 3-5) the nutating axis must be the XY plane
rotaxis1 = vecy #Zero <=====
rotdir1 = -vecx #Direction <=====
#Secondary axis angle description (in machine base terms)
#With nutating (mtype 3-5) the nutating axis and this plane normal
#are aligned to calculate the secondary angle
rotaxis2 = vecz #Zero <=====
rotdir2 = vecy #Direction <=====
Try changing them to match the rotaxis & rotdir values.
Josh
Josh, playing with those switches in the post is not going to make it, for haas machines who has the title as primary, wont be easy to use modified the generic post for it. cause the post setup to have the rot table as primary axis. i think thomsan knew about it right off the back, and thats why he recommended a custom made post
My modded GenFanuc5X works perfect for my Haas. I thought this was an open forum for info and help to those who needed advice. I truly thought I was helping the guy... apparently not. Not everyone can afford the In House posts so we have to do best with what we've got. From now on I'll stay on the asking side of threads instead of the answering bonk.gif
Sorry to hi-jack, but this problem seem simular to the one that I'm having with a 5ax router...
The C-axis of the machine rotates about the Z from -110 to +290. Initially the limits of the axis in the post was set incorrectly by the manufaturer, correcting this helped, but we still have problems.
Lets say that I'm cutting around a part in a clockwise direction. If I start at 270 and move CW around the whole part (270..180..90..0..-90) I would end up at -90 - staying in the limits. The problem is the post spits out a start position of -90, so with my limits, as the machine moves CW and passes -110 I get a flip.
The Machine Component Manager - Rotary Axis settings seem to have no affect on how programs post, but I could be doing something wrong there.
Is there a way to change the post so that a path is analyzed in order to decide if the coordinate between quadrant 3 and 4 should be -90 or 270?
Hi fourssem.
The Machine Component Manager .
LoL,
you mean the machine definition, No thats just a pretty picture to dazzel your eyes. you can download the new machine definition for x2mr2. they even have a better picture for the hass machines with trunion tables, they included the table solid. in there.But still the post wont follow it .
Starworlds... I think that your talking about the Machine Definition tab that is in the Advanced Multiaxis toolpath manager - I was just looking at that today and can see that it's for some kind of simulation option.
What I was talking about is in;
Settings - Machine Definition Manager - In the bottom left of the window there is a "Machine Configuration" window... If I double click on the "C-axis" line you'll get a "Machine Component Manager - Rotary Axis" Window.
In this window there are a bunch of parameters and limits that can be changed. Is stuff also only for simulations, or should it affect the posting of a file?
-Jake
Josh
I think your on target with your advice, same thing we ran into with your post, which is working.
One thing to add: Think about the order in which post solves angles. I would start by swapping primary/secondary. This will get you closer to what you need. There are some other switches in the post that may need to be changed to affect roll over conditions/allowing secondary into negative numbers.
Jimmy. here is a good simple 5 axis program done in different software..
O2820(RGH TOP HUB)
M43M46
G00G17G40G49G80G90G94G99
G91G28Z0.0M09
G91G28X0.0Y0.0A0.0B0.0M05
N1T01(3/32 X 1.0 MIN 3 FLUTE BALL ENDMILL)
M01
(RGH TOP HUB)
G00G54G90A143.329B86.608
G00G54G90X.1027Y-7.7696S2000.M03
G00G43H01Z-1.9942M08
G40
G01Z-2.4942F5.
X0.Y-7.6984Z-2.4954
X-.0046Y-7.6898Z-2.4492A143.881B86.264
X-.0083Y-7.6816Z-2.4085A144.368B85.961
X-.0118Y-7.673Z-2.3677A144.859B85.655
X-.0143Y-7.6641Z-2.3267A145.355B85.347
X-.0161Y-7.6553Z-2.2853A145.855B85.037
X-.0193Y-7.6367Z-2.2021A146.867B84.412
X-.0217Y-7.6171Z-2.118A147.897B83.779
X-.0254Y-7.5751Z-1.9476A150.005B82.495
X-.0284Y-7.5322Z-1.7875A152.02B81.284
X-.0309Y-7.4886Z-1.6389A153.925B80.156
X-.0329Y-7.4438Z-1.4967A155.791B79.069
X-.0339Y-7.3999Z-1.3649A157.58B78.053
X-.0348Y-7.3536Z-1.2338A159.369B77.038
Y-7.3114Z-1.1202A160.993B76.152
X-.0346Y-7.2675Z-1.0073A162.616B75.265
X-.0341Y-7.2285Z-.912A164.05B74.512
X-.0334Y-7.1883Z-.8173A165.485B73.759
X-.0314Y-7.1172Z-.6594A168.039B72.494
X-.0289Y-7.0425Z-.5032A170.593B71.23
X-.0264Y-6.988Z-.3962A172.495B70.355
X-.0237Y-6.9319Z-.2902A174.396B69.481
X-.0212Y-6.89Z-.2146A175.849B68.854
X-.0186Y-6.8473Z-.1396A177.301B68.226
X-.0144Y-6.7865Z-.0374A179.395B67.366
X-.0107Y-6.7412Z.0356A180.989B66.747
X-.0068Y-6.6951Z.1079A182.583B66.128
X-.0025Y-6.6495Z.1768A184.195B65.536
X0.Y-6.5994Z.2418A185.786B64.972
X-.0098Y-6.6491Z.1465A186.87B65.795
X-.0227Y-6.7158Z.0106A188.364B66.962
X-.0301Y-6.7523Z-.0684A189.202B67.636
X-.0376Y-6.7877Z-.1476A190.04B68.31
X-.0412Y-6.8432Z-.2511A188.723B69.172F10.
X-.0415Y-6.8466Z-.2577A188.64B69.227
X-.0422Y-6.901Z-.3664A187.342B70.127
X-.0427Y-6.9536Z-.476A186.045B71.026
X-.0431Y-7.0045Z-.5865A184.747B71.925
X-.0433Y-7.0535Z-.6978A183.449B72.824
X-.0437Y-7.0995Z-.8085A182.255B73.714
X-.0439Y-7.1438Z-.92A181.061B74.604
X-.0441Y-7.1862Z-1.0321A179.867B75.494
Y-7.2269Z-1.1449A178.674B76.383
X-.0442Y-7.2629Z-1.2512A177.612B77.218
Y-7.2974Z-1.3581A176.551B78.052
X-.0441Y-7.3302Z-1.4655A175.49B78.886
X-.0439Y-7.3615Z-1.5733A174.428B79.72
X-.0437Y-7.3884Z-1.6721A173.495B80.48
X-.0435Y-7.4139Z-1.7712A172.561B81.241
X-.0432Y-7.4382Z-1.8707A171.628B82.001
X-.0429Y-7.461Z-1.9705A170.694B82.762
X-.0426Y-7.4803Z-2.0604A169.875B83.444
X-.0422Y-7.4984Z-2.1505A169.056B84.126
X-.0417Y-7.5155Z-2.2408A168.237B84.809
X-.0413Y-7.5315Z-2.3314A167.418B85.491
X-.0403Y-7.5573Z-2.4938A165.972B86.711
X-.0391Y-7.5796Z-2.6568A164.526B87.931
X-.0378Y-7.596Z-2.7991A163.274B88.992
X-.0365Y-7.6097Z-2.9417A162.023B90.053
X-.0358Y-7.62Z-3.0633A160.96B90.955
X-.0355Y-7.627Z-3.1741A159.992B91.775
X-.0354Y-7.6325Z-3.2743A159.118B92.515
X-.0355Y-7.6368Z-3.3739A158.249B93.249
X-.0361Y-7.6393Z-3.4628A157.472B93.904
X-.0368Y-7.6412Z-3.551A156.701B94.552
X-.0377Y-7.6417Z-3.6287A156.019B95.124
X-.0386Y-7.641Z-3.696A155.427B95.619
X-.0396Y-7.6405Z-3.7629A154.837B96.11
X-.041Y-7.6396Z-3.8293A154.252B96.597
X-.0438Y-7.6345Z-3.9503A153.174B97.488
X-.0467Y-7.6302Z-4.0511A152.272B98.229
X-.0498Y-7.6249Z-4.1412A151.46B98.891
X-.0528Y-7.6182Z-4.2207A150.737B99.479
X-.0554Y-7.6142Z-4.282A150.179B99.929
X-.0582Y-7.6083Z-4.3423A149.625B100.374
X-.0605Y-7.6008Z-4.3929A149.154B100.751
X-.0648Y-7.5937Z-4.4768A148.375B101.371
X-.0682Y-7.5826Z-4.5423A147.758B101.858
X-.0694Y-7.5791Z-4.5665A147.529B102.038
X-.0727Y-7.5643Z-4.6536A146.693B102.692
X-.0772Y-7.554Z-4.7389A145.868B103.331
X-.1036Y-7.6762Z-4.7378
G01Z-4.2378F120.
G00Z5.
G91G28Z0.0M09
M30
Here is the same goemtry iges out to mastercam and done in mastercam
O0001(PROGRAM - 282016_ROTOR_COMPRESSOER_MAZAK5AXIS )
(DATE - 27-11-07 TIME - 14:03 )
G20
G0G17G40G80G90G94G98
G0G28G91Z0.
G0G28X0.Y0.
N2T2M6( 1/8 CENTERDRILL TOOL - 2 DIA. OFF. - 2 LEN. - 2 DIA. - .125 )
M01
(RGH TOP PART OF THE HUB )
G0G55G90X-.0357Y-7.6842A95.097B82.696S2500M3
G43H2Z3.1803M8
Z1.307
G1Z1.1803F100.
X-.0361Y-7.6824Z1.1871A95.046B82.646F10.
X-.039Y-7.6697Z1.2343A94.686B82.3
X-.0418Y-7.6567Z1.2813A94.323B81.951
X-.0446Y-7.6433Z1.3281A93.957B81.601
X-.0474Y-7.6297Z1.3746A93.587B81.249
X-.0502Y-7.6157Z1.4208A93.214B80.895
X-.053Y-7.6014Z1.4669A92.837B80.54
X-.0558Y-7.5868Z1.513A92.457B80.184
X-.0586Y-7.5719Z1.5591A92.072B79.827
X-.0613Y-7.5566Z1.6053A91.683B79.467
X-.0641Y-7.5409Z1.6516A91.291B79.106
X-.0668Y-7.5249Z1.698A90.895B78.743
X-.0696Y-7.5085Z1.7446A90.495B78.377
X-.0723Y-7.4917Z1.7914A90.093B78.008
X-.075Y-7.4744Z1.8385A89.688B77.637
X-.0777Y-7.4568Z1.8855A89.277B77.264
X-.0804Y-7.4389Z1.9324A88.858B76.892
X-.083Y-7.4207Z1.9789A88.432B76.521
X-.0856Y-7.4023Z2.0251A88.B76.153
X-.0882Y-7.3836Z2.0708A87.561B75.787
X-.0907Y-7.3647Z2.116A87.117B75.425
X-.0932Y-7.3457Z2.1607A86.668B75.066
X-.0957Y-7.3264Z2.2052A86.219B74.709
X-.0981Y-7.3068Z2.2497A85.772B74.351
X-.1005Y-7.2869Z2.2942A85.327B73.992
X-.103Y-7.2667Z2.3386A84.882B73.633
X-.1053Y-7.2461Z2.3828A84.436B73.275
X-.1077Y-7.2254Z2.4269A83.991B72.916
X-.11Y-7.2043Z2.4707A83.544B72.558
X-.1123Y-7.183Z2.5143A83.095B72.201
X-.1146Y-7.1614Z2.5579A82.645B71.843
X-.1165Y-7.1426Z2.5951A82.258B71.535
X-.1184Y-7.1234Z2.6326A81.872B71.226
X-.1203Y-7.104Z2.6702A81.484B70.914
X-.1222Y-7.0842Z2.7079A81.097B70.599
X-.1241Y-7.064Z2.7459A80.71B70.281
X-.1259Y-7.0434Z2.7844A80.323B69.96
X-.1277Y-7.0224Z2.8229A79.933B69.636
X-.1295Y-7.0012Z2.8613A79.54B69.313
X-.1312Y-6.9798Z2.8996A79.143B68.989
X-.1329Y-6.9581Z2.938A78.744B68.664
X-.1346Y-6.9361Z2.9761A78.341B68.339
X-.1362Y-6.9139Z3.0142A77.934B68.014
X-.1378Y-6.8914Z3.0523A77.525B67.688
X-.1393Y-6.8686Z3.0904A77.111B67.362
X-.1408Y-6.8458Z3.1279A76.693B67.038
X-.1422Y-6.8229Z3.165A76.271B66.718
X-.1436Y-6.8Z3.2015A75.843B66.401
X-.145Y-6.7771Z3.2375A75.411B66.089
X-.1463Y-6.7542Z3.2727A74.973B65.781
X-.1475Y-6.7315Z3.3072A74.531B65.479
X-.1487Y-6.7089Z3.341A74.085B65.183
X-.1498Y-6.6865Z3.3739A73.634B64.893
X-.1509Y-6.6643Z3.4061A73.181B64.608
X-.152Y-6.642Z3.4379A72.725B64.327
X-.1531Y-6.6197Z3.4692A72.268B64.048
X-.1541Y-6.5974Z3.5001A71.809B63.773
X-.1551Y-6.5751Z3.5306A71.349B63.5
X-.156Y-6.5528Z3.5607A70.887B63.23
X-.1569Y-6.5306Z3.5903A70.423B62.964
X-.1578Y-6.5083Z3.6196A69.958B62.7
X-.1587Y-6.4858Z3.649A69.496B62.435
X-.1595Y-6.4628Z3.6789A69.042B62.164
X-.1604Y-6.4392Z3.7093A68.595B61.888
X-.1612Y-6.4151Z3.7405A68.154B61.605
X-.162Y-6.3904Z3.7723A67.717B61.315
X-.1628Y-6.3651Z3.8048A67.285B61.018
X-.1635Y-6.339Z3.8382A66.855B60.713
X-.1642Y-6.3123Z3.8722A66.428B60.4
Z3.9722F100.
G0Z5.8722
M9
M5
G0G28G91Z0.
G0G28X0.Y0.
G28A0.B0.
M30
it absolutley backward.
it is mazak machine. Koma trunion table.
B TILTE PRIMARY. 0-90 TOWARD THE OPERATOR
A ROT. 0-360
i tried everything so far switching primary/seconday. no such luck. if you have a machine simulation take the codes and simulate them if possible. but anyhow can u correct this problem.?
Hi jimmy. here is the koma table configurations,
MACHINE:
name "Mazak FJV-25 with Koma TS 210 Tilting Rotary Table, units INCH
xyz absolute tip
chord 0.0001
simultaneous
synchronous
precision 0.001
PART:
machine
TOOL:
origin 0.0 0.0 0.0
orient Z
PRIMARY:
variable $B
axis table X
zero Z
ninety -Y
pivot 0.0 .00225 -3.15385
align 0.0
limit -1.0 115.0
abc absolute unsigned
SECONDARY:
variable $A
axis table Z
zero Y
ninety X
pivot 0.0 0.0 0.0
align 0.0
initang 0.0
abc absolute signed accumulate
Oh, here so far what i change in mastercam post.
pang_output : 0 #Angle output options, primary
sang_output : 0 #Angle output options, secondary
#0 = Normal angle output
#1 = Signed absolute output, 0 - 360
#2 = Implied shortest direction absolute output, 0 - 360
#Machine rotary routine settings
mtype : 0 #Machine type (Define base and rotation plane below)
#0 = Table/Table
#1 = Tilt Head/Table
#2 = Head/Head
#3 = Nutator Table/Table
#4 = Nutator Tilt Head/Table
#5 = Nutator Head/Head
# 5 Axis Rotary Settings
#Assign axis address
str_pri_axis "A"
str_sec_axis "B"
str_dum_axis "C"
#Toolplane mapped to top angle position strings
str_n_a_axis "A"
str_n_b_axis "B"
str_n_c_axis "C"
rotaxis1$ = vecy #Zero
rotdir1$ = vecx #Direction
rotaxis2$ = vecz #Zero
rotdir2$ = vecy #Direction
#Rotary axis travel limits, always in terms of normal angle output
#Set the absolute angles for axis travel on primary
pri_limlo$ : -360
pri_limhi$ : 360
#Set intermediate angle, in limits, for post to reposition machine
pri_intlo$ : -360
pri_inthi$ : 360
#Set the absolute angles for axis travel on secondary
sec_limlo$ : 0
sec_limhi$ : 90
sec_intlo$ : 0
sec_inthi$ : 90
#Machine base matrix (Base matrix to map positions into)
matb1$ : 1
matb2$ : 0
matb3$ : 0
matb4$ : 0
matb5$ : 1
matb6$ : 0
matb7$ : 0
matb8$ : 0
matb9$ : 1
pri-(assuming axis rotates about x)
axis table X
zero Z
ninety -Y
would be:
rotaxis1 : vecz
rotdir1 : -vecy
sec-(assuming axis rotates about z)
axis table Z
zero Y
ninety X
would be:
rotaxis2 : vecy
rotdir2 : vecx
You can switch sign by swapping axis/dir. There are quite a few combinations that are "close" but only one that is right.
I noticed axis shifts in your info, Is the machine offseting to comp for this? (TCP)
here is the changes i made. to the post, now i got two error and not complete posting.
str_pri_axis "B"
str_sec_axis "A"
str_dum_axis "C"
str_n_a_axis "B"
str_n_b_axis "A"
str_n_c_axis "C"
rotaxis1$ = vecz (vecy) #Zero
rotdir1$ = -vecy (vecx) #Direction
rotaxis2$ = vecy(vecz) #Zero
rotdir2$ = vecx(vecy) #Direction
pri_limlo$ : 0
pri_limhi$ : 90
pri_intlo$ : 0
pri_inthi$ : 90
sec_limlo$ : -360
sec_limhi$ : 360
sec_intlo$ : -360
sec_inthi$ : 360
and the two errors i got
ERROR-SETUP FOR PRIMARY OR SECONDARY AXIS IS ILLEGAL
ERROR-THE TOOL CAN NOT BE POSITION WITHIN MACHINE ROTARY LIMITS
and the gcode comes
:0001 ( PROGRAM - 282016_ROTOR_COMPRESSOER_MAZAK5AXIS )
( DATE - 28-11-07 TIME - 13:22 )
G20
G0 G28 G91 Z0.
G0 G28 X0. Y0.
( 1/8 BALLENDMMILL TOOL - 2 DIA. OFF. - 2 LEN. - 2 DIA. - .125 )
( RGH TOP PART OF THE HUB )
T2 M6
G0 G55 G90 X2.1846 Y.0979 B90. A0. S2500 M3
G43 H2 Z-7.8755 M8
Z-7.7409
X.2904 Y.0348
G1 X.1908 Y.0315 Z-7.7339 F100.
X.1909 Y.0309 Z-7.7331 F10.
X.1918 Y.0269 Z-7.7276
X.1926 Y.0228 Z-7.7222
X.1932 Y.0188 Z-7.7167
X.194 Y.0147 Z-7.7113
X.1946 Y-.0106 Z7.7059 B-90.
x-y position now way out. we swaped the seats of the primary and seconday in the post.
