UNDERCUT-COMPOUND ANGLE
HEAVY METAL
I HAVE UPLOADED A MC8 FILE TO THE FTP SITE CALLED UNDERCUT .I CANT GET A CORRECT TOOL PATH ON THE UNDERCUT SURFACE.I AM USING A FACE (SANDIVIK) MILL WITH 1/2 ROUND INSERTS. THE SHANK IS RELIEVED ENOUGH TO CLEAR TOP AS CUTTER NEARS BOTTOM.MAY BE I AM DESCRIBING TOOL WRONG.IT WOULD BE GREAT IF SOME ONE COULD TAKE A LOOK AT IT.I WAS TOLD BY A MC SALES REP THAT YOU CANT MACHINE THIS TYPE OF CUT BECAUSE MC DOES NOT SEE PAST 90 DEG ON THE CUTTER
I cant get to the ftp due to firewall issues but if your surface cutting tell it exactly the cutter you
are using .We have already found out we can cut undercuts,MC cant see past 90 degrees on a regular
endmill,but as cutter geo. changes so does mastercams abilities.
You can sometimes surface undercuts by turning gouge checking off. Some surfacing toolpaths
do not have that option (contour for example)
and will not do undercuts.
Last week I hade to machine a spherical radis
in a large eyebolt. I used a relieved cutter
with 3/4 round inserts. I could not get a satisfactory tool path using surfacing methods.
I ended up drawing 60 circles stepping down .03
each time and running a 2D contour around them.
In another instance I had to machine a relief
groove around the bottom of a large die using a
5 in saw with .125 corner radi top and bottom.
Cadcam from this forum helped me with this one.
The original model was a parasolid converted from a iges file. The undercut surfaces were made up of 12 solid sheet surfaces. MC would not surface them. Cadcam created 1 sweep surface from the solid's wireframe turned gouge check off and MC put an undercut tool path on them using flowline.
The tool path was not accurate though. MC comped the tool path to the theorical sharp corner of the saw. I was using a custom tool which back- plotted correctly, but MC could not see the radius on the top edge of the saw.
Lucky for me it was just a relief groove. I offset the swept surface and the results were "good enough" rolleyes.gif
Had an accurate surface been required, I'd have been in real trouble.
thanks jay,
I gotta admit maybe i would do this wrong but because of the sharp corner I would rough and
finish most of the way down with a 3" sandvik type cutter with 1/2 inserts, use the slot mill
as tool type,this looks like the best type given the info posted,then i would get or have a 10 degree backdraft cutter made to pick out the bottom but it would almost need to be at least 2 inch diameter
and use a 2 D countour for that.But definetly surface the first cutter.Any one agree this could work? smile.gif
I like to be sure my cutter is completely off the part if so when it z axis plunges it isnt into solid steel,
better safe than sorry,also I like to know it will remove all the material with out leaving an edge..#2you can change the cut to cut one way climb.
[ 06-03-2002, 09:43 AM: Message edited by: mold100 ]
