Bad trim surface
jagg2499
I am using X3 and i am trying to do a waterline hsm cut on a solid and i am getting and error that says .....Bad trim surface found --use analyze test surfaces/check model to find others .... but when i go to analyze , test surfaces and solids, check models it tells me no errors found any help on how to fix this would be great
i get this once on a while.
My solution is to convert it to surfaces.
If you still get the warning, it asks if you would like to change the color of the bad surface. Choose yes. then select it by color and see what it looks like. For me it is always so small that I just delete it. You may have to do this a few times.
And if anyone has a better idea, then I would love to hear it also.
i am trying to recreate the surface i need and it is basically a flat surface with a bunch of .08 slots trimmed out of it but the surface wont trim out right it cuts off big sections of the surface any suggestions would be great or if someone has time to take a look at it for me i would appreciate it
