Problems with angular head
Bjarne_M
Hi I am new to the forum here
We have purchased a new machine FRAL400 a milling machine, that we have problem with the angle head..
Control we use is simens840D
and we use Mastercam X3
I have an X-axis 22000mm on the y-axis 5000mm
We have a problem with our angle head, angle head has a C axis that rotates
360 degrees, when we work in the 0 degrees stays the milling head vertical down,Then we can use this
program to mill the contour
N10 LOAD_TABR
N20 T="390125FRES"
N30 L06
N40 G17 G54 G64 G90
N50 Z1700
N50 TOOL_HOLDER(0,0)
N60 TOROT
N70 G54
N80 F5000
N90 S500 M03
N100 G0 Z1925
N110 G0 Y60.5 X-80.208
N120 G0 Z1720
N130 G1 Z1700
N140 G1 X-42.708
N150 G1 X372.5
N160 G1 Y-60.5
N170 G1 X-42.708
N180 G1 X-80.208
N190 G0 Z1925
N200 M5
N210 ROT
N220 M0
but when we turn our head 45 degrees, we must replace the x axis with the y axis
so then we must create new programs to the next angle
though the contour is the same
then we have to program like this
N230 TOOL_HOLDER(45,0)
N240 TOROT
N250 G54
N260 F1000
N270 S500 M03
N280 G0 Z1925
N290 G0 X60.5 Y-80.208
N300 S500 M03
N310 G0 Z1720
N320 G1 Z1700
N330 G1 Y-42.708
N340 G1 Y372.5
N350 G1 X-60.5
N360 G1 Y-42.708
N370 G1 Y-80.208
N380 G0 Z1925
N390 G0 Y-200
N400 ROT
N410 M5
but when we post out, the mastercam X3 using the same contour on all axes
like this
N10 LOAD_TABR
N20 T="390125FRES"
N30 L06
N40 G17 G54 G64 G90
N50 Z1700
N60 TOROT
N70 G54
N80 F5000
N90 S500 M03
N100 G0 Z1925
N110 G0 X60.5 Y-80.208
N120 G0 Z1720
N130 G1 Z1700
N140 G1 Y-42.708
N150 G1 Y372.5
N160 G1 X-60.5
N170 G1 Y-42.708
N180 G1 Y-80.208
N190 G0 Z1925
N200 M5
N210 ROT
N220 M0
N240 TOROT
N250 G54
N260 F5000
N270 S500 M03
N280 G0 Z1925
N300 G0 Z1720
N310 G1 Z1700
N320 G1 Y-42.708
N330 G1 Y372.5
N340 G1 X-60.5
N350 G1 Y-42.708
N360 G1 Y-80.208
N370 G0 Z1925
N380 M5
N390 ROT
N400 M0
N410 M2
CONTOUR
GEARBOX
Does anyone have experience with an angle head,
or been in the same situation that can help me with this ?
Thanks for all posts
i dont have any angle head exp. but
do you have your planes set right?
machine def set correctly for the angle head?
post setup for angle head?
you have multi axis on MC?
hopefully that helps get ya in the right direction if not looks like a fun toy to play with anyway
Bjarne,
That is a very cool machine!!
Mastercam has a feature called aggregate head
that can handle what you are trying to do.
If you are new to Mastercam, you are probably going to need some help from your dealer to
get a post procceessor set up.
I agree with Gcode......we have a DMU50 and had to get a new post for it....once you index the head.....probably "B" axis your X & Y axis' flip......we had a problem in the beginning but got a fairly decent post (still in the final touch ups) from in-house.......Maybe they even have an already configured post for ya....have your re-seller contact them....
Good luck.....
BTW.....welcome to the forum
I used to work for a MC reseller and I once made a post for a mill aggregate head we just used a router post, MD, CD, All I did was change (one number) in the heading of the post pocessor and it became a mill. I can't remember witch one it was. You can compare the posts beside each other and see. It was a one (1) or a (0) should be only one number difference between then. There should be a generic fanuc router post with and aggregate head in your install. The aggregate head is common in routers.
From there you might need a little help using it.
This part is a gearbox for a winch.
this is a horz machine, which we can unload and Load 7 different various accessories.
And have a tool magazine whit 170 seats.
We have one who has made a post processor for us
but he says that there must be something wrong with the parameters of the angular head.
it changes -X to +X when we go from milling to drilling when we use the same angels
We can change the post, so it's right
but we want that we can program this manually to,
as we were told when we had 1 day training on the machine, and the manu was that we should just write Tool_Holder (0,0) and our angles, and then should it change X,Y,Z by itself
We have contacted the seller, but is pretty poor service from them.
We have 2 different angle heads 1 with C axis, and 1 with a C and A axis "Tool_holder(C,A)"
only C axis
C and A axis
