peck tapping
Go Navy
Guru i just finished grinding the .125 3flt.
i'm running it at 8000 at 9.37 ipm 2pass. pitch is set at .01785714 nice threads and no worries on seven parts with 26 holes each.
now i'm going to get the 0,1,2,3,4 to fill out my single form collection. then i'll have all of them 0 to .75
Last year Harvey only went down as small as #3 single-form thread mills AFAIK, now they are down to #0.
00-90 is common for us. Still waiting...Harvey..How about a .3mm Thd mill??
The single form threadmills might not be one-pass capable, but they sure are nice to have. We just turned over two jobs, one 10-56 and the other 1/4-32.
Sure is nice to not have to wait for special order form taps.
We are allowed 1 1/2 thds from full thd depth on blind holes all the time. The SMA connectors that screw into these parts usually have to bottom out.
We try not to relieve the bottom thread if we don't have to, but sometimes that's the only way to get a thread depth gage to bottom out.
Our problem is we have to guess at a class 4 to a class 11 fit for pre-plate, then prey we didn't under shoot the pitch dia. LOL
We'll know when they come back from the platers.
H4, - H11 Gages for odd threads on 2 1/2 weeks notice is not going to happen anytime soon, so we have to gage by an H2 or H3, then trust the comp, and our feel, then double check with a "Home-made" gage.
I turn gages for myself all the time, but the owners won't trust them, yet won't buy a ground certified gage.
I guess the owner doesn't understand the three wire method of gaging P.D.
Oh well. DIYD-DIYD.
Can't anything ever be easy????
After looking at this thread, to find JP's peck tapping cycle, I found a need to change a few things
to get my ptap$ and ptap2$ postblocks using a peck or no peck.
Custom drill cycles were avoided since I have only a couple left and would like to reserve them
for future use.
Hint: One of them will be a Broaching cycle
I'll post my mods, so someone may learn or benefit:
Anyways here's what I did:
# Mastercamguru additional debug output
bug_tap_1 : 0
bug_tap_2 : 0
# Some new stuff to initialize
fmt 4 count # timing counter #Peck TAP CYCLE
fmt 4 peck_cnt # remaining no. of pecks #Peck TAP CYCLE
fmt 4 numpeck # No. of pecks #Peck TAP CYCLE
fmt 4 pass # pass counter use to calculate depths #Peck TAP CYCLE
fmt Z 2 sub_depth # subsequent depths #Peck TAP CYCLE
fmt Z 2 calc_depth # The total caculated cutting depth #Peck TAP CYCLE
fmt Z 2 calc_peck # the calculated peck amount #Peck TAP CYCLE
fmt Z 2 strt_depth # the first tap depth #Peck TAP CYCLE
fmt Z 2 initial_calc # first peck #Peck TAP CYCLE
# Tapping Cycle - First Point G84/74 call
ptap$ #Canned Tap Cycle
pdrlcommonb
#RH/LH based on spindle direction
numpeck = peck2$
peck_cnt = numpeck
initial_calc = (depth$ - tosz$) / peck_cnt
strt_depth = (tosz$ + initial_calc)
calc_depth = (depth$ - tosz$)
calc_peck = calc_depth / numpeck
if use_pitch, pbld, n$, "G93", e$
if use_pitch = 0,
if numpeck <= 1,
pcan1, pbld, n$, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout,
prdrlout, *feed, strcantext, e$
if numpeck > 1,
pcan1, pbld, n$, *sgdrlref, *sgdrill, pdrlxy, *strt_depth, pcout,
# ----------------------Debugging Block
if bug_tap_1,
"numpeck=", ~numpeck, e$
"peck_cnt=", ~peck_cnt, e$
"initial_calc=", ~initial_calc, e$
"strt_depth=", ~strt_depth, e$
"calc_depth=", ~calc_depth, e$
"calc_peck=", ~calc_peck, e$
count = peck_cnt - 1
pass = 1
while count > 0,
if bug_tap_2,
"count=", ~count, e$
"pass=", ~pass, e$
"sub_depth=", ~sub_depth, e$
sub_depth = strt_depth + (calc_peck * pass)
pbld, n$, *sub_depth, e$
pass = pass + 1
count = count - 1
else,
if numpeck <= 1,
if met_tool$, pitch = n_tap_thds$ # Tap pitch (mm per thread)
else, pitch = 1/n_tap_thds$ # Tap pitch (inches per thread)
prdrlout, *pitch, !feed, strcantext, e$
if numpeck > 1,
if bug_tap_1,
pass = 1
while count > 0,
if bug_tap_2,
"pass=", ~pass, e$
pass = pass + 1
count = count - 1
pcom_movea
tapflg = 1
# Tapping Cycle - Additional Points
ptap_2$ #Canned Tap Cycle
if numpeck <= 1,
pdrill_2$
if numpeck > 1,
pdrlcommonb
pcan1, pbld, n$, pdrlxy, *strt_depth, pcout, prdrlout, e$
if bug_tap_1,
pass = 1
while count > 0,
if bug_tap_2,
"pass=", ~pass, e$
pass = pass + 1
count = count - 1
pcom_movea
And some CTRL stuff:
[tap]
1. "G84/G74 - Tap"
3. ""
7. ""
8. "# of pecks"
9. ""
10. ""
11. ""
This is how it posts.
M1
(TAP 2-56 THRU)
T5 M6 ( 2-56 GUN TAP)
(MIN - Z-.36)
G0 G90 G54 X.22 Y-.335 S1100 M8
G91 G43 H5 Z0. M3
G92 Z.05 M8
G90
G93
G98 G84 Z-.09 R.01 F.0179
Z-.18
Z-.27
Z-.36
X.935 Z-.09
Z-.18
Z-.27
Z-.36
X1.127 Y-.36 Z-.09
Z-.18
Z-.27
Z-.36
X1.607 Z-.09
Z-.18
Z-.27
Z-.36
G80
G94
M9
G91 G28 Z0 M19
[ 06-17-2009, 12:18 PM: Message edited by: Mastercam Guru ]
  • 8 years later...
for future use.
bug_tap_1 : 0
bug_tap_2 : 0
pdrlcommonb
numpeck = peck2$
peck_cnt = numpeck
if use_pitch = 0,
if numpeck <= 1,
if numpeck > 1,
if bug_tap_1,
pass = 1
while count > 0,
if bug_tap_2,
"pass=", ~pass, e$
pass = pass + 1
count = count - 1
else,
if numpeck <= 1,
if numpeck > 1,
if bug_tap_1,
pass = 1
while count > 0,
if bug_tap_2,
"pass=", ~pass, e$
pass = pass + 1
count = count - 1
pcom_movea
tapflg = 1
if numpeck <= 1,
pdrill_2$
if numpeck > 1,
pdrlcommonb
if bug_tap_1,
pass = 1
while count > 0,
if bug_tap_2,
"pass=", ~pass, e$
pass = pass + 1
count = count - 1
pcom_movea
[tap]
1. "G84/G74 - Tap"
3. ""
7. ""
8. "# of pecks"
9. ""
10. ""
11. ""
M1
(TAP 2-56 THRU)
(MIN - Z-.36)
G91 G43 H5 Z0. M3
G92 Z.05 M8
G90
G93
Z-.18
Z-.27
Z-.36
X.935 Z-.09
Z-.18
Z-.27
Z-.36
X1.127 Y-.36 Z-.09
Z-.18
Z-.27
Z-.36
X1.607 Z-.09
Z-.18
Z-.27
Z-.36
G80
G94
M9
G91 G28 Z0 M19
I'm trying to add this to my post but i'm not getting very far.
PST LINE (1591) - The formula/boolean failed (general message), , Label has not been defined[4]
19 Jul 2017 02:53:51 PM - PST LINE (1591) - The formula/boolean failed (general message), The formula/boolean does not terminate properly
19 Jul 2017 02:53:51 PM - PST LINE (1593) - The formula/boolean failed (general message), , Label has not been defined[4]
19 Jul 2017 02:53:51 PM - PST LINE (1583) - Duplicate post block declaration, , Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1593) - The variable/string declaration is a duplicate, The formula/boolean does not terminate properly, , Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1594) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1595) - The variable/string declaration is a duplicate, , Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1596) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1597) - Unrecognized characters after declaration, , Illegal character(s) encountered
19 Jul 2017 02:53:51 PM - PST LINE (1598) - Unrecognized characters after declaration, , Illegal character(s) encountered
19 Jul 2017 02:53:51 PM - PST LINE (1599) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1600) - The variable/string declaration is a duplicate, , Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1601) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1606) - The formula/boolean failed (general message), , Label has not been defined[4]
19 Jul 2017 02:53:51 PM - PST LINE (1602) - Duplicate post block declaration, Unrecognized characters after declaration, , Illegal character(s) encountered, Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1603) - Duplicate post block declaration, Unrecognized characters after declaration, , Illegal character(s) encountered, Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1606) - The variable/string declaration is a duplicate, The formula/boolean does not terminate properly, , Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1607) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1608) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1609) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1610) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1611) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1612) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1613) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1614) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1622) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1625) - The formula/boolean failed (general message), , Label has not been defined[4]
19 Jul 2017 02:53:51 PM - PST LINE (1625) - The variable/string declaration is a duplicate, The formula/boolean does not terminate properly, , Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1626) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1627) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1628) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1629) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1630) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1635) - Unrecognized characters after declaration, , Illegal character(s) encountered
19 Jul 2017 02:53:51 PM - PST LINE (1636) - The variable/string declaration is a duplicate, , Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1637) - The variable/string declaration is a duplicate, , Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1638) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1639) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1640) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1641) - The formula/boolean failed (general message), , Illegal character(s) encountered
19 Jul 2017 02:53:51 PM - PST LINE (1642) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1643) - The variable/string declaration is a duplicate, , Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1644) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1645) - The variable/string declaration is a duplicate, , Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1646) - The variable/string declaration is a duplicate, , Illegal character(s) encountered, Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1647) - Duplicate post block declaration, Unrecognized characters after declaration, , Illegal character(s) encountered, Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1648) - Duplicate post block declaration, Unrecognized characters after declaration, , Illegal character(s) encountered, Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1649) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1650) - The variable/string declaration is a duplicate, , Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1651) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1658) - The formula/boolean failed (general message), , Label has not been defined[4]
19 Jul 2017 02:53:51 PM - PST LINE (1652) - The variable/string declaration is a duplicate, , Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1653) - The variable/string declaration is a duplicate, , Illegal character(s) encountered, Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1654) - Duplicate post block declaration, Unrecognized characters after declaration, , Illegal character(s) encountered, Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1655) - Duplicate post block declaration, Unrecognized characters after declaration, , Illegal character(s) encountered, Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1658) - The variable/string declaration is a duplicate, The formula/boolean does not terminate properly, , Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1659) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1660) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1661) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1662) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1663) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1664) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1665) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1666) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1670) - The variable/string declaration is a duplicate, , Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1671) - The variable/string declaration is a duplicate, , Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1672) - The variable/string declaration is a duplicate, , Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1673) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1676) - The formula/boolean failed (general message), , Label has not been defined[4]
19 Jul 2017 02:53:51 PM - PST LINE (1676) - The variable/string declaration is a duplicate, The formula/boolean does not terminate properly, , Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1677) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1678) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1679) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1680) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1681) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1685) - The variable/string declaration is a duplicate, , Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1686) - Duplicate post block declaration, Unrecognized characters after declaration, , Illegal character(s) encountered, Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1687) - The variable/string declaration is a duplicate, , Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1688) - The variable/string declaration is a duplicate, , Duplicate assignment of label
19 Jul 2017 02:53:51 PM - PST LINE (1689) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1690) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1691) - Undocumented item type error message --> -1
19 Jul 2017 02:53:51 PM - PST LINE (1587) - The formula is attempting to divide by zero, , Calculation returned zero
19 Jul 2017 02:53:51 PM - PST LINE (1588) - The formula is attempting to divide by zero, , Calculation returned zero
19 Jul 2017 02:53:51 PM - PST LINE (1589) - The formula is attempting to divide by zero, , Calculation returned zero
19 Jul 2017 02:53:51 PM - PST LINE (1590) - The formula is attempting to divide by zero, , Calculation returned zero
19 Jul 2017 02:53:51 PM - PST LINE (1591) - The math calculation/formula has an error , The formula is attempting to divide by zero, , Calculation returned zero
19 Jul 2017 02:53:51 PM - PST LINE (1618) - The math calculation/formula has an error , The formula is attempting to divide by zero, , Calculation returned zero
19 Jul 2017 02:53:51 PM - PST LINE (1619) - The math calculation/formula has an error , The formula is attempting to divide by zero, , Calculation returned zero
19 Jul 2017 02:53:51 PM - PST LINE (1621) - The math calculation/formula has an error , The formula is attempting to divide by zero, , Calculation returned zero
19 Jul 2017 02:53:51 PM - PST LINE (1634) - The math calculation/formula has an error , The formula is attempting to divide by zero, , Calculation returned zero
19 Jul 2017 02:53:51 PM - PST LINE (1641) - The math calculation/formula has an error , The formula is attempting to divide by zero, , Calculation returned zero
19 Jul 2017 02:53:51 PM - PST LINE (1693) - The math calculation/formula has an error , The formula is attempting to divide by zero, , Calculation returned zero
19 Jul 2017 02:53:51 PM - PST LINE (1692) - Duplicate post block declaration, , Duplicate assignment of label
Anything that could steer me in the right direction? I'm new to working with PP's. I've looked around but haven't come up with anything yet.
