Flatness Issue
Having some issues trying to keep decent flatness on 42 inch long plates 3.75 to 6.25 wide. Start at 7/8 thick and finish at .770 for grind. Have tried a variety of different feeds and speeds and cut depths. Using a 2" Shear hog from AB Tools 5000 rpm's @ 50 . ipm w/1.6 wide cut as starting point. These cutters I have found are great for aluminum. This is the second cutter we tried the last one was a Mitsubishi and it was worse.
The 3.75 wide plates came out pretty good but the next set at 5.75 bowed about .01 to .020. I am standing the plates up skimming one edge. Down into milled aluminum jaws skim face about .020 deep walk around leaving +.100 on outside. Flip mill off about .060. Parts then go back in skim to clean, finish outside contour, drill some .25 and .406 holes. Flip and mill in to finish thickness. Would like to try and be at least around .005. This is the second go around with these parts. The last time I flipped multiple times and eventually got to .005 to .007. We have probably have about 10 more assemblies to do at 4 to 6 plates per. I would like to not be milling these forever. Any input would be appreciated.
Brian
Whenever I have stress-relief problems with aluminum I either: 1)take some stock off both sides and then let them "rest" for [24] hours or so to stress relieve at room temperature (this sounds dumb but was a suggestion of our metallurgist and works mint) or 2) cook them at 275F for [6] hours and then let sit overnight. We have experienced success with both of these methods but usually just rip some stock off and let them sit.
C
Thanks guys. Chris I will try the let them rest. Can't send them out for stress as this adds an operation and would need to go through the customer for added process. I never tap down till the final op to hold thickness dimension. I am doing the multiple flips. Had some success going to one way and smaller steps. Last set had 4 under .005 1 at .008 and 2 at .015.
You may not be beating the part down as you flip, but are you using your hand to push the part down as you tighten the vises?
The key is that you want ZERO down pressure as you are skimming and flipping.
Tooling plate may be another option if it's in the budget.
some times i have better luck..i mean skill using an endmill verses an insert just better geometry on the bottom and we have been using peel milltool pathes to machine down ss with great flatness results ..just a thought
+1Greg. I am almost to the point of dynamic milling all parts that need to be flat with an end mill.
