Thread and cut pos in 9.1 for wire?
Ronan
Hi everyone, I just updated from MC 9 to MC 9.1 and I'm having trouble picking the thread and cut position.Every time I backplot in MC 9.1 It starts the cut at 0,0.Is this an error due to a default in one of the parameter pages.Any help will be much appreciated.
Thanks...Ronan,
Create A Thread "Style" point
Create A Cut "Style" Point
The thread / cut points should not be on the contour geometry
Toolpath/Contour
Pick the thread point
Pick the chain
Pick the cut point
Click Done
You will notice on the
parameters page > "Origin / WCS" page the start point was inherited from the cut point you chained. If no cut point was chained you would need to set teh value of the cut point there or it will default to 0,0.
As you already know.
I also have a problem similar to this. I've haven't had time to sort it out, so I'v been using Wire 9 instead of 9.1.
What I get is this. I'm doing a 4-Axis cutting with 4 skims and reverse cutting the skims. I got the new thread point and starting point firgured out. But after the first rough pass it's goes back to the thread point then to the end of the contour and then starts the skims. I can open an existing file and it's fine I can just not make a new path in a new file the same way it did in v9.
Here is an example of the posted code.
This is at the end of the rough and start of first skim.
V9 posted code...this is correct
G01X.12244Y1.2061U.07578V0.
G01X.11396Y1.21459U.07578V0.
G01X.10196Y1.21459U0.V0.
G40
G69X.86614U12W10
G62 X0
G00X.10196Y1.21459U0.V0.
G42
G01X.025Y1.10866U.07578V0.
V91 posted code...notice the move and back. This would cut the profile all off I just cut. Notice the bold lines of code. This is not how it was done before. I need the reverse skim cut to start where it left off, NOT go back to the contour start point and then back to the end point where it was at!
G01X.10196Y-.02849U0.V0.
G40
G69X.86614U12W10
G62 X0
G00X.10196Y-.02849U0.V0.
G42
It was messed up before in V9, but once you firgured it out it was ok. Now you go and change it completely, 180° different and I can't even reproduce the same program as before. confused.gif I've read the "What's new" page and this is not described in it. I can upload a file of the orignal V9 part that worked and a V91 file.
This needs to addressed I think. If I'm doing it wrong thats fine, I just need to know where? mad.gif
Brent,
I have only done 2 axis work so far in 9.1 but I did notice this statement in the whats new. Just ashot in the dark.
If a new thread point style is used without a corresponding cut point, the wire will return to the thread point or thread distance when Auto position cut point is selected.
Obviously this should be after all skims, but thought might be worth looking at.
[ 05-01-2003, 11:31 AM: Message edited by: CPeast ]
Chad,
I agree totally...
I have the Auto Start posistion unchecked. It still doesn't work. I've selected the thread and cut point I want. We are cutting an open contour and I don't actually thread and cut the wire at the machine. The wire is cutting a profile and leads in and out of the part.
I'm cutting an open 4-axis contour. I'm going to upload 2 files tonight from home, can't upload via FTP from work. One is the original V9 file that works. And the other is the V9.1 file. They will be in the MC9 folder in a zip file called threadproblem.zip Otherwise if anyone would like to look at it I can email the file to them.
I'd like to firgure this out as soon as possible.
This is how I do it. Before you go to contour.pick thread/cut,position. then place your chain points where you want them. Now go to contour, pick your chain points(thread/cut points) before your chains. I don't use "auto start position" or "thread distance" when doing it this way. This give me the results I want. It took me awhile to get the hang of it now V9.1 is a breeze.
That what I'm doing but I wants to cut back to the thread point after the rough and start of the first skim. I select reverse for the cutting method and it goes from the cut point to the thread point and then back to the cut point and reverse cuts the skim(s).
I really want to figure this out so I can start using V9.1 mill and lathe so I can find more "new and improved" stuff wink.gif
I'm sure once I figure it out how it's done it will work fine, but geez this is harder then it was before!
Brent,
Sorry for dropping a sample part with no explanation.
I haven't been back to the forum 'til now.
You have Thread & Cut points defined, but you have not selected them.
Since you have these points ON the endpoints of what you are going to chain,
you need to be a bit careful when selecting the these points.
You could fix the chaining in your program using the Chain Manager.
Click on the Geometry line of your operation, right-click, select Add Chain ,then add the Thread point
Select 'Point' for the chaining method, the 'Point' to tell MC that you want
to select ONLY a 'point' entity, then drag 'n drop that point to the top of the list.
Now repeat this procedure for the Cut Point
(except you don't need to drag 'n drop this point, it's already at the end of the list.)
This may sound complex, but it's actually quite easy once you've played around with the Chain Manager.
BUT, (in this case) it's not a big deal to just re-chain everything...
This is the sequence I used when chaining everything (I rebuilt the entire operation) ->
Wirepaths, 4-axis (checked that the Sync Mode = Entity)
Chain, Mode, Point, Point - then select the Thread Pt.
Now Chain the lower profile.
Now Chain the upper profile.
Mode, Point, Point - then select the Cut Point.
Again -
The extra 'Mode', 'Point', 'Point' menu selections here are because your
Thread & Cut points are ON the endpoint positions of the profile you are going to chain.
So we need to be specific in telling MC that we want those 'point' entities,
not the endpoints of the profile. BTW, You could also do this using the Color Mask option
if your Thread and Cut Points were a different color than the adjoining entities.
You can make this chaining process a bit easier (a few less menu picks) by eliminating
the first and last lines of your profiles. MC is going to cut from the selected Thread Point
to the start of the profile anyway, and from the end of the profile out to the selected Cut Point.
This way, with your Thread and Cut points just 'floating out in space' you don't have to
concern yourself with telling MC that you just want to select a 'point', since there is
nothing else for MC to grab onto at these positions in space.
Also, make sure that "Thread Distance" is Un-Checked.
You're using the Thread and Cut points you've selected, so you don't want this active.
Roger
Ok I finally got this thanks for setting me straight Roger.
I only think I don't get is this was suppose to be an improvement? I personally like the STCW dialogue box from V9 and I never had problems with multiple thread and cut points on multiple profiles.
Glenn,
before in V9 I'd select my thread pt at the start of my profile and the cut pt and the end of the profile. I manually draw in the lead in and lead out I want, which in my eyes is easier being I get want I want to cut faster and easier.
We mainly do 4-axis open contour cuts here which were easier to use with STCW but may in time I'll see the bigger picture. smile.gif
