Heidenhain Control
Anybody here running Heidenhain Controls?? If so, does anybody have an example of a program with the tool breakage detection cycle in it?? Cycle 586??
0 BEGIN PGM 20 INCH
1 ;***************
2 ;THIS PROGRAM IS THE MAIN SUB CALL
3 ;IT WILL WRITE THE POCKET ROTATION VALUE INTO C
4 ;IT WILL CALL THE REQUIRED TOOL IF NEEDED
5 ;IT WILL THEN CALL THE CODE PROGRAM
6 ;******************
7 ; POCKET 1
8 ;TOOL CALL
9 TOOL CALL 81 Z S3600
10 FN 17: SYSWRITE ID 503 NR3 IDX6 =+0
11 CALL LBL 100
12 ; POCKET 2
13 ;TOOL CALL
14 FN 17: SYSWRITE ID 503 NR3 IDX6 =+24
15 CALL LBL 100
16 ; POCKET 3
17 ;TOOL CALL
18 FN 17: SYSWRITE ID 503 NR3 IDX6 =+48
19 CALL LBL 100
20 ; POCKET 4
TOOL breakage detection cycle here.
21 TOOL CALL 82 Z S3600
22 FN 17: SYSWRITE ID 503 NR3 IDX6 =+72
23 CALL LBL 100
24 ; POCKET 5
25 ;TOOL CALL
26 FN 17: SYSWRITE ID 503 NR3 IDX6 =+96
27 CALL LBL 100
28 ; POCKET 6
29 ;TOOL CALL
30 FN 17: SYSWRITE ID 503 NR3 IDX6 =+120
31 CALL LBL 100
32 ; POCKET 7
33 TOOL CALL 83 Z S3600
Here is an example of my program. You can see where I would like to add the tool breakage detection cycle. Any help would be awesome. Thanks guys.
Does this help ?
TOOL CALL 1 Z S10000 F1000 DL0 DR0 ;TOOL 1
TCH PROBE 586 Q356=+1 Q357=+0 Q359=+0
FN 9: IF +Q199 EQU +0 GOTO LBL “SKIP”
STOP ;TOOL BROKEN
LBL “SKIP”
OR
TOOL CALL 1 Z S10000 ;TOOL 1
TCH PROBE 586 TOOL BREAKAGE DETECT ~
Q356=+1 ;MEAS. DIRECTION ~
Q357=+0 ;RADIAL OFFSET ~
Q359=+0 ;ADD. LENGTH CORRECT.
TOOL CALL 1 Z
Does the cycle need to be right after a TOOL CALL??
You can see from the program I put in as an example:
Tool Call 1
Run Program
Rotate C
Run Program
Rotate C
Run Program
Tool Call 2
I would really like it to run like this:
Tool Call 1
Run Program
Tool Breakage Detection
Rotate C
Run Program
Rotate C
Run Program
Tool Call 2
If the tool breaks, I want to stop everything from running.
Sorry if this is very elementary, I am new to the Heidenhain Conrtols and still getting acquainted with how they operate.
put the cycle after the tool runs. Doesnt the load setting take care of a worn out tool. Unless you are checking something like a small drill before a tap, then call the tool & run the path then check for breakage. Also you can "check" the tool through out the path as often as you want. Just rapid up, check, reposition & go.
  • 3 years later...
Does this help ?
STOP ;TOOL BROKEN
LBL “SKIP”
OR
TOOL CALL 1 Z
Thanks this worked for me as well with a minor modification since it didnt like the "SKIP" i changed it to a 1 without quotes:
FN 9: IF +Q199 EQU +0 GOTO LBL 1
STOP ;TOOL BROKEN
LBL 1
My question is this; If I have multiple tool break checks in the same program will the goto command only search forward to the next "LBL 1" or does it have the possibility of jumping to any of the other LBL 1 lines?
