X5 MPMASTER OUTPUT RIGIDTAP CODE FOR FADAL
I use the mpmaster post for all of my Fadal 3-axis work. Everything works great except for the rigid tapping.
The code I get is a Fanuc style:
N130 T21 M06 ( 1/2-13 TAPRH)
N140 (MAX - Z9.)
N150 (MIN - Z7.4)
N160 M08
N170 G00 G17 G90 G54 X1. Y-.75
N180 G43 H21 Z9.
N190 G94
N200 M29 S130 {------------------------I don't need the M29
N210 G98 G84 Z7.4 R8.4 F10.
N220 X4.25
N230 X16.
N240 G80
N250 M09
N260 M05
N270 G91 G28 Z0.
N280 G28 Y0.
N290 G90
N300 M30
I need this code for the Fadal:
N160 S130.2 M5 M90 {-------------Need M90 and S130.2
N170 G84.2 {---------------------Need G84.2
N200 G0 G17 G90 E1
N240 G0 X1. Y-.75
N250 H21 Z9.
N260 G94
N270 G84.1 G98 Z7.4 R8.4 F10. S130.2 {--------Need G84.1 and S130.2 on this line
N280 X4.25
N290 X16.
N300 G80
N310 G91 G28 Z0.
N320 G28 Y0.
N330 G90
N340 M30
Any Help is appreciated.
Keith A-1
Thanks for the link but that does not help me because I am not starting with the generic Fadal format 2 post. I am starting with the X5 mpmaster post. I still need more help to get the code to output the way it is shown in my original post. Would it be possible to copy the rigid tapping section of the post from the fadal format 2 post and paste it into the mpmaster post.
Justin look for this switch near the top of the post
rigid_tap   : 0     #0 = Floating tap output, 1 = Rigid tap output (suppress spindle output and output M29)
Set that bad boy to zero and that will put your speed output back in the first line and remove the m29 line. I've never used a Fadal so I don't what M90 does. You may have to add something to get that output.
gms1,
Thanks for the advice however simply switching to rigid tap mode in the post will not work in this case because the mpmaster post is set up to output a rigid tap cycle for a Fanuc control. I need the post to output a rigid tap cycle that will work on a Fadal using format2.
CJep,
Thanks for the email but I would rather use the X5 mpmaster post. It works great on our Fadals except for the rigid tapping. What I would like is to modify my existing X5 mpmaster post to output the code shown above.
Thanks again for your suggestions.
This is how I handled it in the post.
pmisc2$ #Canned Misc #2 Cycle - G84.1/G74.1
pdrlcommonb
feed = (1 / n_tap_thds$) * speed
pbld, n$, *sgdrill, *sgdrlref, pfxout, pfyout, pfzout, pcout,
prdrlout, *tap_speed, *feed, e$
pcom_movea
sgm2 : "G84.1" #misc #2 - **right hand**
sgm2d : "G74.1" #misc #2 - **left hand**
sgdrill : "" #Target for string
fstrsel sg81 drlgsel sgdrill 16 -1
fmt S 4 tap_speed ".2" #Spindle Speed (for rigid tapping-> Snnnn.2)
B)
