Need help with 1/4-20 Thread mill on 304SST
Guys,
I am having a problem with 1/4-20 thread mill (.47 depth) on 304SST.
Tool use is Scientific TM170-20HA with 9 active teeth.
Please help.
First tried:
S3400
F10.
5 rgh passes (.005 per pass)
2 finish pass, step over .001
1 spring pass
Tool broke at the first hole
Second tried:
S1400
F2.
7 rg passes (.003 per pass)
2 finish passes
1 spring pass
Tool broke at the thrid hole.
Down to the last tool now.
What could be wrong here and what esle could i try??
Any input will be a big help.
Thanks.
I don't have any experience with that type of thread mill, but I'll tell you what works for me. I use Micro 100 solid carbide thread mills that have multiple teeth on one plane, and I cut the hole right to size using cutter comp so I can sneak up on it. In Stainless and Titanium, I usually add a spring pass. I run 200 SFPM in Stainless with .0002 - .0005" per tooth feed. In Titanium I run 120 SFPM with the same feed.
inconel expert i know say they drill (Guhring carbide) a bit larger than 75% thread. a few thou on a 4-40 does make a difference.
waddaya drill to? with?
304 sucks
9 active seems to be a problem in my mind. too much cut force, not enough bending strength.
inconel expert i know say they drill (Guering carbide) a bit larger than 75% thread. a few thou on a 4-40 does make a difference.
304 sucks
+1
way to much cut force.We cut alot of 304 ss and do alot of threading using scientific t-mills with three active teeth.might want to try threading the hole in two depths.At a 120 sfm and .0009 fpt coolant flood
