Helix Bore Verify
Brian B 74
The bottom line is that something has changed with one of the earlier "X" versions. In MC9 and earlier it was cruising right along. Now anytime there is a ramp move (not only helix) it comes to a crawl in comparison to what it was before.
No setting change will help much. I suspect there was a change in the way mc is doing background calculations while verifying...
Hey Brian,
Try setting your Arc Filter Tolerance values to 2:1 and loosen up your total tolerance value. Upon regenerating the toolpath you will notice it is smaller. That should help speed up the verification process.
Are we still talking about a helix bore tool path? I don't have arc filter settings in my helix bore tool path settings. I only have output arcs.
Still don't see the mcx file. BUT - to recreate my toolpath draw a 1" circle. Using a 1/2 bull nose (R.125) do a .010" step down with starting at center to a depth of 1.38".
I am machining hardened 420ss at 55hrc using an OSG feedmill for roughing some leader pin holes. See what kind of results you get.
Tried your suggestion Tony - no change.
John - I am set to output helixes. Still crawls along.
Have had this problem for some time. Was hoping that it was something easy to fix.
This is a problem I've always had. I did some work at a shop where they had a fairly lame computer, but with a high end Quadro video card
(don't know which model, wish I did) and the helix bore verify zoomed.
IMO it's all in the video card
