cutter comp in lathe canned cycle
odessa
I'd like to ask something. In all seriousness, why does anyone use comp on a lathe? I never use it and don't have a reason to. I just offset my geometry to suit. The only reason I see to use compensation, is so that when you put a new insert in, its at the same place and you have your offset already? Can someone explain what other benefits there are to comp on a lathe?
Let's say you program a finish contour for a 1/32" radius WITH comp and the operator can not get a good finish... he can simply put in a 1/64" radius insert, change his feedrate, and change the nose comp accordingly.
If there is no comp programmed, he would have to depend on you to re-write the whole program to use a different radius insert.
When I ran a CNC lathe (Fanuc 21i-T) all my finishing tool paths had cutter comp (G41/G42). Reason for this - most of my pieces I had to hold +/- .0005" on critical diameters. It was easier to use cutter comp to compensate for tool wear and machine growth. If I used computer for comp I would be constantly reprogramming and uploading new code (which would be a waste of time).
Just my $.02
