3 Axis Vertical recomendations
It does reasonably well. I have AICC 2 on both machines with the Oi-MD. I typically hold my total surface tolerance to .0002" and stepovers to around .004 with say a 1/4" ball mill and have never had an issue. If you're going to be doing strictly 3D stuff or a whole lot of it you'll be better off with a 31i or nicer control. They'll process the data faster. But if you don't need it don't pay for it.
I don't know if I have the manual guide. I do everything in Mastercam.
I like the Manual Guide i INTERFACE. The programming is a bit cumbersome. I've NEVER been a real proponent of programming at the machine anyway.
JM2CFWIW
Yup - talking about the manual guide grammin. Soooooooo long winded and clunky.
And yes, prog at the cam system and let the machine make you money while your programming.
So you can have a Fanuc OI-MD with AICC 2 and no Manual Guide?
It might depend on each machine tool builder. Some reps are saying you must upgrade to Manual Guide I ( 10" screen and FULL Alpha key board) to also get AICC.
Nice to know you can get AICC 2 on the standard OI-MD controller
The Doosan does look good with the 31i as standard along with AICC standard
Guest MTB Technical Services
Doosans also use the 0iMD.
That control uses the same architecture as the 31i Series,
It really depends on the machine and what was ordered from the factory.
  • 3 months later...
I had a good look at the Doosan DNM 500 around $125k and the 650 around $135K today.
They come standard with AI APC (Advanced Preview Control) 20 Block preview.
The reseller in OZ brings them in with the option AICC (AI Contour Control) 40 Block preview
There is another option AICC II with 80 Block preview.
I'm wondering if the 40 block look ahead will be enough??? I'll run a test cut on it.
I'm looking at the Makino PS95 on Friday.
Get the 80 Block preview if you plan on doing a lot of 3D programs.
40 blocks is plenty for 2.5D but you always want to look ahead as far as possible.
For 3D, 40 Blocks is nothing.
That said, if you use the filtering in Mastercam properly, you would probably be OK
but always better to have more look-ahead than you need.
The Okuma on the USA web site starts at $119K.
So in OZ that will be over 200K
Only 460mm in the Z axis ????
Still a great machine. And do you need more than 460mm Z travel? We have an Okuma MB56VA and that has 460mm Z travel. I can't recall ever needing more :)
This is thrown a spanner in the works.
I've come across a second hand Hardinge Bridgeport GX1000 with a 4th axis rotary. Year is 2010
Used Hardinge CNC Machining Centre:
Installed Jan 2011
BT40 10,000 rpm Spindle
1000 x 540 x 540mm X/Y/Z
Spindle Chiller
22kW Spindle Motor
30 m/min rapids,
30 Tool Swing Arm ATC,
4th Axis Drive + 250mm Rotary Table
Chip Conveyor
Fanuc Oi-MD Control
Its a big saving over the new machines I have been looking at.
Can anyone comment on the Hardinge Bridgeport GX1000???
Thank you
Thanks for the heads up Newbee I'll ask the quetsion.
Cheers Dave
Oh a little more info I found out
The Control Storage Capacity is 512KB
It has a Compact Flash card for drip feeding larger programs in.
From the machine information I have this machine does have AICC + Manual Guide i
I'm looking at the machine on Monday morning anything I should look for?
funnily enough I was at the UK distributer today of HB loking at a Feeler 510 drill tap (another thread...:rolleyes: )
They are bloody well built the quasers - stout linear ways and big head castings with not a lot of spindle poking out - like matssura/mori etc
The D control is the latest and very user friendly
This is the reply I recieved re the Hardinge.
This machine is a Hardinge Bridgeport made at the Hardinge Plant in Taiwan.
There is no longer any association with Yang.
Hardinge USA bought the Marketing Division and License from Bridgeport in 2000
Quaser were building some of the Hardinge Bridgeport XR Range but Hardinge Taiwan now build these.
I looked at the Makino PS95 today great machine and comes with the price tag.
If they start at $119k, then the prices jumped up significantly in the last couple of months.
I swear just back in November they started at about $80k. That price tag is the main reason we bought another Okuma.
460mm of TRAVEL on Z axis yes, the spindle stops about 6" from the table. Or 152mm for you metric lovers. ;)
I looked at a Hardinge Bridgport GX1000. Very surprised they have no orgars to remove the swarf from inside the machine. It relies on coolant to wash the swarf to the front of the machine, then into the chip conveyor.
I fill a 44 gallon drum with Alloy swarf in 1 hour I can't see this machine handling the swarf issue.
Crossed off the list.
I really like the Makino PS95 but its 60K more than a Doosan DNM 500
