mondalloy
just got an RFQ for a blisk made of a "mondalloy" forging
I've never heard of it.. even google draws a near blank..
One material company who offers "mondalloy stainless steel"
I can't find any data at all.
I've got a feeling that it's real ugly stuff..
Has anybody heard of it??
Materials for Liquid Rocket Engines for the Integrated High Payoff Rocket Propulsion Technology
(IHPRPT) program:
Turbopump Housing: Nickel based super alloys for LOX. Mondalloy improved Ni based Ox
compatibility over Haynes 214.
:dizzy:
Your boss won't mind - he'll take it on. He's got an expensive okuma to pay for :D
This is a little baby part Ø8." x 12" , way too small for our Okuma
It needs to be held between centers. Its perfect for 5X mill turn.
We're not really set up for this part, but that doesn't mean the boss won't take it on :laughing:
Guest MTB Technical Services
For machining purposes, treat Mondalloy like an Inconel 600 or X-750 alloy.
Hayes214 is an alloy used for low-stress parts in high-temp applications.
It's got a high aluminum content for oxidation resistance.
Mondalloy is used in high-temp applications where oxidation resistance is needed but the part stress makes Hayes214 impractical.
ie. liquid fuel rocket engines
I have cut a lot of invar 36 and 42 which is a nickel based alloy (but only 36% and 42% nickel no where close to the 75% you are dealing with). I got the best results using hss corn cob roughers to cut it. The invar is very toxic to machine I would look into safety data and see what type of ventilation or respiratory protective equipment you would need to cut it.
this is a shaft with radial impeller blades milled from a disc in the middle of the part.
nearly every diameter on the part is ±.0001 and all the blades are .002 MMA.
Its part of a LOX pump and must spin crazy fast.
I took a highlighter and marked all the tolerances up and sent it back to estimating.
So far its been <crickets>
It would be a nice part for someone with the right machine, but that someone is not us
this is a shaft with radial impeller blades milled form a disc in the middle of the part.
Oooooooooooooooooooooooooooooooooooooooohhhhhhhh!!!!!
You could measure those bores 5 times and get a different measurement :lol:
I live by the statement of 'It's not the challenge of doing the part, it's the challenge of making money from doing the part'.
And this looks like it's wrapped up in BIG bucks!
+1. We always tell our customers, it's not making it, it's making it for something youre willing to pay haha.
Mike
i was wishing my mill turn was up and running right up til i read this post...
+/-.0001 eeeeeekkk
grind after final machining...how bad could it be?
exactly.. and the sales staff is saying.. so what if we get killed on these 3 parts
there will be a follow-on order for thousands
Grinding that Material would be my way to ensure you could hold the +/-.0001 on diameters in production. I would think even then it would still be a crap shoot to a point with the .002 Profile tolerance on the thing. I would really look at a Rough, Semi-Finish then Finish op for milling. A grinding machine to finish the whole thing would be my choice like a Studer or something along those lines. Risk having too much SFM for the material with grinding and getting stress fractures, but would help you make sure you can hold any tight tolerances required on that Material.
It's the follow ons I'd be terrified of...
Making the first 3 isn't the true headache, it would be those thousands of parts. Let's see if I'm warm
Climate Controlled room for the machine and material, coolant is temperature controlled, glass scales, JAPANESE, 5 decimal place readout, that should do
I've got a better idea. Slap the junior engineer silly and tell him to go back and tolerance
his creation for the real world. :smoke:
