chamfering holes
ibrox2000
lets say you want to Spot drill with a 45 deg spot drill and at the same time get the chamfer larger then the hole..
When doing the drilling on the second paramater pager were you put the depth you see a little
Calcalter button go there.
You will see the tools you need in inside.
I don't much like the calculator option becasue it adds the calculated value to the depth every time you click it. You get the same results by checking Tip Compinsation, and you can check the value (or add to it by adjusting the 'breakthrough' amount) more easily.
As long as you don't mind trigging out the diameter you want by using the depth and angle..
'Rekd teh calc rules but needs to save settings better
If you know the finish dia, you can just lie about the size of the tool. Dosn't change the code any.
I was sitting here reading this thinking; Why would you define a tool dia that is not the dia that you're using to make the part, just to chamfer a hole to a certain diameter..? (Remeber, you can't change the dia value in the Tip Comp dialog, you can only change it using the dreaded calculator or the tools actual dia.)
You say it doesn't change the code any, and to some degree you're right, but it affects several things that are better left alone. Including the setup sheets, verify, and many other things that are directly related to the tool's actual diameter.
Lets say you have 5 different diameters that you need to create c'sinks for? Are you going create 5 different tools and lie about each of them just to do the spotting and avoid the dreaded calculator?
You might as well not use either and just adjust the depth + or - in the Depth box.
'Rekd
[ 11-16-2003, 12:06 PM: Message edited by: Rekd ]
I use the dreaded calculator method too. True it's not tremendously smooth, BUT it gets the job done quite nicely as long as your point/arc is at the top of the surface to be chamfered, and your dool definition is correct. If the tool definition is not correct, all sorts of problems can crop up. JM2C - lying gets you into trouble. biggrin.giftongue.gif
If I am just spot drilling the chamfer with a 90 deg. spot drill, I do not use the calculator either. I find it just as easy to just type in the math directly into the spot for the depth.
It is a simple formula for a 90 deg tool.
Rad of hole to be chamfered + chamfer size + rad of tools tip= depth of cut
this has always worked for me. Also adding a dwell to the cylce makes it look much nicer as well as keepling the chamfer looking consistent. smile.gif
Eric
[ 11-17-2003, 11:35 AM: Message edited by: Eric Salsman ]
Rick D.,
There is a switch in the "dreaded" calculator that states "Overwrite depth". That switch is just below the one that is defaulted on and says "Add to depth". If you want to change the tool angle simply uncheck the "Use current tool values" switch at the top and then you can put in any angle you have for the tool. HTH biggrin.gif
