All Activity
- Past hour
Krish0090 joined the community
- Today
Need Old version tutorials X4 specifically
JParis replied to Toybreaker's topic in Educational Forum
Ebay might have some older manuals reasonably priced... That's 16 year old software....ancient in software years. -
김창섭 joined the community
Noshad joined the community
sajin joined the community
Paul Wallace joined the community
alanhbw joined the community
- Yesterday
Just like the title says. I have X4, no interest in upgrading, I am using an old small desktop 4 axis cnc machine. Going to be doing mostly small 3d wax seal stuff. I got this software with the hasp when My ship decommissioned and they told me to "dispose of it", well my wife has a need for me to relearn how to use this software and make her little machining center make her some money.
Toybreaker joined the community
GOTO command not working with 5 axis program
mkrmrkr replied to Shiva.aero's topic in Machining, Tools, Cutting & Probing
@Shiva.aero are you able to increase this number? How did you get around this limitation? -
Phelix smith 1022 joined the community
Carlos Alvarado joined the community
- Last week
Appreciate the quick responses guys. Z2G it is. Thanks again.
Your settings look correct.....I use this toolpath frequently and checking "rapid down" as you have yields rapid motion between pecks on all our machines. I'd send a Z2G to your reseller.
The rapid on the tool page only controls the approach and end retract not in the cycle itself. Give high feed rate is your only option that I am aware of. You can put in a request and see what they say.
Using Advanced Drill for the first time. Can not seem to get the drill to rapid back down for the next peck even though I have the Rapid down box checked in the Cut Parameters branch. It rapids down same as the programmed feed rate. Also, what purpose is the Cutting Parameters feeds / speeds in the Tool branch. Seems that the Cut Parameters branch page feeds / speeds overwrites it. Thanks everybody.
Need to get a hold of your dealer so they can remote in and see what is going on.
Time for a call to your reseller
Windows 11 is apparently problematic enough that its market share is actually declining. I built a nice new rig for my dad last year, and put 11 on it. Updates keep breaking things, so we're considering dropping it back to 10. https://gs.statcounter.com/os-version-market-share/windows/desktop/worldwide
I would go into task manager and kill everything related to mastercam. I had to do with the camplete the license thing got hung up and a restart wasn't fixing it
Yes, still doesn't work.
Have you tried running an an administrative?
I am also having an issue with Mastercam where it never starts at all, when I attempt to open it, it does nothing. I checked event viewer and found this: Faulting application name: Mastercam.exe, version: 26.0.7341.0, time stamp: 0x645da48c Faulting module name: KERNELBASE.dll, version: 10.0.22621.3527, time stamp: 0x83efbeab Exception code: 0xe06d7363 Fault offset: 0x000000000006543c Faulting process id: 0x0x6C6C Faulting application start time: 0x0x1DAA7D2759B8F4C Faulting application path: C:\Program Files\mcam\Mastercam.exe Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll Report Id: c5348f50-e072-44e2-9e17-88b1ce8beeec Faulting package full name: Faulting package-relative application ID: Any suggestions? I've reinstalled the application multiple times, repaired C++ redistributable, ran sfc /scannow, nothing seems to work.
I am also having the same issue. Mastercam never starts at all, when I attempt to open it, it does nothing. I checked event view and found this: Faulting application name: Mastercam.exe, version: 26.0.7341.0, time stamp: 0x645da48c Faulting module name: KERNELBASE.dll, version: 10.0.22621.3527, time stamp: 0x83efbeab Exception code: 0xe06d7363 Fault offset: 0x000000000006543c Faulting process id: 0x0x6C6C Faulting application start time: 0x0x1DAA7D2759B8F4C Faulting application path: C:\Program Files\mcam\Mastercam.exe Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll Report Id: c5348f50-e072-44e2-9e17-88b1ce8beeec Faulting package full name: Faulting package-relative application ID: Any suggestions? I've reinstalled the application multiple times, repaired C++ redistributable, ran sfc /scannow, nothing seems to work.
Remove the solid history.
Guilty as charged.
