Drilling without using a cycle
RACINGCONVERTERS
8 minutes ago, RACINGCONVERTERS said:
Is there a way to change from using a G81 drill cycle to a point to point drilling. (not using cycle syntax)
Depending on your post, usually you can disable drill cycles in the control definition page.
I think the section is called drilling cycles.
13 minutes ago, RACINGCONVERTERS said:
I was able to adjust the post to not post the cycle. Thank You for the help.
One more question! Is there a way to change to post fast feed instead of rapid?
That's usually set in the operation parameters, uncheck "rapid retract"
On 3/5/2021 at 5:04 PM, Aaron Eberhard - CNC Software said:
Probably not..  A "regular" G81 cycle specifies that it rapids out, so unless you mod your post to not output rapids, it most likely will exit with a rapid.   Perhaps the advanced drill will do what you need?  That one doesn't rapid out, but has a feed retract rate.
The op has drilling cycles disabled..
Does that change the outcome?
Not really. The movement output is G0/G1.
However, there is a "convert rapid to feed" switch in the CD. This does need to be incorporated into your Post, to get the G1 Fxxx. For Rapid moves.
To get this to work, it is really Post Dependent.
Try the Rapid page of the Control Definition
There is an option there to force G01 rapid mtion
The go to the Machine Definition and define the MAX rapid speed.
This will not work if you are using a really old post that does not respect the Machine/Control definitions
