fear of tapping
motodog
I've got to tap several blind holes in 6061 -t6 and have decided to try thread form tapping to minimize the chip issues. Its a 8 x 1.25 thread and it seems like about .295" drill size should do it. But I'm pretty clueless about feed speeds, and whatever else I'm clueless about (how could I know?). I'm using rigid tapping on a haas vf0 with a floating toolholder. In the past I have put about 1/2 the thread depth with a conventional rigid tap and hand tapped the rest, but in the interest of avoiding carpel tunnel.....I want the haas to do the work!
Any tips or experience would be appreciated.
Thnx
  • Replies 93
  • Created
  • Last Reply
Top Posters In This Topic
motodog,
I have had trouble rollform tapping bigger sized threads on my Haas VF-0 due to lack of torque. I never use floating tap holders when I rigid tap. I rollform all blind holes, and cut tap thru holes. It works out great. Don't use the same sized drill for cut tapping!
Is your program inch or metric?
Roll form is a piece of cake. I think .295 is bit big on the drill though. I use a .290 (letter L) drill for M8. If you use a .295, make sure to check the minor diameter to see if its in print.
Hole sizes for metric thread are an easy calc. For a cut tap, you subtract the pitch from the major dia of the thread. For roll taps, you divide the pitch by 2, then subtract that from the maj dia. For example, we'll use your M8 x 1.25:
8-1.25 = 6.75 (hole for cut tap is .265)
1.25/2 = .625, 8-.625 = 7.375 (hole for roll is .290)
If you're more comfortable with a cut tap, then you could use a spiral fluted cut tap in the blind hole. That way the chip comes out the back of the tap instead of being pushed down like a normal tap.
Good Day,
If there is not much room, you might want to
blow out the holes before tapping.
Tony G
CNCiT Precision Machine - Hudson,NH
X Beta Site
Almost Employed Senior Programmer
N.E Massachusetts - Southern New Hampshire
_________________________________________
End mills and tooling are like The "AMMO"
And coolant and chips are like the enemy
Under your boots as you advance in the
Manufacturing Battle
ABSOLUTELY don't run it dry!!!!! I rigid-tap roll-form all day (and night) at 1200 to 1600 rpm on the smaller taps in 6061 with flood coolant at about a 10% mix (Blasocut 2000SW). On an M8 tap I usually run about 1000 rpm. Use a hard collet (no floaters). The upper limit on my equipment is about 1800 rpm - at 1900 rpm it loses synch and "drills" the threads. After about 6-10 holes of "drilling" it - the tap gets partially left behind. I guess form taps arent really very good as reamers. eek.gif Be aware, the "faster" you tap, the more "headspace" you need at the bottom of the hole to handle overshoot (I am talking about a Fadal here guys!!). For some reason, taps don't like to be smacked into the bottom of the drilled hole........ biggrin.gif
BTW - the first couple of holes with small taps still makes me cring waiting for that gut-wrenching little "pingggg-scritch".
Hammer down, no guts no glory.....heh....
800 RPM in 420SS 1/4"-28 1-1/2" deep of actual thread. Relieved a standard tap with a lathe tool in the collet of the mill so it would go that deep..
390 blind holes took a couple hrs for me to do on a mini drillpress with a motor-reversal micro switch on it. Ganged parts 5 at a time in a Kurt that floated on the drillpress table.
'bout a second a hole...
brush with oil......
Only broke 2 taps......
Murlin teh old school.....
