carbide drill not wearing well
HEAVY METAL
i using an sgs 103 series carbide drill 31/64 dia. 4140 pre-hard is the material i'm machining.
drill depth 1.0 thru no peck. sgs book says 115 sfm .003 per rev. (for tool steel 40 rc and below) this is a 3 flute drill. drill did about a 100 holes then started making some serious noise. the tip seemed to be discolored like it was getting hot. should i try peck drilling . i thought this carbide drill would hold up alot better. the feed per tooth seems conservative enough maybe to slow but that is what book recs.
any have any thoughts on this problem
thanks heavy
I would not peck with solid carbide drill. Definitely no spot drilling (unless your spot drill has the same tip angle). Is the drill coated? If so you need to recoat it after re-sharpening. If you're going too slow than you'll burn it up... 100 holes @ 1" deep is not acceptable. I do have 3 flute drills in here, but always had better luck with 2 flute.
Good Day,
+1 Cbly
The break-thru on hard matl. will destroy most
drills...If anything peck the last break-thru @
small amounts.
In my case, I drill for endmill entry, so a minimal break-thru will do it, so an endmill
will not to have to centercut break-thru.
Tony G
CNCiT Precision Machine - Hudson,NH
X Beta Site
Almost Employed Senior Programmer
N.E Massachusetts - Southern New Hampshire
_________________________________________
End mills and tooling are like The "AMMO"
And coolant and chips are like the enemy
Under your boots as you advance in the
Manufacturing Battle
If you must break thru,the thing I found works best is slowing the rpm's down and increasing the feed just before the full dia breaks thru.
this works especially well with hss/super cobalt spade drills on a lathe.
Have you ever tried the ChamDrill Jet drills from Iscar?
Very very good.
Mitsubishi,Tungalloy and OSG are the only 3 brands of solid carbide drills I buy.
