Trimming surfaces
Jeff the haas_guy
  • Replies 75
  • Created
  • Last Reply
Top Posters In This Topic
This file is in the mcx directory under the name "Trimming problem".
If you remove the shading, you can see there is a 1.0 radius running thru the middle of this part near the top, that is supposed to be open thru the part. I trimmed all the other surfaces, but cant seem to get the angles to trim the the 1.0 radius.
Little help?
Is it necessary to go to class for this or will a training manual be enough help?
Your best bet would be some one-on-one time with someone who knows it. That way you could concentrate on your particular questions. Next, I would suggest some tutorial books. That way, you can work at your own pace. Finally, I would recommend a class at the local community college. They tend to be slow moving (in my experience), but you have plenty of time to try new things.
In that order, those are my recommendations.
In the "Drawings" folder on the FTP, I've uploaded a bunch of practice files to mess with. They range in difficulty from lower # to higher. My files are called mill.zip and lathe.zip. They're fulling dimensioned prints that you can create with wireframe for surfaces/solids.
Thad
I also find the classes slow moving. I am pretty much self trained on Mastercam. The problem is 3d is so much more involved than 2d. Workikng with someone that knows it would be my best bet,that is if I could find someone that would spend the time.
Which tutorial book in particular would you suggest? I am doing this all on my own. My place of employment does not think we need this training. I just enjoy learning something new.
So...here I am.
All I need to do is create a surface at the bottom of the 1.0 radius so the cutter can cut the bottom of the surface.
So you need what Matt has above...the pink/purple surface in the after picture? If so, you could have trimmed the green to the blue surface, and then the blue to the green.
Thad
The books listed here in the Books area are pretty good.
I'd be happy to help you over the phone, if you'd like. They would have to be simpler projects or we'd spend the entire time trying to explain which part we were talking about. biggrin.gif
Thad
