Helix bore
Rakesh
Hi everbody,
I am using helix bore feature to make 4 inch hole in the plate. I am using 3/4 insert type end mill and my idea is to keep going down in z for specify pitch. My problem is at the final z, it is going to the center and the ring which is left inside the hole will give the problem.
Entry/exit arc sweep, I put the value 0
Any idea how we can avoid the tool to go to center at the end.
Any other idea for using the 3/4 flycutter to make hole in the steel plate by keep moving down in z instead of step plunge depth.
Plate is 1" thk, 4140
thanks
If you are going to have a slug in the center, don't use helix bore. Helix bore will want to clear the entire hole out.
Use a 2D contour with the ramp option turned on.
I hope you're going to screw the slug down, because it will rattle around the bore and may break the cutter.
We do a lot of this around here and slugs can be a problem. 1st week at this job, I was out in shop watching a job run. I noticed slug was not screwed down and wondered what operator was going to do. When machine got close to end og helix; he stopped machine, got a hammer and chisel and cut out slug! I was floored. I have since discovered that things are don differently here!
