Converting post from 9 to X
mig
Hi,
This is part of post for ver 9 were taking stock value from:
pstock # Comment amount of stock to leave
spaces=0
if (opcode=13 | opcode=14),
pbld, n, pspc, "(TOOLPATH - ", *stoper, ")", e
pbld, n, pspc, "(STOCK LEFT ON DRIVE SURFS = ", *stock, ")", e
if check<>0, pbld, n, pspc, "(STOCK LEFT ON CHECK SURFS = ", *check, ")", e
spaces=0
if (opcode=2 | opcode=4),
pbld, n, pspc, "(STOCK LEFT ON X&Y = ", *stock2dxy, ")", e
pbld, n, pspc, "(STOCK LEFT ON Z = ", *stock2dz, ")", e
spaces=sav_spc
mig,
I Am looking at the same post I adjusted for you last week. Don't know if it is the same post that is giving you trouble but I noticed the stock variable is not defined.
I don't see either of these in that post
fmt    2 stock      # Amount of Stock left on drive surfs
fmt 2 check # Amount of Stock left on check surfs
You have this
fmt "DRIVE= "  2 surf_stock      # Amount of Stock left on drive surfs
fmt "CHECK= " 2 chek_stock # Amount of Stock left on check surfs
But you're not calling it at that point you're calling the original variables
The stock value is probably coming from a parameter and some of these parameters have changed for X.
There is a document (Mastercam X post parameter reference.PDF) that shows all parameters changed for X it will show the mapping from V9 to X. You can get to this file through your start menu or by using explorer and looking in the mastercam Documentation folder.
Updatepost does NOT autmatically update these, so you must do so manually.
Hello all,
I tried parameter 12437 for drive stock to leave and 10227 for check stock to leave but it still does not work.
Her is what I have in my post:
and
fprmtbl 13      2         # Multisurf Finish
12437 stock # Amount of stock to leave on drive surfs
10227 check # Amount of stock to leave on check surfs
fprmtbl 14 2 # Multisurf Rough
and
spaces$=0
if (opcode$=13 | opcode$=14), pbld, n$," ", pspc, "(TOOLPATH - ", *stoper, ")", e$
if (opcode$=13 | opcode$=14), pbld, n$," ", pspc, "(STOCK LEFT ON DRIVE SURFS = ", *stock, ")", e$
#if (opcode=13 | opcode=14) & check<>0, pbld, n," ", pspc, "(STOCK LEFT ON CHECK SURFS = ", *check, ")", e
if (opcode$=13 | opcode$=14), pbld, n$," ", pspc, "(STOCK LEFT ON CHECK SURFS = ", *check, ")", e$
spaces$=sav_spc
And this still gives me 0. even if my values are set to .06 in MCAMX.
Also, I can't seem to find the parameter number for the op name to post out.
[ 09-15-2006, 10:06 AM: Message edited by: marting ]
another thing to check is make sure that you have the "Write NC Operation Information" check box active in your control definition. This must be active for Mastercam to write the OPS information otherwise everythign is zero.
Do you have other parameters being used in this post?
You may need to post a code snippet of the postblock and postlines from PParameter or pwrttparam so I can see the logic that is making calls to the parameter look up tables.
