Mpmaster post help again
DavidB
With the same tool I have a toolpath at B270 then another toolpath at B90.
I have a 400.mm retract at the end of the first toolpath so to clear the rotation of the B axis.
What the post outputs is the X,Y,Z and B move together on 1 line.
This will cause a crash and defeats the purpose of the 400.mm retract.
X2 Mpmaster code
 G01 G40 X235.188 Y331.336
G00 Z20.
Z400.
(FINISH 3 LUGS DIAMETER 60.4MM)
M11 (UNLOCK)
X-301.042 Y329.83 Z20. B90.
M10 (LOCK)
Z7.89
G01 Z1. F850.
Same toolpaths posted with my V8 Mpmaster.
G00 Z20.
Z400.
G00 M11 (UNLOCK)
B-270.
X-301.042 Y329.83
M10 (LOCK)
Z20.
B rotation first
X,Y Moves
Z move
Can I get this from the X2 Mpmaster?
I have "Break rapid moves-XY then Z for approach,Z then XY for retract Tick in my Control def?
David rearrange the section that handles the out put like this
if lock_codes = 1 & not(index) & rot_on_x, pbld, n$, *sunlock, "(UNLOCK)", e$
pbld, n$, pfcout, e$
pbld, n$, sgabsinc, [if not(index), pwcs], pfxout, pfyout, e$
if lock_codes = 1 & not(index) & rot_on_x & cuttype = 0, pbld, n$, *slock, "(LOCK)", e$
pbld, n$, pfzout, e$
Looking through quick it looks like the only place that complete output is handled is in the ptlchg0$
Looks like this section ptlchg_com could generate it as well
If another one shows up use debug and you should be able to track it down and make the same edits
John,
I ran debug it's not at a toolchange, it's using the same tool at B90 retract then rotate to B270 for next toolpath.
G00 Z20. pzrapid$ prapidout
Z400. pzrapid$ prapidout
(FINISH 3 LUGS DIAMETER 60.4MM) pcomment$ pcomment2
M11 (UNLOCK) pcomment$ p__54:1715
X-301.042 Y329.83 Z20. B-270. pcomment$ p__54:1715
M10 (LOCK) pcomment$ p__54:1715
Z7.89 pzrapid$ prapidout
G01 Z1. F850. plin$ plinout
I had simillar problem, I had to seperate XY, Z, and B(pfcout), in post.
Pl try this after Z rapid out in "ptlchg0"
pbld, n$, "G00",pfcout, e$
pbld, n$, pwcs, e$
pbld, n$, sgabsinc, pfxout, pfyout, e$
and this is the output I am getting.
N720 G0 Z100.
N730 G00 Z1000.
(FACE 180 )
;DATUM PLANE X=268.998 Y=175.3 Z=206.266
N740 G00 B180.
N750 G15 H03
N760 X-25. Y-15.
N770 Z50.
N780 Z2.
N790 G1 Z0. F800.
I think this be the area in ptlchg0?
 pindex
if fmtrnd(prv_cabs) <> fmtrnd(cabs),
if lock_codes = one & not(index) & rot_on_x, pbld, n$, *sunlock, sunlockcomm, e$
pbld, n$, [if not(index), sgabsinc, pwcs], pfxout, pfyout, pfzout, pfcout, e$
Or am I way off?
quote
pindex if fmtrnd(prv_cabs) <> fmtrnd(cabs),
if lock_codes = one & not(index) & rot_on_x, pbld, n$, *sunlock, sunlockcomm, e$ pbld, n$, [if not(index), sgabsinc, pwcs], pfxout, pfyout, pfzout, pfcout, e$
This seems to be the place where the output is coming from but only wierd thing is in your last message.
I can't understand how can this be coming from pcomment.
Monty,
I dont think it is coming from pindex as I added a force of my name and it did not post.
I agree I can not work out where it is coming from with debug.I'm no post guru.
Hopefully Brett from Inhouse will comment.
I did debug the output and everything is coming from ptlchg0 or ptlchg.
N690 X-21.15 Y36.633 I-42.3 J0. pcir$ pcirout 344.
N700 G1 X-23.65 Y40.963 plin$ plinout 346.
N710 Z-68. F999. plin$ plinout 348.
N720 G0 Z100. pzrapid$ prapidout 350.
N730 G00 Z1000. ptlchg0$ p__2:638 400.
(FACE 180 ) ptlchg0$ p__2:638 400.
;DATUM PLANE X=268.998 Y=175.3 Z=206.266 ptlchg0$ p__2:638 400.
N740 G00 B180. ptlchg0$ p__2:638 400.
N750 G15 H03 ptlchg0$ p__2:638 400.
N760 X-25. Y-15. ptlchg0$ p__2:638 400.
N770 Z50. ptlchg0$ p__2:638 400.
N780 Z2. pzrapid$ prapidout 402.
N790 G1 Z0. F800. plin$ plinout 404.
If you want I can send you comlete ptlchg0 and pindex code from my post for you to try.
David,
Could come from here as well
ppos_cax_lin #Position the rotary axis before move - rapid
if index, pindex
else,
if fmtrnd(prv_cabs) <> fmtrnd(cabs) & rot_on_x,
sav_gcode = gcode$
gcode$ = zero
if mr10$>300, n$, "G0", *mr10$, e$
else, pbld, n$, "G0Z300.", e$
if prv_mi8$ = one, "G05P0(SGI OFF)", e$
pbld, n$, "M11 (UNLOCK)", e$
pbld, n$, sgcode, pcout, e$
pbld, n$, "M10 (LOCK)", e$
if mi8$ = one, "G05P10000(SGI ON)", e$
!cia
ps_cinc_calc
gcode$ = sav_gcode
!mi8$
Just out of interest what is wrong with the Old Post?
I changed this in the ptlchg0 section
From this
To this
pbld, n$, [if not(index), sgabsinc, pwcs], pfcout,
This is the posted code now
G00 Z20.
Z400.
M11 (UNLOCK)
B-270.
M10 (LOCK)
Z7.89
G01 Z1. F850.
Now I just need to move the Z20. to a line below the X,Y move after M10 (lock)
Greg,
Your post was for the 5-axis I have since updated all my 5-axis mahines to the Generic 5-axis post from X.
I want to update My V8 Mpmaster to the new X2 Mpamaster.
I check with the mode I made and I can not see it causeing a problem so far.
This is code I'm getting now.
 G01 G40 X235.188 Y331.336                                   plin$ plinout
B90. pcomment$ p__54:1715
X-301.042 Y329.83 Z20. pcomment$ prapidout
Z7.89
How can I get the Z20. move from prapidout to the next line?
David,
The post I copied that code from was old 4 Axis MPmaster set up for A77
Current Mpmaster has this
if index, pindex
else,
sav_gcode = gcode$
if convert_rpd$ = 1,
feed = maxfeedpm
gcode$ = 1
ipr_type = 0
else, gcode$ = zero
if lock_codes = one & not(index), pbld, n$, *sunlock, sunlockcomm, e$
if lock_codes = one & not(index) & cuttype = 0, pbld, n$, *slock, slockcomm, e$
!cia
ps_cinc_calc
gcode$ = sav_gcode
Note that it calls Pindex
I still think your change will be a problem. It may become apparent when machining multiple ops with the same tool
Greg the code below is multible ops with the same tool at 180 degree rotations.
The mod I made to pindex seems to have only now output the B move inbetween the clamping codes.
The following line after clamping I do not want the Z value.
Z7.89
What is the best way to get the Z20. move onto a sepperate line after the X,Y moves?
[ 01-04-2007, 09:22 PM: Message edited by: DavidB ]
gcode yes you could do that.
I use the Referance retract position to get the Z400. on the previous toolpath.
There are to many differances from the V8 to X2 post that a file compare does not work for me.As I said I'm no post guru.
I'd like to get the post working
Paul,
thanks for responding.
My V8 Mpmaster works without needing to have a Referance for the second toolpath.
Is there a way to get the Z axis move on a sepperate line after the rotaion?
I have been programming for years with a retract move only on the pre toolpath if I forget to put a clearance move on the following toolpath also this could be very dangerous.
