Another post question - null toolchange
Bruce Caulley
I have 2 ops that are on the same plane using the same tool. Why would the post output a toolchange as below? I do not have the force toolchange tab checked.
 G91 G28 Z0.                             ptlchg0$ p__5:868 346.
G90 ptlchg0$ p__5:868 346.
M11 B67. M10 ptlchg0$ p__5:868 346.
M98 P555 ptlchg0$ p__5:868 346.
G0 G90 X-147.656 Y-39.998 ptlchg0$ p__5:868 346.
G43 H#100 Z138.69 ptlchg0$ p__5:868 346.
Z129.69 pzrapid$ prapidout 348.
G1 Z128.69 F2000. plin$ plinout 350.
X-109.592 F3400. plin$ plinout 352.
G3 Y-28.57 R5.714 pcir$ pcirout 354.
G1 X-139.656 plin$ plinout 356.
G2 Y-17.142 R5.714 pcir$ pcirout 358.
G1 X-109.592 plin$ plinout 360.
G3 Y-5.714 R5.714 pcir$ pcirout 362.
G1 X-139.656 plin$ plinout 364.
G2 Y5.714 R5.714 pcir$ pcirout 366.
G1 X-109.592 plin$ plinout 368.
G3 Y17.142 R5.714 pcir$ pcirout 370.
G1 X-139.656 plin$ plinout 372.
G2 Y28.57 R5.714 pcir$ pcirout 374.
G1 X-109.592 plin$ plinout 376.
G3 Y39.998 R5.714 pcir$ pcirout 378.
G1 X-147.656 plin$ plinout 380.
Z129.69 F10000. plin$ plinout 382.
G0 Z138.69 pzrapid$ prapidout 384.
G91 G28 Z0. ptlchg0$ p__5:868 438.<============This line not needed
G90 ptlchg0$ p__5:868 438.<============This line not needed
M11 B67. M10 ptlchg0$ p__5:868 438. <============This line not needed
M98 P ptlchg0$ p__5:868 438.<============This line not needed
G0 G90 X-127.992 Y-40. ptlchg0$ p__5:868 438.<============This line not needed
G43 H#100 Z129.69 ptlchg0$ p__5:868 438.
G1 Z128.69 F2000. plin$ plinout 440.
G41 D60 Y-48.8 F3400. plin$ plinout 442.
G3 X-119.192 Y-40. R8.8 pcir$ pcirout 444.
G1 Y40. plin$ plinout 446.
G3 X-127.992 Y48.8 R8.8 pcir$ pcirout 448.
G1 G40 Y40. plin$ plinout 450.
Z129.69 F10000. plin$ plinout 454.
M319 peof$ peof$ 456.
G91 G28 Z0. peof$ peof$ 456.
G90 peof$ peof$ 456.
M01 peof$ peof$ 456.
M99 peof$ peof$ 456.
% peof$ peof$ 456.
Hi David,
The null toolchange post block seems to be the culprit. Search in your post for ptlchg0$ and see what the logic looks like. There should be some kind of boolean "if" statement that compares the current toolplane to the last toolplane and looks for a change. If no change has occured, it should retract the tool to the Z retract or clearance of the current operation, then move to the next op with no toolchange. If you post a snippet of the null toolchange post block here I'll take a look.
HTH,
From the post:
 ptlchg0$         #Call from NCI null tool change (tool number repeats)
pcuttype
pcom_moveb
pcheckaxis
comment$
pcan
result = newfs(15, feed) #Reset the output format for 'feed'
pbld, n$, sgplane, e$
pspindchng
pbld, n$, scoolant, e$
if mi1$ > one & workofs$ <> prv_workofs$,
sav_absinc = absinc$
absinc$ = zero
pbld, n$, "G91 G28 Z0.", e$
n$, "G90", e$
pbld, n$, "M11", pfcout, "M10", e$
n$, "M98 P", work_shift, e$
pbld, n$, *sgcode, *sgabsinc pfxout, pfyout, e$
pbld, n$, sg43, "H#100" , pfzout, scoolant, pstagetool, e$
pe_inc_calc
ps_inc_calc
absinc$ = sav_absinc
if cuttype = zero, ppos_cax_lin
if gcode$ = one, plinout
else, prapidout
pcom_movea
c_msng$ #Single tool subprogram call
Also,
In the example above on one of the unnecessary lines there is a line: M98 P
After the P there should be the workoffset number which I have defined in the post. In the post section above you can see:
I can live with the unnecessary null toolchange, but only if the variable work_shift outputs for all null toolchanges and not just the first.
Bruce
This is what I have:
# Rotary Axis Settings
vmc : 0 #SET_BY_MD 0 = Horizontal Machine, 1 = Vertical Mill
rot_on_x : 3 #SET_BY_MD Default Rotary Axis Orientation
#0 = Off, 1 = About X, 2 = About Y, 3 = About Z
rot_ccw_pos : 0 #SET_BY_MD Axis signed dir, 0 = CW positive, 1 = CCW positive
index : 0 #SET_BY_MD Use index positioning, 0 = Full Rotary, 1 = Index only
ctable : 5 #SET_BY_MD Degrees for each index step with indexing spindle
use_frinv : no$ #SET_BY_CD Use Inverse Time Feedrates in 4 Axis, (0 = no, 1 = yes)
maxfrdeg : 2000 #SET_BY_MD Limit for feed in deg/min
maxfrinv : 999.99#SET_BY_MD Limit for feed inverse time
maxfrinv_m : 99.99 #SET_BY_MD Maximum feedrate - inverse time
frc_cinit : yes$ #Force C axis reset at toolchange
ctol : 225 #Tolerance in deg. before rev flag changes
ixtol : 0.01 #Tolerance in deg. for index error
frdegstp : 10 #Step limit for rotary feed in deg/min
rot_type : 1 #SET_BY_MD Rotary type - 0=signed continuous, 1=signed absolute, 2=shortest direction
force_index : no$ #Force rotary output to index mode when tool plane positioning with a full rotary
use_rotmcode : 0 #Output M-Code for Axis direction (sindx_mc)
#0 = Signed direction (only valid when rot_type = 1)
#1 = M-Code for direction
#Rotary Axis Label options
use_md_rot_label : no$ #Use rotary axis label from machine def? - Leave set to 'no' until available
srot_x "A" #Label applied to rotary axis movement - rotating about X axis - used when use_md_rot_label = no
srot_y "B" #Label applied to rotary axis movement - rotating about Y axis - used when use_md_rot_label = no
srot_z "C" #Label applied to rotary axis movement - rotating about Z axis - used when use_md_rot_label = no
sminus "-" #Address for the rotary axis (signed motion)
#Axis locking
rot_lock : 1 #Use rotary axis lock/unlock codes (0 = no, 1 = yes)
slock "M10" #Axis lock
sunlock "M11" #Axis unlock
I did a search and couldn't find that line. Here are my general output settings:
# General Output Settings
sub_level$ : 1 #CD_VAR Enable automatic subprogram support
breakarcs$ : 2 #CD_VAR Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs
arctype$ : 2 #CD_VAR Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.,
#5 = R no sign, 6 = R signed neg. over 180
do_full_arc$ : 0 #CD_VAR Allow full circle output? 0=no, 1=yes
helix_arc$ : 2 #CD_VAR Support helix arc output, 0=no, 1=all planes, 2=XY plane only
arccheck$ : 1 #CD_VAR Check for small arcs, convert to linear
atol$ : 0.01 #CD_VAR Angularity tolerance for arccheck
ltol$ : 0.002 #CD_VAR Length tolerance for arccheck
vtol$ : 0.0001#System tolerance
maxfeedpm : 500 #SET_BY_MD Limit for feed in inch/min
ltol_m : 0.05 #Length tolerance for arccheck, metric
vtol_m : 0.0025#System tolerance, metric
maxfeedpm_m : 10000 #SET_BY_MD Limit for feed in mm/min
force_wcs : yes$ #Force WCS output at every toolchange?
spaces$ : 1 #CD_VAR Number of spaces to add between fields
omitseq$ : yes$ #CD_VAR Omit sequence numbers?
seqmax$ : 9999 #CD_VAR Max. sequence number
stagetool : 0 #SET_BY_CD 0 = Do not pre-stage tools, 1 = Stage tools
stagetltype : 0 #0 = Do not stage 1st tool
#1 = Stage 1st tool at last tool change
#2 = Stage 1st tool at end of file (peof)
use_gear : 0 #Output gear selection code, 0=no, 1=yes
min_speed : 50 #SET_BY_MD Minimum spindle speed
nobrk$ : no$ #CD_VAR Omit breakup of x, y & z rapid moves
progname$ : 1 #Use uppercase for program name (sprogname)
prog_stop : 1 #Program stop at toolchange: 0=None, 1=M01, 2 = M00
tool_info : 2 #Output tooltable information?
#0 = Off - Do not output any tool comments or toolpable
#1 = Tool comments only
#2 = Tooltable in header - no tool comments at T/C
#3 = Tooltable in header - with tool comments at T/C
tlchg_home : no$ #Zero return X and Y axis prior to tool change?
OK, so now that I have safe output when a null toolchange is called I need to get rid of the unnecessary null toolchanges that I am getting after every operation. If I have three ops on the same plane with the same tool I get the following:
 %                                       pheader$ pheader$ 68.
NC GROUP2(O0000) pheader$ pheader$ 68.
(Experimental post ggggg Be Afraid) pheader$ pheader$ 68.
(MCX FILE MAKINO_CENTRE.MCX) pheader$ pheader$ 68.
( 16MM FIN (EDP09120) 842M | D60 | CONTROL COMP | ) pwrtt$ ptooltable 68.
M42 psof$ psof$ 70.
T#100 M6 psof$ psof$ 70.
G91 G28 Z0. psof$ psof$ 70.
G90 psof$ psof$ 70.
M11 G0 B0. M10 psof$ psof$ 70.
M98 P101 psof$ psof$ 70.
G0 X-65.018 Y48.8 S14000 M3 psof$ psof$ 70.
G43 H#100 Z171. M8 psof$ psof$ 70.
G1 Z170. F2000. plin$ plinout 72.
G41 D#101 plin$ pccdia 74.
X-73.818 F500. plin$ plinout 74.
G3 X-65.018 Y40. R8.8 pcir$ pcirout 76.
G1 X67.643 plin$ plinout 78.
G3 X76.443 Y48.8 R8.8 pcir$ pcirout 80.
G1 G40 X67.643 plin$ plinout 82.
Z171. F10000. plin$ plinout 86.
G91 G28 Z0. ptlchg0$ p__5:869 140.
G90 ptlchg0$ p__5:869 140.
M11 B0. M10 ptlchg0$ p__5:869 140.
M98 P101 ptlchg0$ p__5:869 140.
G0 G90 X-65.018 Y48.8 ptlchg0$ p__5:869 140.
G43 H#100 Z171. ptlchg0$ p__5:869 140.
G1 Z170. F2000. plin$ plinout 142.
G41 D#101 plin$ pccdia 144.
X-73.818 F500. plin$ plinout 144.
G3 X-65.018 Y40. R8.8 pcir$ pcirout 146.
G1 X67.643 plin$ plinout 148.
G3 X76.443 Y48.8 R8.8 pcir$ pcirout 150.
G1 G40 X67.643 plin$ plinout 152.
Z171. F10000. plin$ plinout 156.
G91 G28 Z0. ptlchg0$ p__5:869 210.
G90 ptlchg0$ p__5:869 210.
M11 B0. M10 ptlchg0$ p__5:869 210.
M98 P101 ptlchg0$ p__5:869 210.
G0 G90 X-65.018 Y48.8 ptlchg0$ p__5:869 210.
G43 H#100 Z171. ptlchg0$ p__5:869 210.
G1 Z170. F2000. plin$ plinout 212.
G41 D#101 plin$ pccdia 214.
X-73.818 F500. plin$ plinout 214.
G3 X-65.018 Y40. R8.8 pcir$ pcirout 216.
G1 X67.643 plin$ plinout 218.
G3 X76.443 Y48.8 R8.8 pcir$ pcirout 220.
G1 G40 X67.643 plin$ plinout 222.
Z171. F10000. plin$ plinout 226.
M319 peof$ peof$ 228.
G91 G28 Z0. peof$ peof$ 228.
G90 peof$ peof$ 228.
M01 peof$ peof$ 228.
M99 peof$ peof$ 228.
% peof$ peof$ 228.
