Advanced 5X toolpaths
gcode
How many people out there are using these toolpaths and what kind of results are you getting??
I'm using the advanced 5X swarf toolpath
and getting poor surface finishes no matter
what I set the tolerances and stepovers at.
One of the other programmers is using V9 5X swarf
with default tolerance and getting much better results on similar cuts.
We are both using the same 3rd party post that runs on Mastercam NCI.
Does anyone have any experience or guidance they
can give me regarding tolerance/stepover etc?
fuuny doing a part and seeing some weird things as well.
Are you using the Multi pass? Are you that as a slice or passes function? Have you looked at the surface quality and what do you have them set at? I have a cut tolerance of .0005 distance of .025 with 8 cuts and Max Stepover of .025 and still not really happy with the floor. The walls look great but hope to get a better floor finish by using the step over in surface quality not working the way I hopw it would. The multi-surf looks great on the floor areas for the other area of this part so I guess I will use that in this area.
I'm just doing 5X Swarf. It doesn't matter
whether I use multipass or not and playing
with the steopover toloerances has not improved things much. If these walls were critical features, I'd be in trouble.
The V9 paths with the default .001 chord height and .100 max step are machining much cleaner
walls.
I guess I'll do my next part with X2 old style
5X swarf. That will tell me if its an X2 issue
or an advanced 5x toolpath issue.
I'm wondering if there are any Machine Definition
or Control Definition setting that affect mulitaxis NCI output. I've been using the default generic mill machine definition.
[ 03-11-2007, 11:18 AM: Message edited by: gcode ]
We had a problem with 5-axis toolpaths. If you get flats ( like a fifty pence piece. I dunno what the American equivalent is.....) on surfaces the answer is to use point generators. I used 0.1 distance and 0.2 angle. Gives a huge toolpath but does the job.
  • 3 weeks later...
