Pocket Nightmare
gms1
Ive tried everything I could to makea pocket toolpath for this thing and I can't get what I want. I uploaded it to the ftp under mx2 files -> gms-pocket.mcx
I need to cut that pocket out and the part is already shaped to the 1/8 thick walls surrounding the pocket. I want to cut the pocket out without cutting a full size pocket as if there is material there above the 1/8 walls. I basically want to cut this pocket with the angle of the outside walls acting as som sort of upper boundry so the tool doesnt cut so much air while running. Is it possible?
easy to do use Surface rough pocket turn off the Roughing and just use Finishing. You can control the amount of material left to make step cuts into the material when doing the depths if you would like. I will explain this further I use leave stock of .06 for one operation then I would use another operation with leave stock of .01 or .005. This will act as a semi finish then a finer semi finish then you can finish. Depending on the part I have used this toolpath to finish parts using a ball endmill and small step downs.I use this toolpath all the time for forgings and castings.
I put your file on the ftp site renamed it
gms-pocket_RS.mcx
I pocketed it with a containment and
trimmed the toolpath to a closed profile and it cuts
no air at all.
i used a 1/4" em .05 stepdown for the example
See if that is what you are looking for.
I timed the work I did and it took me 2-1/2mins
total.
Wait!
download this one it has the pocket cut you
described gms-pocket_RS_2.mcx
GMS1, create a surface to close in the pocket and save the file as an STL file. now delete this surface. Use surface high speed toolpaths, select rest roughing, under the rest material page set the "compute remaining stock" to "CAD". Go to your operations navigator and select geometry, you'll see a button that says "cad file", select the stl file you made earlier.
I've uploaded a file for you called GMS-POCKET nap.zip.
HTH,
Neil.
gms-pocket_RS.mcx
no air at all.
total.
Wait!
When it asks "pick a point on the side to keep" where do you pick a point because this isnt working for me with a 1/2 ballnose and wcs
Was the path i made what you are looking for?
OK:
looking in the right side view do not pick inside
the profile. CPLANE has to be set on right also.
pick (the part geometry) or under the profile line
that goes through the path.
it divides the tool path on that line and side you
pick is the path to keep.
Mastercam requires a rectangle or closed profile
to perform tool path or the trimming of surfaces
Rick
