Help with a crash file
gcode
I have uploaded a file to the FTP
Its in X3 files and named ALT S crash.mcx.
I have run this on several machines and can replicate the crash 100% of the time on three
different computers..all with Nvidia video cards
Could some of you guys try it and see if you can replicate the crash.
You'll need X3 with Advanced 5X toolpaths to try it
Here are the steps to replicate the crash
Filename Alt S crash.mcx
(X3MU1)
Turn all levels ON
Turn shading ON
Start an advanced 5X toolpath
Choose 5X swarf
Select T#10
Select the wall surfaces (brown)
Select the floor surfaces (purple)
Select the "Bottom Rail" button to launch
the chain manager..
You can't see the chain on Level 48 so...
Hit ALT S to unshade the surfaces..
and you crash...
These steps wil crash all three of my computers
with 100% reliablity..
I'm wondering if ATI machines will crash
on this file.
Only for you would I knowingly crash my computer while I'm working!!!!!
I followed your instructions to a "T" and sure enough as soon as I hit Alt S she crashed and burned. Which is wierd because I always unshade or use Alt W Shading Translucency Toggle to see my chains.
I'm going to try it again only this time I will try Alt W instead of Alt S and see if it still fails.
Works just fine for me on my Shuttle G..
Course i got a cheepie Quadro 500....
System Information
Time of this report: 1/29/2009, 06:55:17
Machine name:
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.080814-1236)
Language: English (Regional Setting: English)
System Manufacturer: Shuttle Inc
System Model: SB61V40
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel® Pentium® 4 CPU 3.00GHz (2 CPUs)
Memory: 2048MB RAM
Page File: 452MB used, 4515MB available
Windows Dir: C:WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA Quadro FX 500/FX 600
Manufacturer: NVIDIA
Chip type: Quadro FX 500/FX 600
DAC type: Integrated RAMDAC
Device Key: EnumPCIVEN_10DE&DEV_032B&SUBSYS_01BA10DE&REV_A1
Display Memory: 128.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: ViewSonic VA720-2
Monitor Max Res: 1280,1024
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.9136 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 7/12/2006 13:19:00, 4493568 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 7/12/2006 13:19:00, 3934592 bytes
Device Identifier: {D7B71E3E-406B-11CF-DE50-B02100C2CB35}
Vendor ID: 0x10DE
Device ID: 0x032B
SubSys ID: 0x01BA10DE
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek AC97 Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCIVEN_8086&DEV_24D5&SUBSYS_C09D1297&REV_02
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ALCXWDM.SYS
Driver Version: 5.10.0000.6240 (English)
WHQL Logo'd: Yes
Date and Size: 4/25/2007 15:20:48, 4030144 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 26, 25
Static/Strm HW 3D Bufs: 26, 25
HW Memory: 0
Voice Management: No
EAX 2.0 Listen/Src: Yes, Yes
I3DL2 Listen/Src: Yes, Yes
Sensaura ZoomFX: No
Registry: OK
Sound Test Result: Not run
Got acceleration and openGL turned on also...
Wonder why I am the only one not crashing
You're not..I sent it in to QC yesterday
and Chris didn't crash either.. so I thought
I'd get a more tests and put it up here.
My guess is its a driver issue.. Your Quadro
FX-500 is an older card using older drivers.
This is the pertinant line from the logger file
of my crash
MFC80.DLL caused an Access Violation
We have been seeing a lot of crashes in the nVidia OpenGL drivers. We did a little data mining on our crash reports and see specific versions of the drivers that crash a lot more frequently than others. Whenever I see a crash report like this and there is an email address supplied I ask them to do the following:
1. First you should try getting a driver update either directly from nVidia or from the manufacturer of your system.
2. If that does not help, in the nVidia Control Panel, try setting the 3D Settings profile to Dassault Systemes SolidWorks.
This seems to work in 99% of the cases.
The other thing to check is how much memory you have on your graphics card. We document a minimum requirement of 128MB. You can get by with less if you run at very low resolution.
You receive an access violation error message when you run a Visual C++ 2005 application that is statically linked to MFC...
Typically, this problem occurs if the following conditions are true:
The name of the folder in which the application runs contains a percent symbol (%).
You create the application under your profile folder.
There are quite a few instances where the dll will output access violation...
Windowz Support
Just as a follow up on this problem. I was able to reproduce the crash in X3 using the file that gcode uploaded. However it was crashing in a module supplied to us by a third party so I could not tell the exact cause. It does not crash in the X4 release that we are currently working on.
Did not crash my Dell M6300..
NVIDIA System Information report created on: 02/02/2009 10:44:52
System name: SMT-WM923
[Display]
Processor: Intel® Core2 Extreme CPU X7900 @ 2.80GHz (2792 MHz)
Operating System: Microsoft Windows XP (Service Pack 3)
DirectX version: 9.0c
GPU processor: Quadro FX 1600M
ForceWare version: 175.75
Memory: 512 MB (256 MB Dedicated)
Video BIOS version: 60.84.66.00.05
IRQ: 16
Bus: PCI Express x16
[Components]
nvCplUIR.dll 1.5.700.62 NVIDIA Control Panel
nvCpl.cpl 1.5.700.62 NVIDIA Control Panel Applet
nvExpBar.dll 1.5.700.62 NVIDIA Control Panel
nvCplUI.exe 1.5.700.62 NVIDIA Control Panel
nvWSSR.dll 6.14.11.7575 NVIDIA Workstation Server
nvWSS.dll 6.14.11.7575 NVIDIA Workstation Server
nvViTvSR.dll 6.14.11.7575 NVIDIA Video and TV Server
nvViTvS.dll 6.14.11.7575 NVIDIA Video and TV Server
nvMoblSR.dll 6.14.11.7575 NVIDIA Mobile Server
nvMoblS.dll 6.14.11.7575 NVIDIA Mobile Server
nvDispSR.dll 6.14.11.7575 NVIDIA Display Server
NVMCTRAY.DLL 6.14.11.7575 NVIDIA Media Center Library
NVOGLNT.DLL 6.14.11.7575 NVIDIA Compatible OpenGL ICD
nvDispS.dll 6.14.11.7575 NVIDIA Display Server
NVCPL.DLL 6.14.11.7575 NVIDIA Compatible Windows 2000 Display driver, Version 175.75
NV4_MINI.SYS 6.14.11.7575 NVIDIA Compatible Windows 2000 Miniport Driver, Version 175.75
NV4_DISP.DLL 6.14.11.7575 NVIDIA Compatible Windows 2000 Display driver, Version 175.75
nvGameSR.dll 6.14.11.7575 NVIDIA 3D Settings Server
nvGameS.dll 6.14.11.7575 NVIDIA 3D Settings Server
Above are my Drivers and settings.
Oh, I have a Dual Monitor Setup also.
I just performed the steps and like James, my system didn't crash either.
NVIDIA System Information report created on: 02/03/2009 12:14:53
System name: D92G2HH1
[Display]
Processor: Intel® Xeon® CPU E5440 @ 2.83GHz (2826 MHz)
Operating System: Microsoft Windows XP, 64-bit (Service Pack 2)
GPU processor: Quadro FX 3700
Driver version: 178.26
Memory: 512 MB
Video BIOS version: 62.92.19.00.04
IRQ: 52
Bus: PCI Express x16 Gen2
[Components]
nvCplUIR.dll 1.5.620.10 NVIDIA Control Panel
nvCpl.cpl 2.1.310.00 NVIDIA Control Panel Applet
nvExpBar.dll 1.5.620.10 NVIDIA Control Panel
nvCplUI.exe 2.1.310.00 NVIDIA Control Panel
nvWSSR.dll 6.14.11.6947 NVIDIA Workstation Server
nvWSS.dll 6.14.11.7826 NVIDIA Workstation Server
nvViTvSR.dll 6.14.11.6947 NVIDIA Video and TV Server
nvViTvS.dll 6.14.11.7826 NVIDIA Video and TV Server
nvMoblSR.dll 6.14.11.6947 NVIDIA Mobile Server
nvMoblS.dll 6.14.11.7826 NVIDIA Mobile Server
nvDispSR.dll 6.14.11.6947 NVIDIA Display Server
NVMCTRAY.DLL 6.14.11.7826 NVIDIA Media Center Library
NVOGLNT.DLL 6.14.11.7826 NVIDIA Compatible OpenGL ICD
nvDispS.dll 6.14.11.7826 NVIDIA Display Server
NVCPL.DLL 6.14.11.7826 NVIDIA Compatible Windows 2000 Display driver, Version 178.26
NV4_MINI.SYS 6.14.11.7826 NVIDIA Compatible Windows 2000 Miniport Driver, Version 178.26
NV4_DISP.DLL 6.14.11.7826 NVIDIA Compatible Windows 2000 Display driver, Version 178.26
nvGameSR.dll 6.14.11.6947 NVIDIA 3D Settings Server
nvGameS.dll 6.14.11.7826 NVIDIA 3D Settings Server
