.020 deep 45 degree slots- plastic
mike561h
I ran my second setup peice out of pomalux industrial grade plastic you can buy atMcmastercarr. Everything is okay until I cut the fricking .020 deep slots confused.gif with a new 1/8 45 degree carbide endmill 2 flute. The slots look like there is no V at the bottom. I have a TM-1 and max RPM is 4000.
Is this RPM the problem. I run at 10 IPM and went down tto 5 on cleanup. Or do I need to grind a 1/8 spade much like a engraving tool wioth a sharp point at 45 degrees. mad.gif
Mayby tipping the part at 45. then running a standard e-mill through it might get it
That would be my suggestion. Something like a sin vise or angle blocks should do the trick. Believe it or not the bigger and sharper endmill you use the better it will work.
Josh
a two flute going that shallow of depth is only going to "push" the material. too big of a web right at center of cutter. you would get away with it if the material was wood, but not plastic.
if you have to use your current set up, i would switch tooling to a single flute engraving type cutter with at least a .005 tip land.
