Coolant on always all paths
Thee Rickster ™
JP, I dont need it for drilling.
I re-channeled my coolant so it only flow though
the spindle cooling chamber.
So when I have a 116 ball flying at 14000 rpm
for 6hrs it keeps the spindle cool.
I run 3/4 ball at 12000 etc
In my post I had in-house put generic stuff(way back)
at every toolchange, maybe I can have it put an
M08 at the beginning and an M09 at the end
of each change?
N310 Y-4.2122
N320 G80 <--------
N330 G91 G28 Z0.<------
N350 M01 <-------
N360 G17 G40 G80 G90 G54 <--------
N370 #30 DRILL
N380 T10 M06 NO. 30 DRILL
N390 MAX - Z3.
N400 MIN - Z.05
Rick
Here's a Linky from a while ago. This was a workaround for X3.
My coolant sticks, but I use step, peck, coolant to pull the code from the tool def.
If you want to use coolant from the tool, you can export the tool library to a text file, change the coolant codes, then import the text back to a tool library. It's faster than editing each tool one at a time.
[ 12-09-2009, 05:42 PM: Message edited by: Mastercam Guru ]
I just want coolant on all the time. All tool paths.
Every tool change, M08.
Why is this such a task?
What is this step peck coolant array you guys
are talking about.
in a 16 hour program, I peck drill graphite for
20 minutes. The coolant on, cools my spindle,
that is all, it doesent ever spray on my 'graphite
workpiece.
Guru, i have hundreds of saved ops, do I have
to do this export thing to all of them?
ptlchg_com #Tool change common blocks
if force_output | sof,
result = force(ipr_type,ipr_type)
result = force(absinc$,absinc$)
result = force(plane$,plane$)
pcom_moveb
pcheckaxis #Check for valid rotary axis
c_mmlt$ #Multiple tool subprogram call
ptoolcomment
if sof & scomm_sav <> snull,
spaces$ = 0
n$, pspc, scomm_str, *scomm_sav, scomm_end, e$
spaces$ = sav_spc
if sof = 0, scomm_sav = snull
comment$
pcomment3
pmisccheck
#pcan MOVED TK 2/24/09
if stagetool >= zero,
if omitseq$ = 1 & tseqno > 0,
if tseqno = 2, n$ = t$
ptoolcomm, e$
pbld, *n$, *t$, "M6", e$
else, pbld, n$, *t$, "M6", e$ #ptoolcomm, e$
pbld, n$, "M50 (CHIP FLUSH ON)", e$
if mi1$ = 1, n$, *sm00, e$ # ADDED TK 2/24/09
if nextdc$ <> 3, pbld, n$, pfspindleout, e$
pcan #MOVED COOLANT BEFORE TO HERE TK 2/24/09
spaces$=0
if output_z = yes$,
rickster look how i forced M50 to be on, turns on every tool change
I just figured out that if you import a toolgroup
of paths that have all the coolant on, every path
after importing comes in with the coolannt off.
it seems to be ok with MU2 but i have not imported a lot of ops yet to give a good answer to that i had some issues importing with coolant sticking but i use tools coolant and on some of my ops i use V9 style coolant because it wasnt sticking
so i dont think there is a switch did you save them with coolant on?
