Outputting Probing Results using Custom Macro
Mick
Hi there,
We have a Toyoda FMS (2 x 1050s), and I want to somehow output the probing results into a file.
Is there any way of doing this? I'm quite new to custom macros so please be gentle. :)
I'd like to output a file, and have catergories like this:
(X AXIS MEASUREMENT)
112.54
(Y AXIS MEASUREMENT)
23.433
etc etc.
Is this doable at all?
Cheers,
Mike
There are a few ways to do it using DPRINT. Do you have the Renishaw Inspection Plus macros? Those will output them for you automatically. Just add a W1. at the end of each macro call.
I've had machines that will just write the Renishaw output to the hard drive for the last 6 or 7 years, so it's been a long time since I had to play with the DPRINT function. The Fanuc manual has a pretty good explanation of it. You can output just about anything you want.
Ok, the manual mentions dprint, and I understand how the output works.
It doesn't mention anything about specifing a filename though. Is this possible?
Are you going through RS232 to a serial communication program like Cimco? I used to set Cimco to "Receive into new window", and then I could save the thing with whatever name I wanted after it was done. I don't know if there's a way to have it output a specific file name.
Here's a sample I always give to ym customers;
O7777(31i SERIES CONTROL DPRINT TEST)
G90G10L52
N20R4(CHANGE TO FLASH CARD)
G11
(0 and 1 = RS232)
(4 = CARD)
(5 = DATASERVER)
G4X5.
(DATA BELOW IS CAPTURED IMMEDIATELY AFTER A PROBING)
#135=5.8895 (X POSITION)
#136=.0003 (Y POSITION)
#137=.0 (Z POSITION)
#138=1.7507 (SIZE)
#139=.0 (X SURFACE ANGLE/4TH ANGLE/ANGLE)
#140=.0005 (X ERROR)
#141=.0007 (Y ERROR)
#142=.0 (Z ERROR/Y SURF ANGLE)
#143=.0007 (SIZE ERROR)
#144=.0 (X ANGLE ERROR/ERROR)
#145=.00172 (TRUE POS. ERROR)
#146=0. (METAL CONDITION)
#147=0. (DIRECTION INDICATOR)
#148=0. (OUT OF TOLERANCE FLAG 1-7)
#149=0. (PROBE ERROR FLAG)
(PROGRAM TO FORMAT AND OUTPUT CAPTURED DATA)
( * IS TREATED AS A SPACE)
(24 IS FORMATTING NUMERICAL THE OUTPUT - )
( - 2 PLACES BEEFORE THE DECIMAL AND 4 PLACES AFTER)
N100 POPEN (OPEN COMM CHANNEL)
N135 DPRNT[X*POSITION*IS*#135[24]]
N136 DPRNT[Y*POSITION*IS*#136[24]]
N137 DPRNT[Z*POSITION*#137[24]]
N138 DPRNT[DIAMETER/SIZE*#138[24]]
N139 DPRNT[X*SURFACE*ANGLE/4TH*ANGLE/ANGLE*#139[24]]
N140 DPRNT[X*ERROR*#140[24]]
N141 DPRNT[Y*ERROR*#141[24]]
N142 DPRNT[Z*ERROR/Y*SURF*ANGLE*#142[24]]
N143 DPRNT[size*ERROR*#143[24]]
N144 DPRNT[X*ANGLE*ERROR/ERROR*#144[24]]
N145 DPRNT[TRUE*POS.*ERROR*#145[24]]
N146 DPRNT[METAL*CONDITION*#146[24]]
N147 DPRNT[DIRECTION*INDICATOR*#147[24]]
N148 DPRNT[OUT*OF*TOLERANCE*FLAG*1-7*#148[24]]
N149 DPRNT[PROBE*ERROR*FLAG*0-2*#149[24]]
N200 PCLOS (CLOSE COMM CHANNEL)
G90G10L52
N20R5(CHANGE IO TO DATASERVER)
G11
G4X5.
Drop a card in the slot and away you go. It will automatically create the files. (PRNT0000.DAT and start incrementing up from there) You have no control over their naming according to my contact at FANUC.
Thanks very much for that. That is exactly what I need.
I did manage to get it to output data to the card all by myself :)
And thanks for answering the question about the naming. That is a shame that there is no control over the name output. Interestingly, the name output was MCR_PRNT.TXT, but it didn't renumber incrementally. It just errored up saying "file already exists"
Is there any way to change to number the files incrementally, and also change the output channel to use the ethernet, so it can be uploaded to the Cell Controller?
Thanks everyone for your help so far.
Ok, I've got the time and date output sorted :)
Edit: Well, no, I didn't. I get a format error when I try to output #3011 and #3012, which according to the manual can be used to read the current date (#3011) and time (#3012).
Nothing but the best for my friends, :cheers:
Ok,
For the date, I'm pretty sure you need to capture the #3011 and #3012 to Local Variables first, (ex. #161 and #162), then get them out that way.
POPEN and PCLOSE should initiate a new file. You running a 31i Control on your Yoda's? I'll have to check the manual in the morning to see if there's a parameter governing that. I know you can;t rename them, but you should get them incremented up.
Ethernet... perhaps. I've never tried it. Ethernet is Channel 9 IIRC.
Try putting a PCLOS, then POPEN at the beginning of the program, then close it out at the end. I'm looking at some other probing stuff I have and in the Renishaw AxiSet software, it does that. But the fact that it does not give yo ua number in the file name is definitely not what I would expect.
One thing that may be related, #3301.7 (you may see sn HDC above it, maybe not). This allows you to press and hold the shift button down for like 5 seconds and it will capture a screen shot to your open channel (usually 4, it does not work with 5). Why this may be relevant is because you can capture screen shots and it increments the file number up. Give that a shop.
Thanks for the further info James. I'm now at home (being that I am down here in the Southern Hemisphere :) ), so I will try this info in the morning. As I was driving home, I had a thought that maybe I needed to capture the date parameters to local variables. I'll also try the ethernet channel output, and see what happens.
I'll let you know what I find out.
Yes, we're 31i's on our Yodas.
16i Format;
G90G10L50
N20R4
G11
As far as writing a file to the Dataserver... not absolutely sure. I've not tested it. But getting a file from the Dataserver to a PC is done via FTP (over a network usually), if connected directly to a PC, you'll need the ORANGE (Crossover) network cable.
  • 4 years later...
I hope someone can help on this. I'm trying to write a DPRNT routine with DO/WHILE or GOTO loops. I'm trying get the output statement to auto increment.
I want output to look like this:
  PROG:       7781
  DATE:   20160128
  TIME:   160936
  V100       .00000
  V101      1.00000
  V102      2.00000
  V103       .00000
  V104       .00000
  V105      1.00000
  V106      2.00000
  V107       .00000
So I'm attempting to us a GOTO loop ( I had a DO/WHILE in the original, but thought it might be causing the failure so I switched to a loop). I would like to output the description V101,V102,V103.... using a variable. I can do it with the individual statements under the ( # TEST TEMP)  section, but can't crack this nut. I also change the description variable to #143 thinking the same # being called 2x, but sadly no.
Any thoughts?
#141=#4(DATA TRANSFER START #)
#142=#5(DATA TRANSFER END #)
#143=#141
POPEN
(CAPTURE PROGRAM INFO)
DPRNT[**PROG:**#4115[80]]
(CAPTURE DATE & TIME)
DPRNT[**DATE:**#3011[80]]
DPRNT[**TIME:**#3012[60]]
( # TEST TEMP)
DPRNT[**V100**#100[45]]
DPRNT[**V101**#101[45]]
DPRNT[**V101**#102[45]]
N10( LOOP START)
(CHECK LOOP COUNT-COMPLETE)
IF[#141GT#142]GOTO99
DPRNT[**V#143**#141[45]]
#141=#141+1(+1 TO COUNTER)
#143=#141
IF[#141LT#142]GOTO10
N99
PCLOS
Off Track:
Hey Mike, hope all is well. Let me know your plans and we can try to meet up when you are in town.
On Track:
I re-ran the macro and I'm receiving a PS1143 BPRNT/DPRNT STATEMENT FORMAT ERROR Description in the book: "The format used in the BPRINT statement or DPRINT statement is in error" Not much help.
DPRNT output file is:
 PROG:       7781
  DATE:   20160128
  TIME:   160936
  V100       .00000
  V101      1.00000
  V101      2.00000
Fails at the looping section.
Any ideas are welcome.
