Feed
AlbertZini
You can also use the toolpath editor. Right click on the operation and look to the bottom for toolpath editot. Then cycle through the points and then adjust the feedrate where the arc start. You might want to add control points so you can add and delete points to have it start slwoing down right before getting to the corner, but you will figure out what works and what does not soon enough.
I knew that, but now I am interested to do this automatically
in the operations manager, go to tool settings there is a box for "adjust feed on arc move" check the box and enter a value.
If u want use it,you have to go turn it on,and even though ur operation isn't dirty u have to
Regenerate.now for the next tool path if you dont wanna use it you have to go turn it off.
So if you regenerate your 1st tool path with it off your gonna loose ur slow down on arcs.
What i usually do is lock the tool path that i used that feature on.
Thanks :thumbsup: it worked after I was replace post processor and regenerate operation
Can you explain what you mean by control points and how to use them?
