Lazy Iskander dirty tricks Inc .
Fig sign
John !
I consider to change the way I show tricks :
instead of files to use images ,that will help
to see ,what I mean for those who do not have FTP access .
Like I did it in last article .
BTW ,you can do it also ,show me your common geometry and we will try to discuss it .
WTHH
  • Replies 179
  • Created
  • Last Reply
Top Posters In This Topic
Forgive me. I have the image saved out of MC, and I have pasted it into a word doc. But for the life of me I don't understand how to get the image into this posting. If I click on image it asks for a url. ???? It is overhead my head. Please explain how to get the image here and I will do it.
  • 3 weeks later...
A tip : Changing color table .
Thats an easy thing to do but very recommended
Create one line with minimal thickness .
Xform->translate (copy ) it 255 times
Now use Bryan314 c-hook colorent (get it from here ,if you still don`t have them Bryan`s C-hooks )
select all your entities ,set colors from 0 to 255
and run it
Change colors for entities that you do not see good or don`t see at all
WTHH
The main task of this trick with colors is to be able ALWAYS TO SEE CONVERTED GEOMETRY .
It happened a couple of times that I was close to scrapping some part simply because the imported Cad system used white background and I not saw black entities on black .
After I had run this test it would never happen again!
WTHH
  • 1 month later...
Well ,I have something to contribute too
Fast way to check if contours are closed .
If you have 200-1000 contours it can be a challenge ,right ?
Not if you`ll use create->drafting->hatch command ~~~~~~~~~~~~~~~
Hatch entities are fill patterns inserted within closed curve boundaries in a drawing.
If some contours are not closed ,the hatch will be unsuccesful and this contours will be marked in red .
PS
Hi ,Winnie ,I am in !
I would say better option is to use Analize Contour using thurogh. this will give you the option to mark the problem areas for you.
Much fater and easer
Jay !
Thank you for contribution !
Not want to argue .
Only want to say ,that what Bunnie sais good for not closed chains and for all other cases too and what You say good for overlapping chains mostly
Thorough searches for all overlapping entities. You must select Display (Overlapping entities) to enable this option. This search takes longer to process than Quick.
In our (my ,Bunny and Winnie work) the main problem is not closed chains (0.1 is enough )
This can and happens mostly in 3d models with bad imported surfaces .
There are some other cases when you can get the mass appearance of not closed chains .
  • 2 months later...
NONSENSE (New Open-minded NonHuman Scientific Essential Nonprofit Symbolic Encyclopedia )
initiative Lazy tricks revival .
Clean geometry
Preface.
Most problems ,that moldmaker have ,IMHO ,are from bad geometry .
If all the project would be made by one man on one Cad-Cam all or most of
this problems would never occur ,but the real life sometimes very far from
that .
You can get bad ,low quality model ,with lame tolerances ,bad surfaces ,bad
geometry ,bad solids ,and you need to work on it cause your boss scares to
offend the client asking for a good model .
Also the matter of convertors .
Take the best model in the world ,pass it through 2-3 converters and chances
are high that the model may be bad .
Some programs like Cimatron Elite that`s very strong program notorious for
bad convertors ,
So when I get a model from the Cimatron and even a guy tries his best with
different convertors still the model can be bad at the end .
Also when the geometry is bad ,especially contours ,be ready for some not nice
suprises ,especially in contour 3d toolpathes .
The tool can jump down 100 mm only because to keep tangency of the gap
when on contour element looks a bit upwards and the other over a gap downwards
So my goal is TO prepare good geometry BEFORE trying to make the toolpath
I will start from model analizing
Stay tuned
Little tip :
Scrapped part in many cases can be used as a nice ashtray !
Mine can be used for very large boat anchors.
Hey Iskander, I have a question.
I want to replace my current monitor with my flat screen (not an lcd,just a flat panel display) but my video card doesn't support the dv input that my monitor has.
I have a Gforce2 pro,so I got an adapter to go from dvi to vga.
I hooked it up last night,but got no display at all.
Why is that?
Ok ,when you import model and you don`t have
error messages and all analize procedures do not show errors ,still you can have problems and sometimes even visual check is a hard task ,but may be enough to detect them .
So may be it is funny ,but first thing that I do after converting ,levels management ,analize checkings and home setting I run this little c-hook
A link to C-hook
http://www.emastercam.com/tools/chooks/colrsurf/index.html
ColourSurf varies surface colours in an array to a create a patch work
effect. Excellent for working on large surfaced parts.
It is real time-savier .
For it`s better use I changed my color table settings to avoid too dark colors
That`s how my color table looks
To be continued
It can be refresh rate ,for example .
Go down with refresh rate and test it
You pluged in power supply cable ?
It's set at 60hz,same as the other monitor.
And yes the power supply is plugged in.
Oh well,maybe it gives me a reason to go out and get a 256mb video card for gaming huh?
Thanks anyway.
Suppose this is a model
And you run toolpath->surface->finish->shallow and get this result
Only because of some nasty little surface (the remnant of model splitting or some other fault )
If you ran colrsurf.dll before you would see it
The other way is to run analize->surfaces->small.surf with a color changing .
It is a good feature ,but for those who has ver8
it is not an option ,it is new feature of ver9
Stay tuned
Hi Iskander,
I am verily looking forward to this one about analyzing.
This is one of the problems I find time and time again.
I import a costumer’s .DWG, and find double geometry, missing notes or strangest levels.
Now I don’t think you can blame the Mcam converter, you got to expect that once and a while things gets screwed up, like translating Hebrew to Danish. But the fact is you are always sitting with that bad taste in your mouth figuring if you got everything straighten out right. Especially when sometimes you are dealing with the customers who still demands that dimensions are rule and geometry is secondary
What I normally do is starting from one end and putting things on levels, and then I color code as I go along with different colors depending on priority and checked geometry.
Lars
Mill Version 8.1.1 Level .3
Wire Version 8.1.1 Level 2
Demo Version 9
Lars
What I do :
I use IntelliCad as a tool for Dwg/dxf exporting
when MC fails .
I can say that many times Intellicad or Autocad
Convert the drawing worser than MC ,if it was made on an alien program ,(not Intellicad Or Autocad ) .
Intellicad is very mighty program with some nice options and tools ,if you know Autocad you `ll like it ,
It was free before 2001 , now it is cheap pay ,but a demo full options gives you a right to load it something like 1000 times
Recommend to try
After I save dwg or dxf in intellicad as dwg or dxf for ver 12 usually I don`t have problems.
Anyway ,this combination of Intellicad and Mastercam works very nice.
Regards
[ 12-08-2004, 05:08 AM: Message edited by: Iskander teh Owl ]
Jumping out of topic for a bit
Geometry build without closed contours like closed contours with chain ->partial->wait-yes
No need to build additional geometry for engaving
every opened contour with partial chaining taken in two directions so it is regarded as CLOSED !!!!
Masrercam will not calculate nesting pockets ,so you need to add them afterward
Enjoy
If someone needs file ,I can put it on FTP
InSaNe regards
