Family of parts
Hello,
I have been programming a family of parts,(different dia.'s and linear locations), by importing a new solid into an existing file of a dif. size part, putting geometry to the new solid then reselecting the new geometry for each tool and regenerating the path. Is there a faster/easier way to do this. Can Mastercam do parametric programming to adjust for the different sizes. I understand that Solidworks will make the adjustments using, I think it's a matrix table, but I don't have Solidworks.
Can anyone suggest a better way of doing this? Any input will be greatly appreciated.
Thank you,
rchipper
theoretically, you could have a table driven pattern in SW to control features of the part. If the programming was done in MC4SW then it should regenerate correctly when making a change to the spreadsheet.
Never used MC4SW so don't know the pitfalls.
If the family of parts are close enough you might be better off manually writing a program using all XZ? variables then writing each seperate program with a G65 call. Give your print dimensions letters and input the values in the program(s).
G65 P4501 A1.0 B2.75 C.75 D1.014 ect...
G00X[#1+.05]Z#2
G01X-.05F.004
G00X#1Z[#2+.02]
I am with Tim, Take the time to write a smart program with variables, Below is an example that uses Incremental moves and a Variable for the part length
O4956 (J SERIES FRONT RAD)
(CAREFULL INCREMENTAL & ABSOLUTE PROGRAM)
(03.10.13)
(ADDED 0.5MM TO 6MM DIMENSION NOW 6.5)
(#563 X AXIS DEPTH)
N5 (SPINDLE-1 CUT SHAPE)
(T1010 H10. 10 ENDMILL)
(CUT FORM)
#570=0
M98 P4999 (LF/RF)
IF [#560LE2 ]GOTO6 (32MM WIDE)
#563=-22 (20 WIDE)
GOTO7
N6#563=-34 (32 WIDE)
N7 G28 U0
G28 V0 W0
G54
G00 T1010
G361 B0.0 D0.
G00 T [#543](TOOL PRECALL)
M69
G98 G19 M46
M303
M45
G43 H10.
G97 S5000 M13
M69
G00 C0
M68
G00 X60 Y0 Z0
G52 X0 Y#546 Z0 (BUGGER FACTOR ADJUST Y)
M172 (SYNC FOR LOWER SUPPORT)
(SUPPORT ON PART)
M175 (SYNC FOR LOWER SUPPORT)
IF [#562EQ0 ]GOTO900 (LEFT FACING C0)
(RIGHT FACING FROM HERE)
(CUT1 0.3MM STOCK)
G0 Y-25.0 Z [-#520-1.5]M8 (Z-81.5)
X#563
G1 Y-15.3 F300.
G3 V.5 W.5 R.5
G1 Z-2. F500.0 (Z-2)
G2 V7.3 W7.3 R7.3
G1 V4.
G2 V7.3 W-7.3 R7.3
G1 Z [-#520+12.5](Z-67.5)
G3 V.7 W-.7 R.7
G1 V6.
G2 V5.3 W-5.3 R5.3
G1 W-7.5
G3 V.5 W-.5 R.5
G1 V5.
G0 X50.0
G0 Y-25.0 Z [-#520-1.5](Z-81.5)
X#563
G1 Y-15. F300.0
G3 V.5 W.5 R.5
G2 V7. W7. R7.
G1 V4.
G2 V7. W-7. R7.
G3 V1. W-1. R1.
G1 V6.
G2 V5. W-5. R5.
G1 W-7.5
G3 V.5 W-.5 R.5
G1 V5.
G0 X50.0 M09
GOTO998 (EXIT)
N900 (LEFT FACING)
X#563
G1 Y-16.3 F300.0
G3 V.5 W.5 R.5
G1 W7.5 F500.0 (Z-73.5)
G2 V5.3 W5.3 R5.3
G1 V6.
G3 V.7 W.7 R.7
G1 Z-2. (Z-2)
G2 V7.3 W7.3 R7.3
G1 V4.
G2 V7.3 W-7.3 R7.3
G1 Z [-#520-1](Z-81.0)
G3 V.5 W-.5 R.5
G1 V5.
G0 X50.0
Y-21.
G1 X#563
V5.
G3 V.5 W.5 R.5
G1 W7.5
G2 V5. W5. R5.
G1 V6.
G3 V1. W1. R1.
G1 Z-2. (Z-2)
G2 V7. W7. R7.
G1 V4.
G2 V7. W-7. R7.
G3 V.5 W-.5 R.5
G1 V5.
G0 X50.0
N998 (EXIT BLOCKS)
G52 X0 Y0 Z0 (BUGGER FACTOR RESET)
M176 (SYNC FOR LOWER SUPPORT)
(SUPPORT OFF PART)
M09
M05
G49
G28 U0
G28 V0 W0
(SUB END)
G69.1
M01
M99
I program the smallest part and the largest part, Then I compare the output and use it to write a macro program to run all parts by inputing all the varables needed with speeds and feeds.
Example
:8000(XXXXX MAIN PROG.)
(HEAD 1)
G20
G0G10L2P0X0.Z11.3512
G0G10L2P1X0.Z0.
(ENTER PART # ON MACRO VAR. #500)
G65P1000(PART # MACRO)
M38
M434
M100
M01
M101
N4G0G28U0.(TOOL - 4 OFFSET - 4)
G0G30W0.
M102
G0T0499
M11(CHUCK UNCLAMP)
M25
G50S#100
G96S#101M3
G0G54Z-.04M8
X3.
M51
X1.2425
G99G1X1.0425F#102
Z2.0
G0X1.18
Z-.04
G1X.988
Z1.955
G0X3.
M9
M59
G0G28U0.M5
G0Z[11.9312+#116]
G0T0488
M103
/M01
M104
N2G0G28U0.(TOOL - 2 OFFSET - 2)
M105
G0T0299
M10(CHUCK CLAMP)
G50S#104
G96S#105M3
G0G54Z[11.9312+#116]M8
X3.
X.968
G1Z[11.8312+#116]F#106
Z[8.0337+#116]
X1.42
G0Z[11.9312+#116]
X.716
G1Z[11.8312+#116]
Z[10.5112+#116]
X.7974
Z[9.8789+#116]
G3X.8119Z[9.85+#116]R.0612
G1Z[8.0337+#116]
X1.188
G0Z[11.9312+#116]
X.4641
G1Z[11.8312+#116]
Z[11.1104+#116]
X.5581Z[11.0634+#116]
Z[10.5112+#116]
X.936
G0X3.
IF[#116LE0.]GOTO1002
M9
M81
G0G28U0.M5
G0T0288
M106
/M01
M107
N44G0G28U0.(TOOL - 4 OFFSET - 4)
M108
G0T0499
G50S#107
G96S#108M3
G0G54Z[11.7+#116]M8
X3.
X.4016
G1Z[11.7+#116]F#109
Z[11.106+#116]
X.4226Z[11.0955+#116]
X.4826Z[11.0635+#116]
G3X.4916Z[11.0526+#116]R.0154
G1Z[10.4856+#116]
G2X.5069Z[10.48+#116]R.0057
G1X.7042
G3X.733Z[10.4646+#116]R.0154
G1Z[9.8876+#116]
G2X.7439Z[9.8735+#116]R.0246
G3X.769Z[9.8646+#116]R.0154
G1Z[8.0096+#116]
X1.22
X1.3614Z[8.0732+#116]
G0X3.
IF[#116LE0.]GOTO1004
M9
M81
G0G28U0.M5
G0T0488
M109
/M01
M110
N6G0G28U0.(TOOL - 6 OFFSET - 6)
M111
G0T0699
G50S#110
G96S#111M3
G0G54Z[7.98+#116]M8
X6.
X1.42
G1X.71F#112
X1.42
G0X6.
G0G28U0.M5
G0T0688
M112
/M01
M113
IF[#116LE0.]GOTO8
N22G0G28U0.(TOOL - 2 OFFSET - 2)
M114
G0T0299
G50S#113
G96S#114M3
N1002(FOR SHORT BARREL T2)
Z[8.0803+#117]
G0X3.
X.8974
G1Z[7.9803+#117]F#115
Z[7.3119+#117]
G2X.8212Z[7.2187+#117]R1.3138
G1Z[2.454+#117]
X.98Z[2.0063+#117]
X1.1214Z[2.077+#117]
G0Z[7.3384+#117]
X.9137
G1X.8412Z[7.2452+#117]
G2X.6624Z[6.7688+#117]R1.3138
G1Z[6.7638+#117]
X.7323Z[2.7157+#117]
G2X.7362Z[2.6936+#117]R.1288
G1X.8412Z[2.3976+#117]
X.9826Z[2.4684+#117]
G0X3.
M9
G0G28U0.M5
G0Z[11.7+#117]
G0T0288
M115
/M01
M116
IF[#116LE0.]GOTO44
N444G0G28U0.(TOOL - 4 OFFSET - 4)
M117
G0T0405
G50S#116
G96S#117M3
Z[8.08+#117]
G0X3.
N1004(FOR SHORT BARREL T4)
X.835
G1Z[7.98+#117]F#118
Z[7.3396+#117]
G3X.8324Z[7.3334+#117]R.0154
G2X.6Z[6.7835+#117]R1.3596
G1Z[6.7781+#117]
X.6699Z[2.7301+#117]
G2X.6752Z[2.7002+#117]R.1746
G1X1.0144Z[1.7438+#117]
X1.2114Z[1.7613+#117]
G0X3.
M9
M81
G0G28U0.M5
G0Z[7.98+#116]
G0T0488
M118
/M01
M119
IF[#116LE0.]GOTO6
N8G0G28U0.(TOOL - 8 OFFSET - 8)
M120
G0T0899
M26
G50S#119
G96S#116M3
G0G54Z[11.8+#116]M8
X3.
X.3623
G1Z[11.13+#116]F.008
X.4957
Z[11.23+#116]
G0Z[11.8+#116]
X.229
G1Z[11.13+#116]
X.3823
Z[11.23+#116]
G0Z[11.8+#116]
X.199
G1Z[11.115+#116]
X.4957
Z[11.215+#116]
G0X.6957
Z[11.8+#116]
G1X-.0313
G0Z[11.5091+#116]
X3.
M9
G0G28U0.M5
G0T0888
M121
/M01
M122
N10G0G28U0.(TOOL - 10 OFFSET - 10)
M123
G0T1099
G97S#122M3
G0G54Z[11.5091+#116]M8
X3.
X.7
G92X.484Z[10.555+#116]F#123
X.4745
X.4671
X.4607
X.4551
X.4551
G0X.7
X3.Z[11.5091+#116]
M9
G0G28U0.M5
G0T1088
M124
/M01
M125
N1212G0G28U0.(TOOL - 12 OFFSET - 12)
M126
G0T1299
M26
G97S#124M3
G0G54Z[11.35+#116]M8
X3.
Z[11.2025+#116]
X.269
G1Z[11.1025+#116]F#125
Z[11.06+#116]
X.219Z[11.035+#116]
X.1836Z[11.0173+#116]
G0Z[11.2025+#116]
X.319
G1Z[11.1025+#116]
Z[11.0625+#116]
X.274
X.249Z[11.05+#116]
X.2136Z[11.0323+#116]
G0Z[11.2025+#116]
X.339
G1Z[11.1025+#116]
Z[11.1+#116]
Z[11.064+#116]
G3X.336Z[11.0625+#116]R.0015
G1X.299
X.249
G0X.1872
Z[11.0156+#116]
G1X.2225Z[11.0332+#116]
X.276Z[11.06+#116]
X.336
G2X.344Z[11.064+#116]R.004
G1Z[11.1+#116]
Z[11.2+#116]
G0X3.
M9
G0G28U0.M5
G0G30W0.
G0T1288
M127
/M30
M01
N1000(START LOAD SEQ.)
M128
G0G28U0.
G0G30W0.
T0100
M10(CHUCK CLAMP)
M37(SHUTTER OPEN)
G04P1500
M65(LOAD PART)
M129
:1000(PART # AND MATERIAL MACRO)
(SPEED & FEED N2001 OR N2002)
(N2001=ALLOY STEEL)
(N2002=STANLESS STEEL)
IF[#500EQ1001.]GOTO1001
IF[#500EQ1002.]GOTO1002
IF[#500EQ1003.]GOTO1003
IF[#500EQ1004.]GOTO1004
IF[#500EQ1005.]GOTO1005
IF[#500EQ1006.]GOTO1006
IF[#500EQ1007.]GOTO1007
IF[#500EQ1008.]GOTO1008
IF[#500EQ1009.]GOTO1009
IF[#500EQ1010.]GOTO1010
GOTO3000
N1001(CAB)
N1002(CAH)
#132=0.0(LENGTH A)
#133=0.0(LENGTH B)
GOTO2001
N1005(CAB)
N1006(CAH)
#132=4.2(LENGTH A)
#133=0.0(LENGTH B)
GOTO2001
N1009(MAB)
N1010(MAH)
#132=4.2(LENGTH A)
#133=1.99(LENGTH B)
GOTO2001
N2001(ALLOY STEEL)
(N4 TOOL 4 ALLOY STEEL)
#100=[1000*3](MAX RPM)
#101=[100*6](SFPM)
#102=[.001*10](FPR)
(N2 TOOL 2 ALLOY STEEL)
#104=[1000*3](MAX RPM)
#105=[100*6](SFPM)
#106[.001*12](FPR)
(N44 TOOL 4 ALLOY STEEL)
#107=[1000*3](MAX RPM)
#108=[100*6](SFPM)
#109[.001*10](FPR)
(N6 TOOL 6 ALLOY STEEL)
#110=[1000*3.6](MAX RPM)
#111=[100*4](SFPM)
#112[.001*12](FPR)
(N22 TOOL 2 ALLOY STEEL)
#113=[1000*3](MAX RPM)
#114=[100*6](SFPM)
#115[.001*12](FPR)
(N444 TOOL 4 ALLOY STEEL)
#116=[1000*3](MAX RPM)
#117=[100*6](SFPM)
#118[.001*10](FPR)
(N8 TOOL 8 ALLOY STEEL)
#119=[1000*3](MAX RPM)
#120=[100*3](SFPM)
#121[.001*8](FPR)
(N10 TOOL 10 ALLOY STEEL)
#122=[1000*1.28](MAX RPM)
#123=[1./28](TPI)
(N12 TOOL 12 ALLOY STEEL)
#124=[1000*1.28](MAX RPM)
#125=[100*3](SFPM)
M99
N1003(CSB)
N1004(CSH)
#132=0.0(LENGTH A)
#133=0.0(LENGTH B)
GOTO2002
N1007(CSB)
N1008(CSH)
#132=4.2(LENGTH A)
#133=0.0(LENGTH B)
GOTO2002
N2002(STANLESS STEEL)
(N4 TOOL 4 STANLESS STEEL)
#100=[1000*5](MAX RPM)
#101=[100*6](SFPM)
#102=[.001*10](FPR)
(N2 TOOL 2 STANLESS STEEL)
#105=[100*6](SFPM)
#106[.001*12](FPR)
(N44 TOOL 4 STANLESS STEEL)
#108=[100*6](SFPM)
#109[.001*10](FPR)
(N6 TOOL 6 STANLESS STEEL)
#111=[100*4](SFPM)
#112[.001*12](FPR)
(N22 TOOL 2 STANLESS STEEL)
#114=[100*6](SFPM)
#115[.001*12](FPR)
(N444 TOOL 4 STANLESS STEEL)
#117=[100*6](SFPM)
#118[.001*10](FPR)
(N8 TOOL 8 STANLESS STEEL)
#120=[100*3](SFPM)
#121[.001*8](FPR)
(N10 TOOL 10 STANLESS STEEL)
#123=[1./28](TPI)
(N12 TOOL 12 STANLESS STEEL)
#125=[100*3](SFPM)
M99
N3000(ALARM)
#3000=10(NO PART # SET VAR#500)
M99
Thank you all very much. I am sorry for not replying sooner but I have been very busy.
Peter,
That milling C-HOOK would make my life so much easier. The part is not too complicated, diameter changes, linear changes and yes there is a simple 120 degree surface that I am stepping down to rough it.
Would you be willing to share with me how these work? How to create? I am fairly new to Mastercam and am eager to learn everything I can.
Sure, but U should know those C-Hooks are the result of 2-3 years learnig and developing. And digging the net and this forum also ;)
I had to start learning eveything from zero, including C++. That's why was it so long. Today I can say, I can put together some similar in
2-3 weeks, based on this development experience. Whit this, I would say it's not impossible but in the same time not easy.
For basic (half-)automatized tasks, VBS scripts are enough, but the possibilities are limited.
Next level can be the NET-Hook, written in C# or VB. With X7 and with the new NETHook3_0 you have a lot more
functions than VBS scripts, and you can do more, like fancy pop-up windows like mine, do more complex drawings,
auto chaining and auto import (or create) of operations and connect them to geometries.
What I used is C-Hook, written in C++. With C-Hooks you get a lot of function (much more than NET-Hook) you
can control basically everything very deeply and that's why it can be difficult sometimes. But at the same time
you get a full control over everything and you can automatize a lot of functions in Mastercam.
If one day, when you taste this "power" how you can control Mastercam, you gonna say it's easy and fun... ;)
Hope this helps a little and make some sense to start on a way.
