Changing arc sizes as a group
MetalMarvels
I need to change several hundred .096 diameter arcs to .125 diameter arcs (full circles). I have been trying to locate a function similar to the one that allows you to create a point in a group of same sized arcs. If I could create the .125 diameter arcs on a group of points or in the center of a group of arcs - that would work since I can delete a group of same sized arcs (deleting the .096 arcs after creating the "replacement" .125 diameter arcs with same centers). I have not found a function that allows me to do this. Any ideas??
MetalMarvels,
Try X-Form/Offset Contour and Window select all the arcs you have to change. You may have to click outside the group of arcs that you've just windowed to select them all. Once this is done, type in the distance in the Offset Contour dialog and click OK. This should give you the results if the original arcs were all drawn the same way. If they offset to the wrong side, simply Undo immediately and try it again, only change the side from "Left" to "Right", or vise versa, in the Offset Contour dialog. HTH biggrin.gif
I noticed that I forgot to mention that the arcs I want to change are scattered all over the landscape with two other sizes of arcs in irregular arrays. Even a non-rectangular selection box will be almost as painfull as individually selecting the arcs. I was going to explore moving things to different layers and going from there.
This script searches on specific arcs but could be modified to search on pretty much anything using the EntityBits and EntityFlags combination.
Const DEF_CURRENT_ENTITY = -1
Const DEF_ARC_LOWER_BOUND = 0.001
Const DEF_ARC_UPPER_BOUND = 1.00
Const DEF_NEW_GROUP = " Arcs"
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
Dim CArc, CNewArc
Dim bRet, intCounter
Dim dblNewArcs, dblExistingArcs
' -- Initialize our counter
intCounter = 0
If askValue("Input arc diameter to find", DEF_ARC_LOWER_BOUND, DEF_ARC_UPPER_BOUND, dblExistingArcs) Then
' -- Prompt for new dia
If askValue("Input new arc diameter", DEF_ARC_LOWER_BOUND, DEF_ARC_UPPER_BOUND, dblNewArcs) Then
bRet = StartDBSearch(mc_alive, mc_arctype)
' -- Begin our loop through our database
Do While bRet
Set CArc = New McAr
' -- Get this entity
If GetArcData(DEF_CURRENT_ENTITY,CArc) Then
' -- Test
If (CArc.R * 2) = dblExistingArcs Then
Set CNewArc = New McAr
' -- Set our arcs properties from current arc entity
With CNewArc
.X = CArc.X
.Y = CArc.Y
.Z = CArc.Z
.R = (dblNewArcs / 2)
.SA = 0
.SW = 360
.View = mcVIEW_TOP
End With
' -- Create our new arc
If CreateArc(CNewArc, mcCOLOR_YELLOW, mcCONSTRUCTION_LEVEL_CURRENT) = mcENTITY_INVALID Then
ShowString "Could not create new arc"
Else
If Not AddCurrentEntToGroup(dblNewArcs & DEF_NEW_GROUP) Then ShowString "Problem adding new arc to group"
' -- Keep a running total
intCounter = intCounter + 1
End If
End If
End If
bRet = NextDBSearch
Loop
If intCounter = 0 Then
ShowString "No matching arcs found"
Else
ShowString intCounter & " " & dblNewArcs & " arcs created"
End If
End If
End If
End Sub
One problem though - it creates a copy of the arc. FOr example - I created a number of .250 Arcs. I wanted it to change the .250 to .255. It created new .255 arcs.
Hmmmm.
James teh "puts on debug hat"
James,
Yes this creates new arcs in the same position as the existing arcs.
There is a delete entity function in the next mcamvb update (coming soon) that you can plug into the script to remove the existing arcs that will mimic a 'resize' option, currently we can not write to existing entity properties.
I was digging through help and surmised that it was not possible yet. This has application though. I create lots of counterbores and stuff like that and this will come in quite handy.
Thanks Mick - Keep up the great work.
