adv. multiax / moduleworks problem
Frankieboy
anybody knows how to make the morph toolpath  , so the pattern is more equal ( like oper 2 )  , so  the tool does like the old "blend " toolpath
the moduleworks toolpath is better in many occations since it can calculate the correct pos for start - end  , but not good with this geometry
i have made a test part and attached  ,
anybody ?
moduleworks question.mcam
FrankieBoy - You're right that Morph doesn't currently support constant cusp machining, which is really what you're after.  Blend doesn't provide it either, as you know, because it creates a 2d toolpath and projects it down onto the surface.   I'd like to get that into Morph soon, but that doesn't help you out today.
You can get better contact along the fillet if you were to set it to cut with the tip (center of the tool) on the tool axis control page, but then you'll gouge, so head to the collision control page and turn on retract along surface normal if the tip gouges.
Here's a comparison of the different options.  You can see that Morph is giving you a constant stepover, but not a constant cusp.  Compare that to set to Center, and it looks a bit better.
Cheers,
Aaron
thanks to you all
i have now done all  the solutions you came up with , see attached mcx file
nothing really produces a satisfying result  , but im glad that that there will be a solution soon  for the morph/spiral  .
for the solution Aaron came with the bottom of the toolpath is missing
surfaces on level 3
moduleworks question - 5 toolpaths.mcam
