Help with programming a slot
John@WMM
1 hour ago, CJep said:
Axis Sub sample
SLOT_CJep.mcam
The only problem to be aware of with axis substitution is the cutter must point to Y0 or centerline of the part, so if you review this toolpath closely it gouges the walls at the bottom of the slot on each end. its one of the many limitations of axis substitution, a multi-axis type path (like Swarf) would cut this pocket without the gouge on ends.
Roll Die takes care of this and you don't need a multi axis license. I also used transform mirror then rotate to get the other slot. Thank you John Summers for putting this in the software.
5th Axis Roll Die Example
  • Like 3
