Macros: Automatic calculation of fixture offsets
powerfulp
I want the control to calculate fixture offsets for me by using macros (fanuc macro B). I'm not quite sure how to write the formula for this.
What I have is a horizontal machining center with a rotary B-axis. I want to manually enter the X-axis and Z-axis numbers (for the work offsets) at B0 (G54), then run the program and have the formula in the program enter in the rest of the work offsets at the other B-axis angles.
For instance, if I entered in ".0500" for X-axis and "9.0000" for Z-axis, the offsets at B180.000 would be just the opposite signs (-.0500 & -9.0000, respectively). That would be easy enough to write. But I need the formula to be able to calculate at "odd" B-axis angles, like say 103.250 (The answers would be X-8.7719, Z-2.0141), using trigonometry.
So for an example, if I had a G54 (B0) offset with the X & Z-axis numbers given (I enter and these numbers represent distance from c/l of index), I would want to calculate for the X & Z-axis numbers for G55 (@B103.250). I would want the formula to consider what is in the G54 X & Z work offsets (#5221 & #5224), then calculate for the new X & Z work offsets based on what's in the B-axis offset for G55 (#5246), and automatically enter in the table. I know I need to use SIN and COS, but I'm not sure exactly how and where...
I hope I explained that well enough.
Any help is appreciated....
From Fanuc G54.2
The rotary table dynamic fixture offset function saves the operator the
trouble of re–setting the workpiece coordinate system when the rotary
table rotates before cutting is started. With this function the operator
simply sets the position of a workpiece placed at a certain position on the
rotary table as a reference fixture offset. If the rotary table rotates, the
system automatically obtains a current fixture offset from the angular
displacement of the rotary table and creates a suitable workpiece
coordinate system. After the reference fixture offset is set, the workpiece
coordinate system is prepared dynamically, wherever the rotary table is
located.
The zero point of the workpiece coordinate system is obtained by adding
the fixture offset to the offset from the workpiece reference point.
That sounds cool, and I will look into it, thanks. However, I still want to know how to write this. I have mazak and mitusbishi and other controls that use custom macro B but aren't fanuc controls. Plus it would help me become more familiar with custom macro B, etc. I figured it out using excel (in a spreadsheet) but I'm not as familiar with custom macro B...
Are you looking for something like this, you just set your offset on the macro variables and add the math in the program
(B0. OFFSET)
G0G90G10L2P1X#601Y#602Z#603
N88T9008(101240 ENDMILL)
M6
G65P7716B360.(COORDINATE ROTATION)
M11
G0G90G54B0.M8
M10
G0G90G54X.527Y.4103S2801M3T9004
G43H99Z2.
M98P1011
G0G90G55X.527Y.4103
Z2.
M98P1011
Z12.
(B60. OFFSET ROTATION)
G0G90G10L2P1X-[COS[60]*[#601]-[#603*SIN[60]]]Y[#602]Z-[#601*SIN[60]+[#603]*COS[60]]
M11
G0G90G54B60.
M10
G0G90G54X-1.3926Y.5
Z2.
M98P1012
G0G90G55X-1.3926Y.5
Z2.
M98P1012
M5
G0G91G30Z0.M9
G0G91G30X0.Y0.
M01
That formula is exactly correct mathematically, but I don't understand the order of operations. If I use your model, my formula would look like this:
for the X-axis offset:
#5241=[COS[42]*[#5221]-[#5224*SIN[42]]] (Answer is -5.9850)
and for Z-axis:
#5244=[#5221*SIN[42]+[#5224]*COS[42]] (Answer is 6.7218)
I haven't tried this in the machine (I'm not at work till tomorrow), but doing it manually, I know what order to do the calculations. I can't tell what it's doing with the brackets, though. Ok, this is going to be a crazy question, but how do you know where to put them (the brackets)? I would like to write some other formulas ...
Thanks...
- Paul
It can be a pretty simple macro. Or it can be pretty cumbersome. Depending on what you need for functionality.
I wrote one that simple takes one offset(g54...) and transfers compensated values to another offset (g55...). Works very well. Use it all the time.
A typical callup for me would be.
G65 P9050 A0. B123.222 C1. D2. E3. F2.
rotate G54.1 P1 to 123.222 and put into G54.1 P3
This would not physically move the machine but would set the offset to be used when you move there.
I am willing to give it up if you need it. But I find with on machine "software" like this it is best to write them yourself so you are familiar with it in case you are having problems and need to troubleshoot.
In a nutshell you need only do a few things.
establish centerline of rotation
calculate vector to C/L
rotate vector about c/l
output vector endpoint in cartesian coordinates
easy as pie.
Words of advice. Pay attention to your quadrants. Make sure to know how you trig functions act in each quadrant. Or as I didm just create different cases for each quadrant.
Good Luck
Here is what I use
O9910
IF[#23GT49]GOTO50
IF[#23GE1]GOTO200
IF[#23EQ#0]GOTO3000
N50#100=[#23-53]
(W = WORK OFFSET TO BE USED FOR CALC)
(R = NEW WORK OFFSET NUMBER)
(B = INDEX AMOUNT)
(X = INC TO NEW X ZERO AFTER ROTATION)
(Z = INC TO NEW Z ZERO AFTER ROTATION)
#540=-19.682 (MACHINE POS X ROTATION)
#541=-42.13 (MACHINE POS Z ROTATION)
#542=#[5201+[#100*20]] (STORE CURRENT X OFFSET FOR CALC)
#543=#[5203+[#100*20]] (STORE CURRENT Z OFFSET FOR CALC)
#544=[#542-#540](DELTA X)
#545=[#543-#541] (DELTA Z)
#546=SQRT[[#544*#544]+[#545*#545]] (HYP FOR CALC)
#547=[ASIN[#544/#546]] (START DEG FOR CALC)
#548=[#547+-#2] (CACL DEG)
#549=[sIN[#548]*#546] (NEW DELTA X)
#550=[COS[#548]*#546] (NEW DELTA Z)
#551=[#549+#540] (NEW X OFFSET)
#552=[#550+#541] (NEW Z OFFSET)
IF[#18GT49]GOTO2
IF[#18GE1]GOTO20
IF[#18EQ#0]GOTO3000
M99
N200#100=[#23]
(B = INDEX AMOUNT)
#542=#[6981+[#100*20]](STORE CURRENT X OFFSET FOR CALC)
#543=#[6983+[#100*20]](STORE CURRENT Z OFFSET FOR CALC)
IF[#18GT49]GOTO2
IF[#18GE1]GOTO20
IF[#18EQ#0]GOTO3000
N2
G90G10L2P[#18-53.]X#551Z#552B#2
G91G10L2P[#18-53.]X#24Z#26
M99
N20
G90G10L20P#18X#551Z#552B#2
G91G10L20P#18X#24Z#26
M99
N3000#3006=[(NO WORK OFFSET CHECK G65 LINE)]
Wow, these are all awesome replies, thanks. I will be experimenting with all of these.
Does anyone think my formula will work, though? I can't get on the machine to check it at this time, but here it is again:
and for Z-axis:
#5221 is the X-axis position at G54 (B0)which is +.0500
#5224 is the Z-axis position at G54 (B0)which is +9.0000
and the "42" is the B-axis angle that I am figuring out the offsets for.
The calculations are correct, I just don't know about the precedence (the use of the brackets). Will the formulas reach the same answers and I have above?
Thanks for any help....
I think this will work, it's a little more simplified...
#7021=[#5321*COS[155.369]]-[#5324*SIN[155.369]]
#7024=[#5321*SIN[155.369]]+[#5324*COS[155.369]]
I can understand the order of operations in this one. COS of 155.369 degrees x #5321 minus SIN of 155.369 degress x #5324 = -2.1255 if #5321 is zero is #5324 is 5.1000. The next one equals -2.1255. The numbers come out correct and I believe the preferences are correct. I will find out when I try it on my machine, hopefully sometime this weekend....
Thanks everyone for the input! :)
- Paul
Here's mine :welcome:
O9018(G2201 -- XZ COORDINATE ROTATION PROGRAM)
(PARAMETER 6058)
#10=[13980+[#4130*20]](CURRENT FIXTURE OFFSET NUMBER)
#11=[#10+1](NUMBER FOR CURRENT OFFSET X)
#12=[#10+2](NUMBER FOR CURRENT OFFSET Y)
#13=[#10+3](NUMBER FOR CURRENT OFFSET Z)
#14=[#10+4](NUMBER FOR CURRENT OFFSET B)
#15=[ABS[#921]-ABS[#[#13]]](Z LENGTH FROM PALLET CL)
#16=[#[#11]](X LENGTH FROM PALLET CL)
#17=SQRT[[#15*#15]+[#16*#16]](HYPOTENUSE LENGTH)
#18=ATAN[#16]/[#15](ANGLE FROM PALLET CL TO PART ORIGIN)
(NOW MAKING NEW G59 COORDINATES)
#19=[sIN[#18-#2]*[#17]](PART ANGLE + ORIGIN ANGLE X LENGTH)
#20=[COS[#18-#2]*[#17]](PART ANGLE + ORIGIN ANGLE Z LENGTH)
#5321=[#19](X G59 COORDINATE)
#5322=[#[#12]]
#5323=[#921]+[#20](Z G59 COORDINATE)
#5324=[#[#14]]
#19981=[#19](X G54P300 COORDINATE)
#19982=[#[#12]]
#19983=[#921]+[#20](Z G54P300 COORDINATE)
#19984=[#[#14]]
M99
Edit to add a snippet of the part programming...
END1
N113 WHILE[#[#539+600+[2-1]]EQ1]DO1 (SURFACE 3)
IF[#172EQ5101]GOTO211
IF[#172EQ5102]GOTO212
IF[#172EQ5105]GOTO211
#900=[#539+[2-1]]
G91 G00 X0 G54 P[#900]
G90 G00 B270.
G2201 B270. <<<<<<<<<<<<<<<<<<
G91 G00 X0 G59
M#173 P[#170+3]
GOTO211
END1
  • 2 years later...
