All Activity
- Today
GOTO command not working with 5 axis program
mkrmrkr replied to Shiva.aero's topic in Machining, Tools, Cutting & Probing
@Shiva.aero are you able to increase this number? How did you get around this limitation? -
Phelix smith 1022 joined the community
Carlos Alvarado joined the community
- Yesterday
Donald Rickard joined the community
Rory Carter joined the community
Appreciate the quick responses guys. Z2G it is. Thanks again.
Your settings look correct.....I use this toolpath frequently and checking "rapid down" as you have yields rapid motion between pecks on all our machines. I'd send a Z2G to your reseller.
pedro12 joined the community
The rapid on the tool page only controls the approach and end retract not in the cycle itself. Give high feed rate is your only option that I am aware of. You can put in a request and see what they say.
Using Advanced Drill for the first time. Can not seem to get the drill to rapid back down for the next peck even though I have the Rapid down box checked in the Cut Parameters branch. It rapids down same as the programmed feed rate. Also, what purpose is the Cutting Parameters feeds / speeds in the Tool branch. Seems that the Cut Parameters branch page feeds / speeds overwrites it. Thanks everybody.
Nickle-Pickle joined the community
emastercam joined the community
Need to get a hold of your dealer so they can remote in and see what is going on.
llynn joined the community
Time for a call to your reseller
Windows 11 is apparently problematic enough that its market share is actually declining. I built a nice new rig for my dad last year, and put 11 on it. Updates keep breaking things, so we're considering dropping it back to 10. https://gs.statcounter.com/os-version-market-share/windows/desktop/worldwide
Dhamodharan D joined the community
- Last week
I would go into task manager and kill everything related to mastercam. I had to do with the camplete the license thing got hung up and a restart wasn't fixing it
Yes, still doesn't work.
Have you tried running an an administrative?
I am also having an issue with Mastercam where it never starts at all, when I attempt to open it, it does nothing. I checked event viewer and found this: Faulting application name: Mastercam.exe, version: 26.0.7341.0, time stamp: 0x645da48c Faulting module name: KERNELBASE.dll, version: 10.0.22621.3527, time stamp: 0x83efbeab Exception code: 0xe06d7363 Fault offset: 0x000000000006543c Faulting process id: 0x0x6C6C Faulting application start time: 0x0x1DAA7D2759B8F4C Faulting application path: C:\Program Files\mcam\Mastercam.exe Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll Report Id: c5348f50-e072-44e2-9e17-88b1ce8beeec Faulting package full name: Faulting package-relative application ID: Any suggestions? I've reinstalled the application multiple times, repaired C++ redistributable, ran sfc /scannow, nothing seems to work.
I am also having the same issue. Mastercam never starts at all, when I attempt to open it, it does nothing. I checked event view and found this: Faulting application name: Mastercam.exe, version: 26.0.7341.0, time stamp: 0x645da48c Faulting module name: KERNELBASE.dll, version: 10.0.22621.3527, time stamp: 0x83efbeab Exception code: 0xe06d7363 Fault offset: 0x000000000006543c Faulting process id: 0x0x6C6C Faulting application start time: 0x0x1DAA7D2759B8F4C Faulting application path: C:\Program Files\mcam\Mastercam.exe Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll Report Id: c5348f50-e072-44e2-9e17-88b1ce8beeec Faulting package full name: Faulting package-relative application ID: Any suggestions? I've reinstalled the application multiple times, repaired C++ redistributable, ran sfc /scannow, nothing seems to work.
Remove the solid history.
Guilty as charged.
Slykdexia rules KO!
Zip 2 Go is the utlity in Mastercam that share files with all the settings along with post, machine and control definition and if wanted the Machine Simulation file. Simulates correctly on my end. The axis travels and limits are all wrong and need to be fixed other than that without a Z2G cannot tell you why you are seeing the issue you are seeing.
