All Activity
This stream auto-updates
  1. Today
  2. Yesterday
  3. Appreciate the quick responses guys. Z2G it is. Thanks again.
  4. Your settings look correct.....I use this toolpath frequently and checking "rapid down" as you have yields rapid motion between pecks on all our machines. I'd send a Z2G to your reseller.
  5. The rapid on the tool page only controls the approach and end retract not in the cycle itself. Give high feed rate is your only option that I am aware of. You can put in a request and see what they say.
  6. Using Advanced Drill for the first time. Can not seem to get the drill to rapid back down for the next peck even though I have the Rapid down box checked in the Cut Parameters branch. It rapids down same as the programmed feed rate. Also, what purpose is the Cutting Parameters feeds / speeds in the Tool branch. Seems that the Cut Parameters branch page feeds / speeds overwrites it. Thanks everybody.
  7. Need to get a hold of your dealer so they can remote in and see what is going on.
  8. Time for a call to your reseller
  9. Windows 11 is apparently problematic enough that its market share is actually declining. I built a nice new rig for my dad last year, and put 11 on it. Updates keep breaking things, so we're considering dropping it back to 10. https://gs.statcounter.com/os-version-market-share/windows/desktop/worldwide
  10. Last week
  11. I would go into task manager and kill everything related to mastercam. I had to do with the camplete the license thing got hung up and a restart wasn't fixing it
  12. Have you tried running an an administrative?
  13. I am also having an issue with Mastercam where it never starts at all, when I attempt to open it, it does nothing. I checked event viewer and found this: Faulting application name: Mastercam.exe, version: 26.0.7341.0, time stamp: 0x645da48c Faulting module name: KERNELBASE.dll, version: 10.0.22621.3527, time stamp: 0x83efbeab Exception code: 0xe06d7363 Fault offset: 0x000000000006543c Faulting process id: 0x0x6C6C Faulting application start time: 0x0x1DAA7D2759B8F4C Faulting application path: C:\Program Files\mcam\Mastercam.exe Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll Report Id: c5348f50-e072-44e2-9e17-88b1ce8beeec Faulting package full name: Faulting package-relative application ID: Any suggestions? I've reinstalled the application multiple times, repaired C++ redistributable, ran sfc /scannow, nothing seems to work.
  14. I am also having the same issue. Mastercam never starts at all, when I attempt to open it, it does nothing. I checked event view and found this: Faulting application name: Mastercam.exe, version: 26.0.7341.0, time stamp: 0x645da48c Faulting module name: KERNELBASE.dll, version: 10.0.22621.3527, time stamp: 0x83efbeab Exception code: 0xe06d7363 Fault offset: 0x000000000006543c Faulting process id: 0x0x6C6C Faulting application start time: 0x0x1DAA7D2759B8F4C Faulting application path: C:\Program Files\mcam\Mastercam.exe Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll Report Id: c5348f50-e072-44e2-9e17-88b1ce8beeec Faulting package full name: Faulting package-relative application ID: Any suggestions? I've reinstalled the application multiple times, repaired C++ redistributable, ran sfc /scannow, nothing seems to work.
  15. Been looking for a method to do this lately as well. Found it today! The menu to choose a Default Simulation Machine for a given Machine Def is under 'General Machine Parameters' in the Machine Definition Manager. Found this thread last week while I was trying a few things out, wanted to update it with an answer. I'm using 2024 U6.
  16. I bought a new PC last year that came with Win11 It's got 6 months on it now and I've had no issues, with Mastercam or any of the other CAD/CAM apps I run We've update 2 engineering PC at work from Win10 to 11 including mine. My work PC has been in Win11 for a couple of months.... no issues A coworker recently had a made to order Win11 and was suffering crashes so bad it was unusual after a bunch of trouble shooting he found the problem. He set his Mastercam installs to "run as an admin" which fixed the problem. As for security and spyware, I have turned a bunch of stuff off and opted out of things. The only way to eliminate it completely is air gap your machine.
  17. This is a new one and glad I keep backups of my workspace file. Anyone else seeing just random issues with Windows 11? I am hearing of large groups down grading to Windows 10 because of how bad the bloatware and spyware is in windows 11 that Microsoft is putting for the the NSA, CIA and other intelligence agencies.
  18. i will focus on those calculations in the beginning . Would you suggest a reliable file or site . Thank you Riverhunter , love you.
  19. Do some testing and find out what works best for you. 15 years ago i relied on excel files with all kinds of crazy formulas. now days its just experience. Below is an example of what i use. the 25% / 50% rule has been fine for me. you can see the pattern in the step over and stock. Ø.750 bem rgh step over .1875 leaving .060 ( just go for it ) Ø.750 bem semi fin step over .046 leaving .030 ( adjust feed rate for stock left behind ) Ø.750 bem fin step over .012 ( really adjust feed rate for stock left behind ) FINISHING BALL ENDMILLS TOOLPATH REL DIA REL LEN CLAMP REC REC ADJ STEP TIP STOCK COOL ADJ ADJ ADJ ADJ TO ADJ ACT SURF TIME PER TYPE TYPE DIA FL C/R LOC RD RL PRO MAT DEPTH SFM CPT RPM % OVER DOC SURF LEAVE HPF STYLE MAN PART# HOLDER RPM FEED ACPTF CPT DIA RPM MAX RPM FEED SFM FINISH SQ IN HP CIPM BEM SURF PARALLEL 0.7500 2 0.375 1 0.73 2.5 2.6 6061 0.100 1500 0.0091 100% 0.016 0.030 SURF 0 3.5 FLOOD DATA FLUTE HSM-BM-M-20750 .750 SOLID 7640 139.0 0.3919 0.0232 0.526 10900 10000 464.4 1950 64 0:00:08 0.0637 0.2229
  20. Thank you so much. So to get a better surface finish (Rt) , a minimum axial cut (ap) and maximum tool radius are required according to the picture below. But when cutting a very smal thikness (ap), this will affect the chip load per teeth required by the tool manufacturer : how to solve this ? So should i start by the finishing operation and adequate tool to know how much stock to leave in semi finishing or roughing operation? I ask for the methodology in general. Again thank you for help.
  21. Thank you for your feed back Could you suggest a guide that helps.
  22. Zip 2 Go is the utlity in Mastercam that share files with all the settings along with post, machine and control definition and if wanted the Machine Simulation file. Simulates correctly on my end. The axis travels and limits are all wrong and need to be fixed other than that without a Z2G cannot tell you why you are seeing the issue you are seeing.
  23. I'm sorry what's a Z2G? I ended up getting the machine simulation to work but not the simulation. Here's the machsim file: VF3ss with TRT100.zip
  1. Load more activity
