How did you learn to edit posts?
Tom Szelag
Some things are intuitive, mainly the pre-existing switches. But beyond that there is obviously a lot of depth to what you can have a post do. For example the topic that was just revived about moving to a certain position for a toolchange.
So how did you learn it? I've had a fair amount of programming in MATLAB and Java, but I have no idea what the syntax is for a MasterCAM post processor or what any of the variables are.
EDIT - And while I'm at it what is "staging tools"?
Trial n Error
+1 Matt, I don't know too many people who don't still use this method.
Staging tools is when the machine indexs the carosel to the proper tool while the spindle tool is running. Our matsuuras don't stage tools. So at a toolchange it has to wait for the carosel to index before it can be change to the spindle. Mostly single arm toolchangers do this. they have to put the old tool away before loading the new tool.
"Staging tools" refers to bringing the next tool to be used into position for tool change before the tool change command.
EX.
T1 M06
G0 G90 G54 X0. Y0.
G43 H1 Z1. T2
BLAH
BLAH
BLAH
BLAH
BLAH
BLAH
BLAH
BLAH
G0 Z2.
G28 Z0.
T2 M06
It just saves time on tool changes.
Definitely trial and error frown.gif .
Staging tools calls the next tool to the tool change pocket on machines that have floating tool pocket assignments. It makes for a faster tool change by decreasing the wait time for the toolchanger to cycle around.
Post (specific) questions to the forum. There's a lot of talent around here. And people are always ready to help. biggrin.gif
+1 trial and error
+1 cd
also sometimes your dealer may have an older book which is easier to flip thru than the cd.
this is the very heart of why this forum is
so important for us to have.
I've gleamed what I could from here,
the post CD and my reseller and came up with
a solution that works in my post.
Man, your right about these posts having
so much involved with them, mine rotates and
spins on it's head if you ask. Here is what I came
up with for the safe tool change position in case
ptlchgl # Tool change
n,"M05",E
n,pcooloff,e
n,"G91 G28 Z0 ",e
if mi5=1,pmoveout <---- added line to ptlchg and the rest is added in misc. output.
pmoveout# safe tool change
if mi5=1, n,"G91 G28 ", *xh, *yh, e
**the following below is from post.txt file**
[misc integers]
1. "Starting Work Offset[1=G54 2=G55,etc.]"
2. "Sub Programs [# OF SUBS?]"
3. "Sub Program Rotation [0=OFF 1=ON]"
4. "M00 Before This Operation [0=OFF 1=ON]"
5. "TOOL CHANGE POSITION [0=OFF 1=ON]" <----added here (mi1 - mi5)
Tom,
+1 to the trial & error and the post cd. Just start logging in some time and it will come to you.
King,
Paul means you're making the post verify the condition twice. The post is searching mi5 once to make the post go to the postblock and again in the postblock itself. If your postblock has only one line and is being called only in one spot on your post you could get rid of the postblock entirely and make only one line where your arrow is;
if mi5 = 1, n,"G91 G28 ", *xh, *yh, e
Tim
I intended it as a toggle on the misc. integers
so I could select when I want it not everytime.
I'll reread his post again, but this was the only way I could get this thing to post the way I wanted it. you should see this thing (post) eek.gif
it's a monster post that is designed to do just about everything for seven different machines.
no flame on, just the only way I could get the darn thing to behave. confused.gif
Sorry Lou, let me clarify..
This is what you have now:
n,"M05",E
n,pcooloff,e
n,"G91 G28 Z0 ",e
What Tim meant was that the call to a seperate postblock really isn't needed. You can simply have:
n,"M05",E
n,pcooloff,e
n,"G91 G28 Z0 ",e
if mi5=1, n, "G91 G28 ", *xh, *yh, e
What I meant was the if statement that you had in your post block pmoveout was redundant. In order to be in that postblock mi5 had to equal 1 in ptlchgl.
