dynamic comp
k-cee
Strike 2
Q. Does anyone have a post for a [insert machine or control name here]?
A. Ask this question as your first message here and you won't necessarily like the responses you receive. Look to your reseller to supply you with the proper post for your machine, or quote for the work that needs to be done.
If you have something and are looking for improvements, it's a reasonable request. Maybe tell us why the post you have needs improvement.
Perhaps try to participate a bit on the Forum before you go asking for something. Not unlike Habitat for Humanity, we value Sweat Equity here. Quid pro quo, Clarice.
You may also want to let everyone know your company name so that your Hotmail or Yahoo email account doesn't give everyone the impression that you aren't a licensed Mastercam user.
Try reading it
FORUM FAQ
We have a Variaxis 630 5x Post with dynamic compensation. It cost us mucho grande $$$$$$$$$. If you want a free one ask post modification questions and I am sure someone can help tweak the generic fanuc 5x post to do the same thing. If you want one now, ring Inhouse solutions and write a cheque.
Bruce
Once again my company have the variaxis1 post but the output is not up to par with the machine capability . If there is a Oz you first need to find the yellow brick road and so on............
thanks bruce
and yes your right with that quote.
"the world has forgotten, sometimes you can be stuck in the middle. "
First off that is NOT what you said in your previous posts, you specifically asked for a post. With that being said if you need modification that is probably doable.
Welcome to the forum
What is the problem with what your posting is outputting. What are you getting and what do you need?
Yeah believe it or not we have all been there atleast once. I went to place that did not have a good post and I had ot figure out how to modify posts for a 5 axis all on my own did not know about the forum. I as well as others will gladly try to help you get things fixed but free posts espically for a 5 axis are not going to happen sorry if you think they should. I took the time to get myself out of the middle and so did others and if you want some help climbing that ladder out of the hole you been put in by someone's stupidity by not getting the post you need we will help you like I said.
Welcome to the Forum I am origanlly from Jacksonville where abouts in Florida are you?
I am a fan of the mazak controllers but they have one weakness. In true 5 axis work they can only work using single predefined origin point. So any post you get is going to ask for the distance from that point to your MC origin on every WCS you have. As a general rule these custom posts are pricey and locked down by the Mastercam serial numbers.
Since you will need to know the distance away just shift your part in Mastercam that distance and your current post should work. I currently am running multi-part 5-axis production of medical parts lights out and all parts are programmed this way. Funny part is I have the high end post but with proven programs I want my operators to fix what’s wrong at the machine not just try to adjust the problem away.
Orlando Florida
So if we modify the post can it output what we need it to do. The type of work is a Injection
Molding plant. Dynamic comp. uses a G54.2 offset
trying to avoid setting work piece in the center of rotation every time is there any tech support that we can send for post modification.
sorry but did not mean any disrespect to anyone thanks for help.............................
DC GORN, That is how most posts are initially written as it is less risky. If you have a pc fusion controller you can leave the G54 page 0,0,0,0,0 and instead set your datum using the G54.2 offset page. If you have your parameters set correctly the machine knows where the rotation point is and adjusts itself. We have 2 types of 5 axis mazaks here and both of the posts prompted for guageline lengths when we first bought them. We quickly worked out that that was doing things the hard way and changed it to suit the g54.2 method.
When I get into work I will post some code showing how the rotations work.
Bruce
Thanks Dave,,, I know Camaros Arent "cool" anymore but someones going to have to pry that car out of my cold dead hands.
I have not done Mazak I some time. I am currently using DMU evolutions and they use a G7 to set planes. I was told by someone who I thought knew what he was talking about that Mazak could do the same thing it 5 axis positioning but it could not do it is true 5 axis work. Maybe he was referring to 5 axis incremental moves. I will need to figure this out tho cause my company has Mazaks in the UK and we may transfer jobs from time to time.
It works with simultaneous 5 axis paths too. Here is some code of a swarfing op.
 G00 G17 G40 G94 G80
G54.2 P0 (CANCEL DYNAMIC COMPENSATION)
G61.1 (HIGH SPEED SETUP ON TOLERANCE= 0.01)
G91 G28 Z0.
G90 G53 X-630. Y-400.
G91 G28 A0. C0.
N13
G00 G90 G54 A-30. C0.
S15000 X20.966 Y103.148 M03
G54.2 P#100 Z129.35(DYNAMIC COMPENSATION ON)
Z129.35 M08
M43
M46
Z34.35
G01 Z29.35 F2000.
X19.348 Y103.7
X17.672 Y104.035
X15.966 Y104.148
X17.025 Y103.972 Z29.253 A-30.002 C.706 F1041.8
X18.081 Y103.786 Z29.157 A-30.008 C1.411
X19.134 Y103.589 Z29.063 A-30.017 C2.116
X20.183 Y103.382 Z28.971 A-30.03 C2.821
X21.228 Y103.164 Z28.881 A-30.047 C3.524
X22.268 Y102.936 Z28.793 A-30.068 C4.227
X23.302 Y102.699 Z28.706 A-30.092 C4.928
X24.331 Y102.452 Z28.621 A-30.12 C5.628
X25.354 Y102.195 Z28.539 A-30.152 C6.326
X26.371 Y101.929 Z28.458 A-30.187 C7.022
X27.38 Y101.654 Z28.378 A-30.226 C7.716
X28.382 Y101.37 Z28.301 A-30.269 C8.408
X29.377 Y101.077 Z28.226 A-30.315 C9.098
X30.363 Y100.777 Z28.152 A-30.365 C9.784
X31.341 Y100.468 Z28.081 A-30.418 C10.468 F1052.4
X32.311 Y100.151 Z28.011 A-30.475 C11.149
X33.271 Y99.827 Z27.943 A-30.535 C11.827
X34.222 Y99.496 Z27.878 A-30.599 C12.501
X35.163 Y99.159 Z27.814 A-30.666 C13.172
X36.095 Y98.814 Z27.752 A-30.736 C13.839
X37.016 Y98.463 Z27.692 A-30.81 C14.503
X37.927 Y98.107 Z27.634 A-30.887 C15.162
X38.827 Y97.745 Z27.577 A-30.967 C15.818
X39.716 Y97.377 Z27.523 A-31.05 C16.469 F1062.5
X40.595 Y97.005 Z27.471 A-31.136 C17.116
X41.462 Y96.628 Z27.421 A-31.226 C17.758
X42.317 Y96.247 Z27.372 A-31.318 C18.396
X43.162 Y95.861 Z27.326 A-31.413 C19.029
X43.995 Y95.472 Z27.282 A-31.512 C19.657
X44.816 Y95.08 Z27.239 A-31.613 C20.281
X45.625 Y94.684 Z27.199 A-31.716 C20.899 F1072.8
X46.422 Y94.286 Z27.16 A-31.823 C21.513
X47.208 Y93.885 Z27.124 A-31.932 C22.121
X47.981 Y93.482 Z27.089 A-32.044 C22.724
X48.743 Y93.078 Z27.056 A-32.158 C23.322
Bruce
  • 1 year later...
Thanks. I assume you ar talking about Bruce from Mouldcam. I saw in a search that he has a Veri-Axis 630. We have a 730. I have the post pretty much dialed in as far as Dynamic comp on and off. I have even included the offset variables in them to eliminate the scary z moves in on and off. I just don't know how to force the post to make the c-axis move after an A-axis move. It wants to stay at the last C-axis move and calculate the XY output at that location. That is fine if you are programming from c/l of rotation. But we are not and in this case dynamic is not on.
John
I agre about the scary Z movements when dynamic kickcs in and cancels out. Always make sure you call up the G54.2P_ before calling up the TLO...
We have the (2) 730 5X with the new Matrix controlls on them. Those machines are awesome!!!
Renishaw just came up with the update to their inspection plus software to calculate the dynamic work offset without having to do the math @ the machine. (N-4013-0118.00)...
Sorry, but I can't help you with the post. I don't use mastercam.
DYNAMIC WORK OFFSETS
Addition codes #5121 #5122 & #5123 are used within the software. These codes allow the software to
run in normal mode and dynamic mode.
This software can only be used in dynamic mode to measure component features and positions, it can
not be used to update work shifts when G54.2 is active.
To update the dynamic offsets parameter S5 (X & Y) & S12 will need to be used in calculations as
shown below.
Using this example should give you a figure in X & Y which is the difference between the centre
of table rotation in XY and the centre of the part in XY, these must be within a small amount
otherwise the control gives an alarm (I think it is 3mm). The Z is not controlled to the same
tolerance and can be quite big.
O00001004(XYZ DYNAMIC OFFSET EXAMPLE)
(LOAD G54XYZ)
#5221=-315.(LOAD G54X TO TABLE CENTRE)
#5222=-315.(LOAD G54Y TO TABLE CENTRE)
#5223=-399.(LOAD G54Z TO COMPONENT FACE)
G91G0G28Z0
G90
T80M6
G54X0Y0
G43Z100.
G65P9810Z80.F3000
G65P9814D40.Z20.0S1.(UPDATE G54 XY)
(CALCULATE XY DYNAMIC VALUES)
#100=#5221-[-315]
#101=#5222-[-315]
(-315.000 OBTAINED FROM PAR S5)
G65P9810X30.Y-30.
G65P9811Z0.S1.(UPDATE G54 Z)
(CALCULATE Z DYNAMIC VALUE)
#102=689.984+#5223
(689.984 OBTAINED FROM PAR S12)
(LOAD XYZ DYNAMIC VALUES G54.2P2)
G90G10L21P2X#100Y#101Z#102
G91G0G28Z0
G90
M30
END OF FILE
