Tool inspection in new HST paths
  • Replies 55
  • Created
  • Last Reply
Top Posters In This Topic
Marc,
I honestly have't looked but you might take a peek. The newest MP master has a bunch of new funcitionality, you might check it out and see it there is anything in there you can use.
  • 1 month later...
I dug up thej post I started on. I added this to prapid:
 if ((cur_cflg$ < 100000) & (cur_cflg$ => 70000)), ptlchg_sister
else, pncoutput
cur_cflg$ is set to 70000 on the rapid move between passes.
I never finished up on what ptlchg_sister was going to do. You will want very, very different output depending on what your machine has for sister tooling functionality.
If anyone has some examples of what their machine has for sister tooling functionality I would like to see it. I think I remember one machine just using a M16 instead of a M06 to call predefined sister tooling, You even used the same D and H offset #'s. It was pretty cool but I don't remember what kind of machine it was.
  • 1 year later...
Ok I am going to bump this since Gcode's problem brought this back up. I have my information for the block skips he needs,but do not have anything for this function. I found the NCI number for it which is 12608 for distance and 12609 for time. I am wondering has anyone got this to work. I played with this and wonder if someone got it done. If not can someone from CNC chime in since it is not in the posts they supply with Mastercam as of MR2.
I did go into MPMASTER and figure we need to get the information through the pwrttparam$ read. I then get an output and trying to use Roger example above get nothing happening. So if you guys added this capability to the operations give us a way to use it please.
Thanks for anyone that can shed some light on this.
Ron,
Check out the stock Generic 3X Fanuc post that come with the install, most of it is roughed in, I am adding this in to it now
if rpd_typ$ = 7,
pbld, n$, sg00, *sav_zabs, e$
gcode$ = 1000
pretract
pbld, n$, "M00", "(TOOL INSPECTION POINT - POST CUSTOMIZATION REQUIRED)", e$
Looks OK
N2282 G0 Z2.
N2284 M5
N2286 G91 G0 G28 Z0.
N2288 M00 (CHECK TOOL)
N2290 M01
N2292 T1 M6
N2294 G0 G90 G54 X-1.5492 Y1.3429 S8000 M3
N2296 G43 H1 Z2.
N2298 G1 Z-1.736
N2300 Z-1.811 F8.56
hi everyone,
is there any way that i can modify my post so that I can get "M01" everytime it finishes the pocket? I can only add "M01" in prapid .. .
if I put before pncoutput , it will output M01 after clearance height before going to the other pocket..if i put "M01" after pncoutput, the M01 appears after it moves to the other pocket,
  • 1 year later...
I have a huge cavity to rough and I know (if nothing goes wrong) my feedmill inserts will cut good for about 1 hour. I'm estimating this cavity will rough for around 5 hours, so I want to use the tool inspection/change and found this old posting but still wondering if it is worked out and what will I have to do to my post to make it happen.
Thanx
Hi, open the NCI & Parameter Reference manual. Right on the first page near the top ("What's new in X4") there's a link to sections about lathe tool inspection. This is about the lathe tool inspection feature, but it works similar to mill except that you don't get the 29999 comment that is output for lathe. It should get you started.
# Motion NC output
#The variables for absolute output are xabs, yabs, zabs.
#The variables for incremental output are xinc, yinc, zinc.
prapidout #Output to NC of linear movement - rapid
sav_gcode = gcode$
if convert_rpd$ = 1,
feed = maxfeedpm
gcode$ = 1
ipr_type = 0
pcan1, pbld, n$, sgplane, `sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, pcout, [if gcode$ = 1, `feed], strcantext, scoolant, e$
gcode$ = sav_gcode
if rpd_typ$ = 7, ptool_insp #Tool inspection point ------------> ADDED THIS
plinout #Output to NC of linear movement - feed
pcan1, pbld, n$, sgfeed, sgplane, `sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, pcout, `feed, strcantext, scoolant, e$
pcirout #Output to NC of circular interpolation
if not(arccomp), pcompwarn
if hel_2100 = one, pcirout2
else, pcirout1
pcirout1 #Output to NC of circular interpolation
pcan1, pbld, n$, `sgfeed, sgplane, *sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, pcout, parc, feed, strcantext, scoolant, e$
I found what to add, but do not know where to put the postblock ptool_insp at headscratch.gif
Should it go in with/after/before the above code I pasted in?
Thanks again
 ptool-insp    #Tool inspection point
#Modify following lines to customize output for tool inspection
If posttype$ = 2, #Lathe tool inspection point
=(TOOL INSPECTION POINT – POST CUSTOMIZATION
MAY BE REQUIRED) =, e$
If prmcode$ = 29999, #Only output tool insp comment if one
was entered with this insp point
sparameter$ = ucase (sparameter$)
pbld, n$, *sm00, “(“, sparameter$, “)”. e$
else, pbld, n$, *sm00, e$ #Output just the stop if no comment
pbld, n$, *sgcode, *toolno, e$ #Restate tool number
pbld, n$, pgsgplane, e$ #Restate plane code
prpm # Output programmed RPM #Restate spindle
prv_feed = c9k #Set prv_values to c9k to force them out with next moves
prv_gcodes$ = c9k
prv_workofs$ = c9k
if coolant$, prv_coolant$ = c9k
else, #Mill tool inspection point
pbid, n$, *sm00, “(TOOL INSPECTION POINT – POST CUSTOMIZATION
REQUIRED)”, e$
According to the pdf the above code is the postblock but, I still am unclear as to where to add it to my post.
Can one of you post guru's help me out?
Thanx
Should it go in with/after/before the above code I pasted in?.
If I correct remember any place in post
start near from logic if rpd_typ$ = 7, ptool_insp
for easy edit after
This is what my post looks like now and it does not work
 # Motion NC output
ptool-insp #Tool inspection point #*Added 08-19-2009 KAH
#Modify following lines to customize output for tool inspection #*Added 08-19-2009 KAH
If posttype$ = 2, #Lathe tool inspection point #*Added 08-19-2009 KAH
[ #*Added 08-19-2009 KAH
=(TOOL INSPECTION POINT – POST CUSTOMIZATION MAY BE REQUIRED) =, e$ #*Added 08-19-2009 KAH
If prmcode$ = 29999, #Only output tool insp comment if one was entered with this insp point #*Added 08-19-2009 KAH
sparameter$ = ucase (sparameter$) #*Added 08-19-2009 KAH
pbld, n$, *sm00, “(“, sparameter$, “)”. e$ #*Added 08-19-2009 KAH
] #*Added 08-19-2009 KAH
else, pbld, n$, *sm00, e$ #Output just the stop if no comment #*Added 08-19-2009 KAH
pbld, n$, *sgcode, *toolno, e$ #Restate tool number #*Added 08-19-2009 KAH
pbld, n$, pgsgplane, e$ #Restate plane code #*Added 08-19-2009 KAH
prpm # Output programmed RPM #Restate spindle #*Added 08-19-2009 KAH
prv_feed = c9k #Set prv_values to c9k to force them out with next moves #*Added 08-19-2009 KAH
prv_gcodes$ = c9k #*Added 08-19-2009 KAH
prv_workofs$ = c9k #*Added 08-19-2009 KAH
if coolant$, prv_coolant$ = c9k #*Added 08-19-2009 KAH
else, #Mill tool inspection point #*Added 08-19-2009 KAH
pbid, n$, *sm00, “(TOOL INSPECTION POINT – POST CUSTOMIZATION REQUIRED)”, e$ #*Added 08-19-2009 KAH
sav_gcode = gcode$
feed = maxfeedpm
gcode$ = 1
ipr_type = 0
gcode$ = sav_gcode
if rpd_typ$ = 7, ptool_insp #Tool inspection point #*Added 08-19-2009 KAH
