X Crashing on surface rough pocket
Bruce Caulley
Morning all,
I have a solid model that I can't get a surface rough pocket to work. I get:
Bad trim surface found - use analyse test surfaces check model to find others
and:
Toolpath calculation error, contact your Authorised mastecam reseller.
And then it usually crashes.
Model is a solid supplied by the customer, there are no surfaces. If I analyze it it says 0 errors so does anyone know WTF is going on?
BTW I tried the new HS toolpaths too with the same result.
Bruce
IGES frown.gif I did the fixture assembly design in solidworks and then inported the lot into MC as a parasolid.
I have tried creatinf surfaces and then creating solid from surfaces, but it goes no-where from there.
Next attempt: Re-import the IGES direct. (Sounds obvious now doesn't it)
Bruce
I imported the model into SW2007 beta1 and ran
import diagnostics. It found one bad face in one of those holes that break into the floor.
Repairs were successful and I broght the new solid back into X. Still got the same error
when applying toolpaths though.
Pete, I tried those checks and didn't get a problem. Did you get any on your system? Once it came in from SW it was a good solid and "Analyze check solid" found zero errors. creating surfaces from solids gave me a couple of untrimmed surfaces, but who hasn't had those before. Even selecting just the flat floors in the pocket and using a boundary gave me a crash.
Anyway, the job is done now. I didn't really need to use a surface path on this and would have normally just used 2d pockets on geo broken at intersections, but I thought it strange enough that I ended up spending 2 hours arsing about on something that would have only saved me 5 minutes and would have generated a longer cycletime anyway. We've all done that before biggrin.gif
Bruce
I messed with your file for a few min Bruce.
Your error comes from a bad surface trim carrying over to the parasolid.
All I did was to convert back to surfs and untrim the two bad trim surfs on the end of the part where the 2 side holes are drilled thru the corner radius and I was able to crunch the rough/pocket/.
Something tells me it may also have something to do with the buggy WCS.
What I did was to IGES out the surfs so the WCS got wiped clean. I deleted the tube surfs for the 2 side holes. But maybe it is just an X thing....***shrugs***
I was in ver 9 BTW when I recrunched the rough/pocket.
I always fall back on 9 the first sign of trouble and bypass the frustration...
Murlin teh has no loyality to X....
I have had several jobs that X would NOT do, but 9 worked flawlessly....not to bash X because I like it alot.....I just need to get er done....
I think the solid chaining is the problem on this particular model. I now have a drilling op on the side with 4 points, but they all backplot as 1 hole in the wrong position. This isn't the first problem I have had with solid chains/points with models from this customer, so I will bundle them up and send them to QC.
Bruce
Bruce I've been on vacation I had a look at your file and I had no prob creating a toolpath.
I created surfaces from the solid it had 3 self intersecting surfaces I deleted them used the surfaces as geom in your toolpath and it generated in less than 30 seconds.
There are 3 points color 14 where the 3 bad surfaces where.I put it back on the FTP site as Pita_Dave
You have mail
