M5 instead of M3
Lee.
N160 G0 G17 G40 G80 G90
N170 ( 375-RH-TAP TOOL - 1 DIA. OFF. - 6 LEN. - 1 DIA - .375 )
N180 T1 M6
N190 G0 G90 S255.2 M5 M90 E1 X0. Y0.
N200 H1 Z.1
N210 G84.1 G99 X0. Y0. Z-1.04 R0.1 S255.2 F15.94
N220 G80
N230 M5
like this on line N190.
if i remember correctly the spindle starts up at the g84.1. the reason mc is outputting a m5 is that the control needs to see the spindle stopped. run the program above the part and see if the machine starts up the spindle at the g84.1
i do believe your m90 s255.2 needs to be in the line just above the g84.1. it's been a long time since i worked on a fadal
Here's our tap on a Fadal;
N1030(1/4-20 UNC-2B TAP RH)
N1040T6M06S800.2
N1050G90M05
N1060G84.2
N1070G00X3.3752Y-3.8401E1T7
N1080H6Z2.M08
N1090Z.4
N1100G84.1G99Z-.525R0.4S800.2F40.
N1110X6.3098Y-5.0529
N1120X6.9137
N1130X7.6304Y-5.0533
N1140X8.3177Y-5.0531
N1150X7.987Y-6.5864
N1160X7.7628Y-7.4445
N1170X9.5183Y-8.3197
N1180G00G80Z.4
N1190Z2.
N1200G91G28Z0M09
N1210M01
Run fadals everyday,this should work for you.
N1 O1234 ( TAP )
N2 ( CREATED ON 08-01-08 AT 4:35 PM )
N3G20
N4G0G17G40G80G90
N5 ( 3/8-16 TAPRH TOOL - 1 DIA. OFF. - 1 LEN. - 1 DIA - .375 )
N6T1M6
N7G0G90S80.1M5M90E1X0.Y0.
N8H1Z1.M8
N9G84.2
N10G84.1G98X0.Y0.Z-.5R0.1S80.1F5.
N11G80
N12M5M9
N13G90H0Z0.
N14E0X0Y0
N15M30
I was going to ask if it was a tap, but I figured you'd have mentioned it if it was.
Fadal recommends NOT turning on the spindle (don't know why since it still works if you do) when tapping. The code below will work, although I don't know what M90 is. I've never used it and I've probably tapped over 1000 holes on Fadals. As others have mentioned, the G84.1 will take care of turning the spindle on.
N180 T1 M6
N190 G0 G90 M90 E1 X0. Y0. <-- NO S OR M5!
N200 H1 Z.1
N220 G80
N230 M5
Also, the ".2" in the RPM is only necessary when tapping above 750 RPM.
Thad
Thad and All,
Yes I am running Format 2, It's easier for me to understand, being of Fanuc Based Programming for 9 years.
I will try it as posted in fresh air and let you know what I find.
I haven't run the machine much so am not very experienced in it.
