2D Ramping Quirk
Mic6
So I was milling a 6.000 circle out of a 1" plate. I bolted the slug down, the ramp began at 0 deg. Went around 720 deg to depth. Now regardless if I have "additional pass at final depth" checked or not, when the tool came to 0 deg. at final depth it made a slight G03 move to a point @ about 300 deg on the prev. toolpath and continued on to 0 deg and retracted. It doesnt show in verify, but the extra move pops up when posted. Any ideas?
  • 1 month later...
So I'm still having prblems with contour ramping cutting an arc thru my part and then retracting. My explanantion in my previous post was kinda messy. When the tool reaches depth, it mills around to about 45deg to cleanout the entire ramp, then does a G03 move thru my part back to zero, and then retracts. It will do it regardless if "Make a pass at final depth" is checked or not. FTP doesnt seem to be working. I'llpost the file as soon as it's working.
You're problem is related to using Wear comp and no lead in/lead out
Change it to computer and it works perfectly.
If you NEED wear add small lead in/lead out moves
The ONLY difference between the 2 paths is wear and computer
O1111( 2 )
( T2 | 3/8 VARIMILL | H2 )
G20
G0 G17 G40 G49 G80 G90
( MILL 2.375 HOLE THRU 8X )
T2 M6 ( 3/8 VARIMILL | T: 2 | D: 2 | H: 2 | DIA: .375 )
G0 G90 G54 X.9617 Y-.1738 C0. S2850 M3
G43 H2 Z.25
/M8
Z-1.25
G1 X.9877 Y-.026 F18.5
G3 X.99 Y0. R.15
Z-1.31 I-.99 J0.
Z-1.37 I-.99 J0.
Z-1.43 I-.99 J0.
Z-1.49 I-.99 J0.
X.495 Y.8574 Z-1.5 I-.99 J0.
X.99 Y0. R.99 <-------This is the move cutting back thru my part
X.495 Y.8574 R.99
X.4713 Y.8684 R.15
G1 X.3303 Y.9197
G0 Z.25
M5
G91 G28 Z0. M9
G0 G90 G154 P99 X0. Y0.
T2 M6
M30
I tried using computer comp as suggested. I also added small lead-in/out moves. As well as added moves to Wear. This problem isnt visible in backplot or verify. Only when it posts.
The backplot I used is the actual posted gcode. It is outside of Mastsrecam.
Mastercam does NOT show the move.
What to look for.
I can not say off the top. Have you made any modifications to your post?
You should turn on debugging and see what section of the post is outputting that line. That should give you a starting point for troubleshooting.
You have both I's J's and R's in those arc statements..
Go to your Arc page in the Control Def and
make sure you have all three planes
set to Delta Start to Center..
It looks like you've got at least one of them set to output R's (which are bad news)
O1111( 2 )
( T2 | 3/8 VARIMILL | H2 | D2 | DIA: .375 )
G20
G0 G90 G54 X.99 Y0. C0. S2850 M3
G43 H2 Z.25
/M8
Z-1.25
G3 G41 D2 Z-1.31 I-.99 J0. F18.5
Z-1.37 I-.99 J0.
Z-1.43 I-.99 J0.
Z-1.49 I-.99 J0.
X.99 Y0. I-.495 J-.8574
G40 X.495 Y.8574 I-.99 J0.
G0 Z.25
M5
G91 G28 Z0. M9
T2 M6
M30
Thanks, that did it.
Mic6,
Make sure you do the fix from
Settings/Machine Defintion..
that permanently changes you machine/control def..
If you make the fix from the Edit button in the OPS Manager.. you are only changing the local copy for that MCX file.... and you'll have the same problem on your next project..
also...
will your machine accept a G40 in an arc statment.
most won't
It's a Haas. I just ran it, and it liked it. Suprised me too.
Do you have a value in the D register or did you run D = 0.
If you ran D=0 try running D=-.03 and D= .03
UP IN THE AIR... Turning Cutter comp off
and on with arcs is dangerous business.
Here's the code WITH Lead-in/Lead-Out. I stayed tangent with a 5deg. sweep. I want to preserve as much of the slug as I can.
O1111( 2 )
G20
G0 G90 G54 X.9764 Y-.1625 C0. S2850 M3
G43 H2 Z.25
/M8
Z-1.25
G1 G41 D2 X.9894 Y-.0131 F18.5
G3 X.99 Y0. I-.1494 J.0131
Z-1.31 I-.99 J0.
Z-1.37 I-.99 J0.
Z-1.43 I-.99 J0.
Z-1.49 I-.99 J0.
X.4834 Y.8634 I-.075 J-.1299
G1 G40 X.3474 Y.9268
G0 Z.25
M5
G91 G28 Z0. M9
T2 M6
M30
It ran fine with D.025
