programme run time x2
dorfy
So I just did the verify and that I believe is verification time, not part run time, my backplot run time is 7min 8 sec, verify time was 17 seconds. Unless maybe it updates with each tool? didnt pay much attn to that.
Also for those that could be unawre there are factors in backplot time vs. Actual machine time, if you run a machine with no look ahead you should be close within reason. If your using look ahead as in most HSM applications I have found that 1.5 times is close for the Makinos I used to run as well as the Sodick I run now. Just added info.
The backplot time doesn't take tool changes into account.
The setup sheet does, and there should be a setting in the MMD file and the post where you can input how long your machine takes to do a toolchange, and that is where the setup sheet gets it's times from.
