Dynamic mill open pocket issue.
BenK
I have two different Dynamic mill paths both using the same chain for the pocket. They use a different chain for the stock . The issue I’m having is with the first toolpath. It is set up with all the same start points, directions and settings as the second toolpath but it will not cut the open pocket. Has anyone else had this issue?
Toolpath 1 (incorrect toolpath)
p><p> <img src=[/img]
Does anyone know why the first toolpath would not turn out right?
you have to make 2 chain
1st is the stock
2nd is the stock to LEAVE , not the stock to remove
so your 2nd chain must get the "U" shape , not the "D" shape if i can explain like this ... master cam will remove any material that is not common to the 2 chain (core mill method)
the 2nd chain direction tell mastercam the way to ramp (CCW or CW)
hope thats help you a bit , Dynamic mill can be tricky to get it works well
search for dynamic island.MCX on the FTP X_4_files folder this will be a good example for your situation
Goldorak, That is how I have both of them chained they just don't come out the same. The 1st one is what my part looks like and the 2nd one I created the chain for the stock. I just don't like creating geometry.
The chains are closed.
you need a line closing the rectangle for your stock chain. Then chain the same one but with the U-shape cut out. This would be your island chain. The small u-shaped chain you have there is not needed for this path.
Remember that when you chain the stock, it needs to be the actual stock to machine from. Your above example has the pocket already cut out from it.
Wouldnt it be nice if you could actually specify which chain was stock and which was not.
I have battled with this path in the past. It takes a few times to understand what it is looking for and even then, some tricky open pockets can take a bit of head scratching prior to building your chain geometry. Mostly it is well worth the time spent.
The 2d HST toolpath chaining convention is a little tricky. And your not the only one who thinks we should be able to designate chains at "stock" or "outer profile" or "etc..." to make it easier/faster/more intuitive.
Send your request in to [email protected]
While once you understand the logic it is easy to get it to do what you want, but many times it REQUIRES that you creat NEW geometry. This effectively makes working directly off a solid impossible for toolpaths requiring these chaining methods. Which also means using change recognition is more difficult, etc...
And your comment about it "mostly being worth the time spent" is the worst part. Dynamic mill is a wonderful toolpath that has many benefits. But if it's difficult to use, it simply won't be used as much as it could/should be.
JM2C
A few more kick a$$ videos like that and you'll have a good chance of converting us old style tool path guys, maybe even sell a few more seats. The disclaimer about flying live and making mistakes is great as well. Keeping it real. This is how a lot of us work in the real world. Knowing what not to do is just as important as as knowing whats right. Great job, keep 'em coming.
Just saw part 2 and 3 links:
Part 2 http://www.youtube.com/user/MastercamTech#...u/1/kr1Anw0e5VI
Part 3 http://www.youtube.com/user/MastercamTech#...u/2/He1uJL8xo0k
[ 05-12-2010, 07:03 PM: Message edited by: MotorCityMinion ]
