A simple example script....
' -- WriteIGES.vbs
' -- Writes out the current data to an IGES file.
' -- The IGES file will be written to the folder of the current MCX file
' -- Kick off the script --
Call Main
' Sub Declaration
Sub Main()
Dim objFSO ' -- File System Object
Dim strFileMCX ' -- The current MCX file (full path)
Dim strFileIGS ' -- The IGES output file (full path)
Dim strOutputPath ' -- The output folder
Dim strOutputFile ' -- The output filename
Dim bResult
' -- Create an instance of a File System Object
Set objFSO = CreateObject("Scripting.FileSystemObject")
strFileMCX = GetCurrentFileName()
'ShowString("strFileMCX -> " + strFileMCX) ' -- DEBUG
strOutputPath = objFSO.GetParentFolderName(strFileMCX) + "\"
' ShowString("strOutputPath -> " + strOutputPath) ' -- DEBUG
strOutputFile = objFSO.GetBaseName(strFileMCX)
'ShowString("strOutputFile -> " + strOutputFile) ' -- DEBUG
' -- Assembly the output IGES file path
strFileIGS = strOutputPath + strOutputFile + ".IGES"
' -- Export the current Mastercam database to a IGES file.
' Note that a "enter comment" prompt will be displayed allowing
' you to supply a comment to be placed in the IGES about to be written.
bResult = WriteIGES(strFileIGS)
If bResult Then
ShowString("IGES written to -> " + vbCrLf + strFileIGS)
Else
ShowString("IGES write -> failed!")
End If
' -- Clean up
Set objFSO = Nothing
End Sub
but can't you just simply do file > save as... > .iges?
Yes...
I can't get it to export thru code
He said he wanted to do it "by code" and tagged his post with VBScript, so that's what I answered. ;)
The script cannot do anything different as File-SaveAs does in regards to the IGES data being written out
it's really just a convenience of not have to click SaveAs and scroll down thru the File Types to find *.IGES ?
You could use ScriptLinker to be able to create a Toolbar Icon for the script and with one click you get an IGES file
  • 2 weeks later...
  • 9 years later...
I've exported "assemblies" from Mastercam as STEP files and imported them into my CAD program and they come in as a single part with multiple bodies and no names. Good chance names are not supported on export. Haven't tried IGES.
There's a saying about IGES... it is really just a misspelling of I guess. Meaning if that is your last resort and the only thing available then it may be better than nothing but not always.
My first choice would be parasolids X_T or X_B.
Second choice would be STEP
Dead last choice, drug kicking and screaming to the alter, would be IGES
No matter what you use I don't think X4 is going to import the part names.
The newer releases will do that when importing parasolids X_T or X_ B
There is a reason for this
Hit File/Help/About
You'll see this..  Mastercam runs on the Siemens Parasolid kernel .
To me, it's common sense that Parasolid files would yield the best results when importing models.
We only use parisolid in this shop but were have guys from a sister company that use space in our shop and they only use IGES.  I ask them if they want me to show them parisolid but they do not like change.  They have been using X4 for all these years and are fighting to change to 2022.  thank for the help.  I will tell them.
I've always used STEP as first choice but I'll be keeping a lookout for any parasolid files in the future. thanks!
8 hours ago, Aaron Eberhard said:
I've always joked that it was " 'I Guess' if you exported as IGES."  :)
For sure it has some unexpected results sometimes,although, there were times also that iges worked out better than step when moving stuff from Catia to mcx although not too often
